Pressure washing the 6v92
01-08-2010, 08:58
I wanted to clean up the oil mess on the 6v92 motor using a pressure washer. Is
there anything I need to do or be careful with? I just plan on doing the bottom
where all the oil/dirt gathers then falls on the toad. Should I leave it running
while I do this?
Jerry
85 PT40
Sent via BlackBerry from T-Mobile
01-08-2010, 11:47
Jerry, We have pressure washed my engine so many times that I couldn't count. You can leave it off or running. With this mechanical engine, I have had no problems. You can use some good degreaser, also
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Fri, 1/8/10, jburgessx2@... wrote:
Subject: [WanderlodgeForum] Pressure washing the 6v92
To: WanderlodgeForum@Yahoogroups.com
Date: Friday, January 8, 2010, 2:58 PM
I wanted to clean up the oil mess on the 6v92 motor using a pressure washer. Is there anything I need to do or be careful with? I just plan on doing the bottom where all the oil/dirt gathers then falls on the toad. Should I leave it running while I do this?
Jerry
85 PT40
01-08-2010, 12:14
Keep the alternator dry.
Bill 88 FC Michigan
> Jerry
> 85 PT40
01-08-2010, 12:31
my 2 alternators are way up front by the bed and out of the line of the water
83PT40
Wanderlodge
--- On Fri, 1/8/10, pattypape wrote:
Subject: [WanderlodgeForum] Re: Pressure washing the 6v92
Date: Friday, January 8, 2010, 6:14 PM
Bill 88 FC Michigan
> Jerry
> 85 PT40
01-08-2010, 12:54
Thanks Ernie. I thought it was okay but just wanted to check.
Try not to freeze there. It was cold here today too - only made it to 69 degreesSmile
Jerry
85 PT40
Port Hueneme, CA
Date: Fri, 8 Jan 2010 15:47:42 -0800 (PST)
To:
Subject: Re: [WanderlodgeForum] Pressure washing the 6v92
83PT40
Wanderlodge
Jerry
85 PT40
01-08-2010, 13:04
83PT40
Wanderlodge
Date: Friday, January 8, 2010, 6:54 PM
Jerry
85 PT40
Port Hueneme, CA
To:
83PT40
Wanderlodge
To: WanderlodgeForum@ Yahoogroups. com
Jerry
85 PT40
MARKETPLACE
01-24-2010, 01:01
The engine should be warm when you wash it to promote drying and lack of puddles on the block. It will help dry the harness if you drown it
Gary
85pt40
Date: Friday, January 8, 2010, 7:14 PM
Bill 88 FC Michigan
> Jerry
> 85 PT40
01-24-2010, 01:02
Degreaser is great but I would never wash a running motor. You could get water in the oil
Gary
85pt40
Date: Friday, January 8, 2010, 3:58 PM
Jerry
85 PT40
