***@@water pumps
02-01-2010, 13:22
***@@water pumps
I just replaced one of my small Shurflos with the 5.7. That way I havea backup already installed, and can use the smaller one when boondocking. Thenew largerone puts out enough extra pressure to make a shower a bit more enjoyable, but it certainly is no inordinate increase in pressure enoughto worry about the Bird not handling it. Didn't get the price David got from Amazon though, and I paid a bit over $200 from Tucson's Camping World.
Rick and Marilyn Davis 1993 WBSA
Loudon, TN (in Vegas)
From: luckyron1 To: WanderlodgeForum@yahoogroups.com Sent: Mon, February 1, 2010 5:54:50 AM Subject: [WanderlodgeForum] ***@@water pumps We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked fine up until sometime last week. The wife commented that she thought that she had been hearing the water pumps running continuously for several minutes. Oh oh, I thought, empty water tank and a faucet running somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks anywhere. Cycled all of the pump switches on/off. The pump would turn on/off but no suction, no increase in water pressure. Crawled into the pump area to do a visual/feel. Only the top one runs but no suction. The bottom one won't even run. Anyone been there? Thanks. Ron & Ruth 2000 LXI in SPI |
02-01-2010, 13:52
***@@water pumps
Ron,
It is highly likely that your problem with your pumps running is that there is debris in the Sporland valve that controls the filling of your fresh water tank. Odds are that there is some construction debris that has found it's way to your Sporland valve. One way you could verify that is to connect a hose to your water system and fill the tank. Leave the hose connected overnight. If you find a puddle under your rig and water trickling out your overflow pipe you have debris in your Sporland valve. When you are filling your tank try flipping the tank fill switch several times. It's possible that if there is debris in the Sporland valve seat the water flow plus flipping the switch might clear the problem. Happy trails, Eric Perplies 1996 PT-42 |
02-01-2010, 16:40
***@@water pumps
You guys are great teachers, Thanks to David and all for the info. If I had you folks as teachers when I was going to school, I would be a lot smarter than I am today, and the memory loss wouldn't be as severe, at least percentage wise. Regards to all, George Burke 1977 FC31 Charlotte
On Mon, Feb 1, 2010 at 8:52 PM, Eric <"purple_ees@hotmail.com"> wrote:
02-03-2010, 07:47
***@@water pumps
Thanks for the input guys. I'm considering all advices. One more test to do
after this monsoon is over with. Meanwhile: 1:32 PM 2/3/2010 further testing: with water pumps both on/off, i repeatedly cycled the tank fill valve and it did not jar the pumps to suction. the water hose is connected to the fill and the water is on. cycled the water pump switch repeatedly between all 3 positions with 3 faucets running and the water tank remained full, just like it was when this issue began; i dumped the gray tank twice during the testing. When the weather clears we'll see if the top water pump still hums/vibrates when the pumps are turned on. 2000 LXI in rainy SPI --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > > We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked fine up until sometime last week. The wife commented that she thought that she had been hearing the water pumps running continuously for several minutes. Oh oh, I thought, empty water tank and a faucet running somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks anywhere. Cycled all of the pump switches on/off. The pump would turn on/off but no suction, no increase in water pressure. Crawled into the pump area to do a visual/feel. Only the top one runs but no suction. The bottom one won't even run. Anyone been there? Thanks. > > Ron & Ruth > 2000 LXI in SPI > |
02-03-2010, 13:45
***@@water pumps
Ron,
> To be clear. Once it stops raining fill your tanks until the overflow passes water. Make sure most of your large water uses are over with for the night. Leave the water hose connected and your pumps off. (Use water from the garden hose for the night.) The water overflow will stop dribbling after a couple of minutes after you turn the "tank fill" switch to off. If the tank continues to overflow a small amount of water your problem is probably your electrically operated Sporland water fill valve. If the pump problem goes away you have cleared the debris from the seat of the valve. Eric Perplies 96 PT-42 |
02-03-2010, 15:05
***@@water pumps
Don't forget to check the screen/filter just before the input for the pump. It's rare, but sometimes that filter will clog.
Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 3, 2010, at 5:45 PM, Eric wrote:
03-01-2010, 02:49
***@@water pumps
UPDATE
Thanks for all of the input, much appreciated. All advice was considered and nothing had worked; except maybe to take the 9 month old pumps apart for cleaning. In fact, we were ready to make the trip to Foretravel in Nacadoches to have them replace the pumps under the warranty. The pumps were still down when we left SPI. Along the way, I turned them on and lo and behold they gradually came all the way back. I noticed iron colored water and some debris/clogging in the sink faucet filters/screens. So, upon our arrival in SA, I drained and 'flushed' the water tank, then re-filled it, and the pumps are again functioning at 100%. Go figure! Thanks Ron & Ruth 2000 LXI in SA --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > > We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked fine up until sometime last week. The wife commented that she thought that she had been hearing the water pumps running continuously for several minutes. Oh oh, I thought, empty water tank and a faucet running somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks anywhere. Cycled all of the pump switches on/off. The pump would turn on/off but no suction, no increase in water pressure. Crawled into the pump area to do a visual/feel. Only the top one runs but no suction. The bottom one won't even run. Anyone been there? Thanks. > > Ron & Ruth > 2000 LXI in SPI > |
03-01-2010, 03:38
***@@water pumps
I've had the same thing at one time or another in every RV I've had. I now install a second punpwith an "A" or "B" switch so I can alternate or isolate one when it quits and fix it when I get home.
From: luckyron1 To: WanderlodgeForum@yahoogroups.com Sent: Mon, March 1, 2010 8:49:40 AM Subject: [WanderlodgeForum] Re: ***@@water pumps UPDATE Thanks for all of the input, much appreciated. All advice was considered and nothing had worked; except maybe to take the 9 month old pumps apart for cleaning. In fact, we were ready to make the trip to Foretravel in Nacadoches to have them replace the pumps under the warranty. The pumps were still down when we left SPI. Along the way, I turned them on and lo and behold they gradually came all the way back. I noticed iron colored water and some debris/clogging in the sink faucet filters/screens. So, upon our arrival in SA, I drained and 'flushed' the water tank, then re-filled it, and the pumps are again functioning at 100%. Go figure! Thanks Ron & Ruth 2000 LXI in SA --- In "WanderlodgeForum%40yahoogroups.com", "luckyron1" wrote: > > We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked fine up until sometime last week. The wife commented that she thought that she had been hearing the water pumps running continuously for several minutes. Oh oh, I thought, empty water tank and a faucet running somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks anywhere. Cycled all of the pump switches on/off. The pump would turn on/off but no suction, no increase in water pressure. Crawled into the pump area to do a visual/feel. Only the top one runs but no suction. The bottom one won't even run. Anyone been there? Thanks. > > Ron & Ruth > 2000 LXI in SPI > |
User(s) browsing this thread: 14 Guest(s)
