Backup Camera-Monitor
04-30-2010, 06:47
Hi or All, On my 99LX I have the origional sony back up camera and monitor and
it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions? thanks Bob&Carol Howald Bunker Hill, Il. 99LX-SK |
04-30-2010, 13:03
sounds like reversed wires
did you change anything Stephen 97 bmc37 --- In WanderlodgeForum@yahoogroups.com, "contrail Bob" > > Hi or All, On my 99LX I have the origional sony back up camera and monitor and it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions? > > thanks > Bob&Carol Howald > Bunker Hill, Il. > 99LX-SK > |
04-30-2010, 13:17
Hi Stephen: No, nothing changed.If the key is turned on and the engine is off
and you select reverse without starting the engine you get a good picture, when you start the engine and select reverse you lose the picture??????? Bob&Carol 99LX --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > sounds like reversed wires > did you change anything > > Stephen 97 bmc37 > > --- In WanderlodgeForum@yahoogroups.com, "contrail Bob" > > > > Hi or All, On my 99LX I have the origional sony back up camera and monitor and it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions? > > > > thanks > > Bob&Carol Howald > > Bunker Hill, Il. > > 99LX-SK > > > |
04-30-2010, 13:31
04-30-2010, 14:08
Thanks Bill
No, If I turn on the key and hit reverse it works ok, when I start the coach and hit reverse the monitor goes blank. It's a touch pad shift so I doubt if there is much movement. Thanks Bob&Carol 99LX --- In WanderlodgeForum@yahoogroups.com, Bill Mills > > Does this happen when the coach is not running?à That is just a curiosity questiorn, it sounds more like you are pulling on a connector enough to break the connectionà when moving to the reverse position.à You might try an ohm meter at the cable that plugs into the "TV" screen end of theà cable that goes into the camera output, on the camera output end of the cable put a short.à In short, on the cable that carries the output of the camera put a short, where that plugs into the TV put an ohm meter, if you loose continuity when shifting into reverse and it returns in forward look for a work or loose connector on that cable. > Advise is always worth what you pay for it.à Hope this is helpful. > Bill of Huntsville > 83 FC35 > > --- On Fri, 4/30/10, cape0001 <sbirtles@...> wrote: > > From: cape0001 <sbirtles@...> > Subject: [WanderlodgeForum] Re: Backup Camera-Monitor > To: WanderlodgeForum@yahoogroups.com > Date: Friday, April 30, 2010, 8:03 PM > > > > > > > > à > > > > > > > > > > sounds like reversed wires > > did you change anything > > > > Stephen 97 bmc37 > > > > --- In WanderlodgeForum@ yahoogroups. com, "contrail Bob" > > > > > > Hi or All, On my 99LX I have the origional sony back up camera and monitor and it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions? > > > > > > thanks > > > Bob&Carol Howald > > > Bunker Hill, Il. > > > 99LX-SK > > > > |
04-30-2010, 14:14
Check the GROUND(s); bad grounds cause all sorts of strange things to happen.ÃÂ Unplug the camera and reconnect it; do the same with the monitor.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Fri, Apr 30, 2010 at 7:08 PM, contrail Bob <"rhowald@frontiernet.net"> wrote:
05-09-2010, 02:59
05-09-2010, 12:43
Thanks to all. I just looked into it again this past week. I disconnected the
camera, unpluged the cable's on the monitor followed wires as far as I could and it still went blank when shifting to reverse. I have the camera cable and three wires running into the back of the monitor. I discovered that if I disconect the green wire the monitor will no longer come on when reverse is selected. Then, when I put it in reverse and manually turn on the back-up system it all work's normal. this is GREAT as I can remember to turn on the system if I want to use it to back up. It always works normal in forward so for now that's the way Iam using it. Thanks to all. Bob&Carol Howald 99LX-SK Bunker Hill, Il. --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > Is the video selector relay sticking? > Gary 85pt40 > > --- On Fri, 4/30/10, Curt Sprenger > > From: Curt Sprenger > Subject: Re: [WanderlodgeForum] Re: Backup Camera-Monitor > To: WanderlodgeForum@yahoogroups.com > Date: Friday, April 30, 2010, 10:14 PM > > > > > > > > à > > > > > > > > > > Check the GROUND(s); bad grounds cause all sorts of strange things to happen.à Unplug the camera and reconnect it; do the same with the monitor. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > On Fri, Apr 30, 2010 at 7:08 PM, contrail Bob wrote: > > > > > > > > > > > > > > > > > à > > > > > > > > > > Thanks Bill > > No, If I turn on the key and hit reverse it works ok, when I start the coach and hit reverse the monitor goes blank. It's a touch pad shift so I doubt if there is much movement. > > Thanks > > Bob&Carol 99LX > > > > --- In WanderlodgeForum@ yahoogroups. com, Bill Mills > > > > > > Does this happen when the coach is not running?Ãâà That is just a curiosity questiorn, it sounds more like you are pulling on a connector enough to break the connectionÃâà when moving to the reverse position.Ãâà You might try an ohm meter at the cable that plugs into the "TV" screen end of theÃâà cable that goes into the camera output, on the camera output end of the cable put a short.Ãâà In short, on the cable that carries the output of the camera put a short, where that plugs into the TV put an ohm meter, if you loose continuity when shifting into reverse and it returns in forward look for a work or loose connector on that cable. > > > > Advise is always worth what you pay for it.Ãâà Hope this is helpful. > > > Bill of Huntsville > > > 83 FC35 > > > > > > --- On Fri, 4/30/10, cape0001 <sbirtles@> wrote: > > > > > > From: cape0001 <sbirtles@> > > > Subject: [WanderlodgeForum] Re: Backup Camera-Monitor > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Friday, April 30, 2010, 8:03 PM > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > sounds like reversed wires > > > > > > did you change anything > > > > > > > > > > > > Stephen 97 bmc37 > > > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "contrail Bob" > > > > > > > > > > > > > > Hi or All, On my 99LX I have the origional sony back up camera and monitor and it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions? > > > > > > > > > > > > > > > thanks > > > > > > > Bob&Carol Howald > > > > > > > Bunker Hill, Il. > > > > > > > 99LX-SK > > > > > > > > > > > |
