foggy humid wet windows
02-05-2010, 04:41
Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach
is undrivable. We wipe them down, the defroster is on (does not help). Seems the
only thing that improves the condition is to turn the airconditioners on all
around to a popcicle temperature and freeze but hey the windshield is clear. I
cant believe they made the coach to run this way, it must be some settings that
we are overlooking. Anyone experience this and find out how to correct it? It is
just so annoying and time consuming.
Thanks in advance for anything that could help us out,
Patty Austin
88 wanderlodge PT40
Tampa FL
02-05-2010, 04:51
Is your dash air working? The a/c is used with the defroster so if its not working, the defrost won't work as well in humid conditions.
Markus
Date: Fri, 5 Feb 2010 16:41:01 +0000
Subject: [WanderlodgeForum] foggy humid wet windows
Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming.
Patty Austin
88 wanderlodge PT40
Tampa FL
Hotmail: Trusted email with Microsoft’s powerful SPAM protection. Sign up now.
02-05-2010, 04:59
I have found that when we are in really
humid weather I have to open the fresh air to the heater to help the defrosters
prevent fogging. There is also a possibility that you have a leak in the
heater core. This will cause severe fogging.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of patty_austin
Sent: Friday, February 05, 2010
10:41 AM
humid wet windows
Patty Austin
88 wanderlodge PT40
Tampa FL
02-05-2010, 05:06
It is not just the windshield it is the entire coach, all windows become so wet they soak the frames at the bottoms. Does this still sound like a heater core leak? How can i tell the difference? Is the fresh air the vents?
Thanks
Patty Austin
88 BB Wanderlodge WBPT40
Tampa Fl
--- On Fri, 2/5/10, Chuck Wheeler wrote:
Subject: RE: [WanderlodgeForum] foggy humid wet windows
Date: Friday, February 5, 2010, 11:59 AM
I have found that when we are in really humid weather I have to open the fresh air to the heater to help the defrosters prevent fogging. There is also a possibility that you have a leak in the heater core. This will cause severe fogging.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of patty_austin
Sent: Friday, February 05, 2010 10:41 AM
Patty Austin
88 wanderlodge PT40
Tampa FL
02-05-2010, 05:09
Markus is asking you the right question. My understanding is that the defrost/defog setting should activate the dash a/c compressor to de-humidify the air.
Elliot
1995 WLWB 40
RARA AVIS
NW ILLINOIS
-----Original Message-----
To: wanderlodgeforum@yahoogroups.com
Sent: Fri, Feb 5, 2010 10:51 am
Markus
Patty Austin
88 wanderlodge PT40
Tampa FL
02-05-2010, 05:22
I don't believe that's physically possible on my coach, and I would be surprised
if it were possible on other older coaches.
The "dash air" isn't dash here. It is overhead. The defrosters come from the
dash heaters. There is no connection between the two.
My defrosters do work fairly well.
Don Bradner
90 PT40 "Blue Thunder"
>Elliot
>1995 WLWB 40
>RARA AVIS
>NW ILLINOIS
02-05-2010, 05:26
This is an '88 PT and the controls for the dash air and defrost is separate
systems I believe. The common AC/Heat control was not introduced until the
'90's Coach's. But I could be mistaken on this point.
So warm air inside, glass (inside) cold equals moisture on the inside glass
and fog. So if the glass (inside) is warmer than the cold out side, the
moisture forms on the out side. I have not thought about this since high
school. lol
Is the defrost switch on the lower dash with a front heat on/off switch? I
know the defrost in my FC barely stems the tide of fog on the drivers side,
and not very good until the inside of the windshield warms up. I have
helped it out by switching on the Coach air, fan only, on the overhead to
assist the air moving.
Safe travels,
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
>Elliot
>1995 WLWB 40
>RARA AVIS
>NW ILLINOIS
>From: Markus Meyer
>Markus
>From: patty_austin@...
>Patty Austin
>88 wanderlodge PT40
>Tampa FL
02-05-2010, 05:50
The dash air works great. It freezes us. The defrost is warm air. We have turned on the vents, didn't make a change. We have turned on the dash air, blows great and is cold. we have done various combinations but nothing seems to work except the dehumidifyng use of the AC units that freeze us to death. The best thing we tried is using rainex antifog. But just doesn't seem this should be the fix.
Thanks,
--- On Fri, 2/5/10, Ralph L. Fullenwider wrote:
Subject: Re: [WanderlodgeForum] foggy humid wet windows
Date: Friday, February 5, 2010, 12:26 PM
school. lol
Safe travels,
Duncan, Oklahoma
>Elliot
>1995 WLWB 40
>RARA AVIS
>NW ILLINOIS
>From: Markus Meyer <markusfmeyer@...>
conditions.
>Markus
experience
>Patty Austin
>88 wanderlodge PT40
>Tampa FL
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
WanderlodgeForum-digest@yahoogroups.com
WanderlodgeForum-fullfeatured@yahoogroups.com
02-05-2010, 06:28
when I say dash air I just mean not rooftop. the defrosters do work but only in the center where the metal frame area, not out at the edges. So we cant see in the mirrors or right in front of us. There is no adjusting any directional flow. It just comes out where it comes out. But it doesnt seem to come out all the way across the vent. Mostly comes out drivers right and passengers mid to left. There is nothing blocking any air movement that we can see. Should we use a combination of ac from above the window plus the defroster? We had both on earlier and seemed to make the situation worse than with just the defroster.
PS it is not humiddue to beingin Florida. We are in Tennessee at present driving in a freezing cold rain.
Thanks, Patty
88 PT40
Tampa, Fl
Date: Friday, February 5, 2010, 12:22 PM
I don't believe that's physically possible on my coach, and I would be surprised if it were possible on other older coaches.
The "dash air" isn't dash here. It is overhead. The defrosters come from the dash heaters. There is no connection between the two.
Don Bradner
>Elliot
>1995 WLWB 40
>RARA AVIS
>NW ILLINOIS
Yahoo! Groups Links
02-05-2010, 16:52
When our coach gets saturated with humidity we hook up to 50 amps and run the
air conditioners and the heat together for however long it takes, a couple hours
at least, better yet on and off for a day or two. The excess coach humidity
runs out the AC condensation drains and you are done with if for a while.
A leaking heater core usually makes itself known because the coach starts to
smell like a radiator.
Bob Griesel '84 FC31 WLII WA
> Thanks
> Patty Austin
> Tampa Fl
> From: Chuck Wheeler
fogging.
> - Chuck Wheeler-
> Patty Austin
> 88 wanderlodge PT40
> Tampa FL
