air throttle cable
09-06-2007, 13:24
air throttle cable
Where can I purchase a air throttle cable for DD 6V92 1984 1/2 PT 40
Thanks
Joe South Bend IN
1984 1/2 PT 40
12-15-2009, 17:00
air throttle cable
Am in need of finding a source for the air throttle cable on an
87 PT. It is approx 4' long.
I remember we had some discussion on this awhile back, but can't
any info on it. Morse is out of business, and can't find another
source.
90WBWL401/2 Jus Chillin
Ponchatoula, La. Where we are starting on building the ark after
a week of steady rain and over 21" of the
wet stuff this month.
12-15-2009, 22:57
air throttle cable
Steve- what is wrong with yours? Is it binding up or sticky? We can disassemble
and clean it at Q. You might also consider rebuilding the air throttle
assembly. If you really need a cable, I would take it to a marine supply house
and tell them it's for a boat. If you tell them it's in an over the road
application, they won't help. There are numbers stamped into the side of the
plastic insulation near one end that give the exact length in inches. You may
have to rub off the crud and then wet the insulation to read it.
Shane Fedeli
85PT40
Hershey, PA
> source.
> Steve Gureasko
12-16-2009, 11:49
air throttle cable
Shane,
Thanks for the reply, but this is not for me. A friend who has
an '87 needs the cable. He said it was binding in the housing and
the sheathing was staring to rust(go figure! Just because he lives
in New Orleans). He knows that it is 4' long and has metric threads
on it. The marine places he has tried don't have it. Most of
the boats have mechanical linkage with zerk fittings.
He did say that if he can figure out how to convert over to mechanical
linkage he would.
Ponchatoula, La. Where it finally stopped raining, and I
stopped with the ark, but the animals are
wet and smelly. Anyone want to buy fresh
fertilizer?
12-16-2009, 21:55
air throttle cable
Steve- Have him contact these folks- [http://www.midwestcontrol.com/240.php]
It's a standard push-pull cable with unique ends. He'd probably be able to send
them the old cable and have a new one made up. On ag equipment, this kind of
stuff is pretty common
-Shane
> Shane,
linkage he would.
> Steve Gureasko
> fertilizer?
12-17-2009, 00:21
air throttle cable
Steve,
This cable has been an issue with little or no inputs for an easy fix.
The cable is used on the Bendix curise control / air throttle cylinder, also
used on many PT's, SP's and late model FC's.
There are many posts on the WOG forum, In the interest of helping your friend
one on the threads is
http://www.wanderlodgeownersgroup.com/fo...=midw\
estcontrol
also do a search for Bendix air throttle or Bendix Cruise.
Bill 88 FC Michigan
> source.
> Steve Gureasko
12-17-2009, 00:27
air throttle cable
Steve,
The cable is used on the Bendix cruise control / air throttle cylinder, also
estcontrol
Bill 88 FC Michigan
> source.
> Steve Gureasko
