Air hose for coach
12-07-2009, 11:50
Air hose for coach
The airhose that comes with the coach is missing. It's the one that plug's into
the outlet port in the cargo bay. I've tried a couple of my regular fittings M style etc but nothing fit's. Does anyone know which hose fitting fit's this port. thanks, Bob 99LX Bunker Hill, Il. (soon to be in Tx) |
12-07-2009, 11:59
Air hose for coach
Bob:
It is a standard fitting but it works differently that most. Instead of pushing in on the right and inserting the air hose you pull it out and insert the air hose. It took me a while to discover that but that is the way it works. Hope this helps. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "contrail Bob" > > The airhose that comes with the coach is missing. It's the one that plug's into the outlet port in the cargo bay. I've tried a couple of my regular fittings M style etc but nothing fit's. Does anyone know which hose fitting fit's this port. > > thanks, Bob 99LX Bunker Hill, Il. (soon to be in Tx) > |
12-07-2009, 15:08
Air hose for coach
There are two different sizes available. You can probably find the correct one
at Home Depot. If you can't, then change the female fitting in the bay to work with what you have. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "contrail Bob" > > The airhose that comes with the coach is missing. It's the one that plug's into the outlet port in the cargo bay. I've tried a couple of my regular fittings M style etc but nothing fit's. Does anyone know which hose fitting fit's this port. > > thanks, Bob 99LX Bunker Hill, Il. (soon to be in Tx) > |
12-08-2009, 11:23
Air hose for coach
Marv is right. This is an unusual female fitting and different from the "air
coach up" fitting in engine compartment. It fits all of my std 1/4" male tips, you just have to insert hose, (it won't snap like a normal fitting), then slide the collar back toward the hose. MoreyZ 99LXi41' now in FL |
