Help...Us buy our first motoerhome......
01-17-2010, 16:58
Post: #21
Wave, I'm sure you have good intentions so I'll followup. The factory used 2 different bars on the LXi. A 1.75" diameter bar and a 2.125" diameter bar. My bus came equipped with the 2.125". I don't know why they used two bars; since there's no factory at this point one could only speculate.ÃÂ I haven't had an opportunity to try the softer 1.75" bar. It may be just right. All I know for certain is that the 2.125" bar is too stiff. Over the years I've noticed that we Wanderlodge owners aren't afraid to tune our buses to our personal tastes. Many of us are engineers, or have years of trucking experience, or race car experience, or hands on mechanical experience and knowledge. One thing I've learned over the years is to never prejudge a Wanderlodge owner; we are a credentialed lot. David Brady '02 LXi, NC On 1/17/2010 10:42 PM, wavel wrote: ÃÂ |
01-18-2010, 06:31
Post: #22
David,
This description (finally) explains the ride criticisms I've heard about the LXi models... I did not realize that the body/frame combination was so very different from the earlier 'birds. Indeed, (considering its size), my 42' 'bird handled and rode fairly well, especially after I had an alignment done by Henderson's Line-up (Grants Pass OR) where a damaged, bent and jammed Blue Ox True Center steering device was removed and replaced with the much more heavily constructed Safe T Plus steering control (built by Hendersons). During the alignment, we also identified and replaced a worn drag link tie-rod end that had contributed to "wander". My coach did have its share of rattles -- but I ultimately narrowed that down to the windows -- they all needed to have the sealing/weatherstripping renewed to better hold the sliding part of the glass in its channel. (A task I never "got to"...) Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 17, 2010, at 6:58 PM, David Brady wrote:
01-18-2010, 07:48
Post: #23
Pete,
As Stephen pointed out, it's really a matter of personal preference. Some may like the stock ride, other's may find it stiff. IMHO, the stiffness is solely related to the use of a front anti-sway bar (ASB) of aggressive proportions. Recall that no Wanderlodge, before the LXi, came equipped with a ASB; the LXi was the first. Also keep in mind that the suspension system on the LXi is essentially the same Ridewell suspension system used on previous coaches. Also recall that my decision to remove my ASB was guided by conversations with Ridewell engineers whom stated to me that the use of an ASB was purely BlueBird's call and that the suspension functions as designed without the bar. Perhaps the ASB was first used in the LXi cause the designers thought the chassis torsionally stiff enough to handle one. Who knows. All I can relay is my personal experience with my bus, and perhaps anecdotal experience I've gleaned from LXi owners who previously owned FC, PT's, and Wide Bodies. My personal experience is that without the ASB the bus is as Prevost like as your likely to find, smooth, rattle free, and stable. With the ASB, there's considerably more road shock transmitted thru the front suspension. The anecdotal evidence I've gleaned from owners who worked their way up the food chain, is that the LXi is by far the best riding, handling, and rattle free bus Wanderlodge ever built. Prospective buyers need to find a way to take a test drive and to make their own opinion. If anyone in the Western North Carolina area would like to go for a ride in mine, you're more than welcome. David Brady '02 LXi, NC -----Original Message----- |
01-18-2010, 08:36
Post: #24
BB you wrote,
No coach, new, used, metal or plastic will be a snap to
Just curious what you think you think it’s What problems seem to happen the most? My wife and I will soon retire and are considering an Working on a coach. Stuff that is expensive though might
Mark Northglenn,Co. |
01-18-2010, 08:36
Post: #25
David,
Thanks you for the insight.You are right - I do not have an agenda except to move up to a bus - which means I am looking at Prevost and Bluebird. I am sure that topic has come before the group many times.It appears that BB is the better bargin- but I am not sure about the rest of the equation. I really appreciate the group and what they mean to a prospective owner. Wave SW Oklahoma -----Original Message----- |
01-18-2010, 11:15
Post: #26
Mark,
I think your greatest expense will be depreciation (which will be less on an older coach) but upkeep will be more. I am in the same process as you but I do own a coach now. Prepurchase inspection becomes important - engine, transmission, chassis, bakes, generator set,diesel fired heating, AC's, air bags, tires - maybe in that order. All the house stuff is fairly cheap by comparison. Im sure others have kept a log of expense - but if I were to average mine over 10 years it would be about 5K/year - but that is only with rare useage. Wave -----Original Message----- |
01-18-2010, 11:26
Post: #27
Mark,
Again, just a non-mechanic civilian, but from memory, I'll tell you what my most repetitive problems were. #1 Microphor air toilet. If it wasn't one of the air or water valves, it was the pump. If it wasn't the pump, it was the breaker. By far, the toilet gave me more trouble than any other single part. Potential fix is replacing the 12v pump w/ 120v compressor that runs on inverter or installing asimpler camping toilet IF it was on topof the holding tank. #2Refrigerator. Worked fine the first few months, thenit quit working while in motion.Refrigerant showed no leaks, power was okay, circuit board okay, doors were okay, venting okay (after several attempts at all areas to diagnose and fix). We completely removed and re-sealed the existing cooling unit and it still didn't work when in motion. Temecula Valley RV installed a new cooling unit for the new owners. #3 On my Newell, we had water leaks around the window, windshield (new)and skylights. Eventually sealed both automotive skylights with silicon, disabling them and had the factory reseal the windows. Still not water tight but better when sold. #4 Plumbing leaks (both coaches). In my book, plumbing and water leaks must be dealt with as a near-emergency because they can blow your electricity disabling the entire coach or cause rotting and rust that is undetectable until much damage has been done. Inspecting for water leaks or evidence of water leaks from the roof-joints to the basement floor is very important. One electrical problem caused by water leaks can lead to many more. One fix is never to winterize your coach, just pay to keep it plugged in or running diesel or gas heat in the winter. There is no way to be absolutely sure that your coach water pipes havebeen winterized unless you run antifreeze through them. #5 Entry door. Weight, alignment, gunk in the locking mechanism, weather-stripping and sun/heat exposure can cause leaks and warping. I have no ideahow much a normal maintenance should run. If you're at peace and happy with the coach regardless of your repairs, then it's not too much. If it's making you unhappy, it's too much. Coaches are supposed to make us happy. This forum is a good place to learn how to avoid problems or work around them. Best of luck, Brad "bbartonwx@hotmail.com" To: WanderlodgeForum@yahoogroups.com From: summitwolf@... Date: Mon, 18 Jan 2010 13:36:46 -0700 Subject: [WanderlodgeForum] Re: Help...Us buy our first motoerhome...... BB you wrote,
No coach, new, used, metal or plastic will be a snap to own
Just curious what you think you think itâs reasonable to need to spend on maintainance. What problems seem to happen the most? My wife and I will soon retire and are considering an older DP to fulltime in. I donât mind and am very capable of Working on a coach. Stuff that is expensive though might be a problem.
Mark Northglenn,Co. Hotmail: Trusted email with Microsoftâs powerful SPAM protection. Sign up now. |
01-18-2010, 12:07
Post: #28
HI, What years or $ are you considering for a coach. Prevost - best to consider 2004 shell (2005 conversion) or later. Has front axle upgrade Blue Bird--LXi 2004 or earlier. Ross 06 LXi From: wavel To: WanderlodgeForum@yahoogroups.com Sent: Mon, January 18, 2010 3:36:30 PM Subject: Re: [WanderlodgeForum] Re: Help...Us buy our first motoerhome...... David, Thanks you for the insight.You are right - I do not have an agenda except to move up to a bus - which means I am looking at Prevost and Bluebird. I am sure that topic has come before the group many times.It appears that BB is the better bargin- but I am not sure about the rest of the equation. I really appreciate the group and what they mean to a prospective owner. Wave SW Oklahoma -----Original Message----- Looking for the perfect gift? Give the gift of Flickr! |
01-18-2010, 12:21
Post: #29
Interesting....
The general suggestion, particularly on an older coach, is to hold back about $10K to cover "contingencies." The 5K per year is a fair guess for regular maintenance -- less if you can do it yourself -- more if you are incapable of lifting a wrench at all. I think there's a certain randomness to the problems.... 1. In 3 years, I had zero, nada, zip maintenance issues with the Microphor toilet. This air-driven toilet was pressurized by a Microphor-brand (12 vdc) pancake compressor in the basement. 2. The gas/electric "camper" style refrigerators often get complaints. My coach had a full-size home-style 22 cu ft Amana side by side. Rapid weather changes related to moving from place to place caused some internal temperature problems -- but a refrigerator thermometer helped -- I'd just have to adjust the settings if it started to get too warm or too cold. This ran off inverters unless there was shore power or the generator was on. The "nice to do someday" list was to get a newer, much more efficient refrigerator, as this one was a bit of a power hog and would run the batteries down fairly quickly when off the grid. (My coach was "all electric" (no gas on board) -- that had plusses and minuses.) 3. Water leaks. I _thought_ I had a rain water leak, but I eventually traced it to the center AC drain line. The line was blocked somewhere, and the condensation would dump into the cabinets over the galley. I could avoid the problem by just running the front and/or rear ACs instead. After 3 years, I eventually had a rain leak by the Fantastic Fan vent. Cleaned the old caulk (multiple layers, a real mess) and re-sealed. No more leak. Surprised, considering the messy job of previous caulkers, that it didn't leak sooner. 4. Never had any plumbing leaks. 5. Had some issues with the latching mechanism in the front door. Required stripping it down, cleaning, adjusting, and replacing a spring that broke. Had to re-install the safety stop after opening the door during a 70 mph gust in the tail end of hurricane Ike. (Stripped out a couple of screws in the safety stop -- installed a metal plate to give them better strength.) I did have expenses due to getting a new radiator core (about $4K with labor and some other work), and a stress-fracture to the left front shock mount. Came to about $1500 with a new shock ($700 -- the old one was bent by the failure) and the necessary welding. Drive axle brake linings had to be renewed -- about $600 -- including new drive axle shocks. (Fortunately, they were not the expensive ones used up front.) New muffler, with labor about $1300. In hindsight, I might have done this differently, but there would have been very little cost savings. Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 18, 2010, at 3:26 PM, brad barton wrote: |
01-19-2010, 02:01
Post: #30
Good Morning,
On the Prevost side - I think I like the rivited coaches (XL) both from cost and from appearance. Maybe 98 to 2000 with IFS - no slides.
On the BB - I am just learning. Probably 200k $ limit. The cost has been dropping quickly on both - not sure where the bottom is yet or if there will be one.
I note that you suggested LXi 2004 or earlier?
Wave
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ross MacKillop Sent: Monday, January 18, 2010 6:08 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Help...Us buy our first motoerhome...... HI,
Ross
06 LXi
From: wavel To: WanderlodgeForum@ Sent: Mon, January 18, 2010 3:36:30 PM Subject: Re: [WanderlodgeForum] Re: Help...Us buy our first motoerhome.. David, Thanks you for the insight.You are right - I do not have an agenda except to move up to a bus - which means I am looking at Prevost and Bluebird. I am sure that topic has come before the group many times.It appears that BB is the better bargin- but I am not sure about the rest of the equation. I really appreciate the group and what they mean to a prospective owner. Wave SW Oklahoma -----Original Message----- Looking for the perfect gift? Give the gift of Flickr! |
