Backup Camera-Monitor
04-30-2010, 06:47
Hi or All, On my 99LX I have the origional sony back up camera and monitor and
it works just great. The problem Iam having with it is that when I put the coach
in reverse I lose the picture when I shift back into forward gear picture
returns. This is a new problem as it used to work just fine, any suggestions?
thanks
Bob&Carol Howald
Bunker Hill, Il.
99LX-SK
04-30-2010, 13:03
sounds like reversed wires
did you change anything
Stephen 97 bmc37
and it works just great. The problem Iam having with it is that when I put the
coach in reverse I lose the picture when I shift back into forward gear picture
> thanks
> Bob&Carol Howald
> Bunker Hill, Il.
> 99LX-SK
04-30-2010, 13:17
Hi Stephen: No, nothing changed.If the key is turned on and the engine is off
and you select reverse without starting the engine you get a good picture, when
you start the engine and select reverse you lose the picture???????
Bob&Carol 99LX
> Stephen 97 bmc37
> > thanks
> > Bob&Carol Howald
> > Bunker Hill, Il.
> > 99LX-SK
04-30-2010, 13:31
Does this happen when the coach is not running? That is just a curiosity question, it sounds more like you are pulling on a connector enough to break the connection when moving to the reverse position. You might try an ohm meter at the cable that plugs into the "TV" screen end of the cable that goes into the camera output, on the camera output end of the cable put a short. In short, on the cable that carries the output of the camera put a short, where that plugs into the TV put an ohm meter, if you loose continuity when shifting into reverse and it returns in forward look for a work or loose connector on that cable.
Advise is always worth what you pay for it. Hope this is helpful.
Bill of Huntsville
83 FC35
--- On Fri, 4/30/10, cape0001 <sbirtles@...> wrote:
Subject: [WanderlodgeForum] Re: Backup Camera-Monitor
Date: Friday, April 30, 2010, 8:03 PM
Stephen 97 bmc37
--- In WanderlodgeForum@ yahoogroups. com, "contrail Bob" wrote:
> Hi or All, On my 99LX I have the origional sony back up camera and monitor and it works just great. The problem Iam having with it is that when I put the coach in reverse I lose the picture when I shift back into forward gear picture returns. This is a new problem as it used to work just fine, any suggestions?
> thanks
> Bob&Carol Howald
> Bunker Hill, Il.
> 99LX-SK
04-30-2010, 14:08
Thanks Bill
No, If I turn on the key and hit reverse it works ok, when I start the coach and
hit reverse the monitor goes blank. It's a touch pad shift so I doubt if there
is much movement.
Thanks
Bob&Carol 99LX
questiorn, it sounds more like you are pulling on a connector enough to break
that cable.
> Bill of Huntsville
> 83 FC35
> From: cape0001 <sbirtles@...>
> Â
> Stephen 97 bmc37
> > thanks
> > Bob&Carol Howald
> > Bunker Hill, Il.
> > 99LX-SK
04-30-2010, 14:14
Check the GROUND(s); bad grounds cause all sorts of strange things to happen.  Unplug the camera and reconnect it; do the same with the monitor.
Curt Sprenger
Anaheim Hills, CA
On Fri, Apr 30, 2010 at 7:08 PM, contrail Bob <"rhowald@frontiernet.net"> wrote:
Thanks Bill
No, If I turn on the key and hit reverse it works ok, when I start the coach and hit reverse the monitor goes blank. It's a touch pad shift so I doubt if there is much movement.
Thanks
Bob&Carol 99LX
--- In "WanderlodgeForum%40yahoogroups.com", Bill Mills wrote:
> Does this happen when the coach is not running?  That is just a curiosity questiorn, it sounds more like you are pulling on a connector enough to break the connection  when moving to the reverse position.  You might try an ohm meter at the cable that plugs into the "TV" screen end of the  cable that goes into the camera output, on the camera output end of the cable put a short.  In short, on the cable that carries the output of the camera put a short, where that plugs into the TV put an ohm meter, if you loose continuity when shifting into reverse and it returns in forward look for a work or loose connector on that cable.
> Bill of Huntsville
> 83 FC35
> Stephen 97 bmc37
> > thanks
> > Bob&Carol Howald
> > Bunker Hill, Il.
> > 99LX-SK
05-09-2010, 02:59
Is the video selector relay sticking?
Gary 85pt40
--- On Fri, 4/30/10, Curt Sprenger wrote:
Subject: Re: [WanderlodgeForum] Re: Backup Camera-Monitor
Date: Friday, April 30, 2010, 10:14 PM
Curt Sprenger
Anaheim Hills, CA
On Fri, Apr 30, 2010 at 7:08 PM, contrail Bob <rhowald@frontiernet .net> wrote:
Thanks Bill
Thanks
Bob&Carol 99LX
> Bill of Huntsville
> 83 FC35
> To: WanderlodgeForum@ yahoogroups. com
> Â
> Stephen 97 bmc37
> > thanks
> > Bob&Carol Howald
> > Bunker Hill, Il.
> > 99LX-SK
05-09-2010, 12:43
Thanks to all. I just looked into it again this past week. I disconnected the
camera, unpluged the cable's on the monitor followed wires as far as I could and
it still went blank when shifting to reverse. I have the camera cable and three
wires running into the back of the monitor. I discovered that if I disconect
the green wire the monitor will no longer come on when reverse is selected.
Then, when I put it in reverse and manually turn on the back-up system it all
work's normal. this is GREAT as I can remember to turn on the system if I want
to use it to back up. It always works normal in forward so for now that's the
way Iam using it. Thanks to all.
Bob&Carol Howald
99LX-SK
Bunker Hill, Il.
> Gary 85pt40
> From: Curt Sprenger
> Â
> Curt Sprenger
> Anaheim Hills, CA
> Â
> Thanks Bill
> Thanks
> Bob&Carol 99LX
> > Bill of Huntsville
> > 83 FC35
> > --- On Fri, 4/30/10, cape0001 <sbirtles@> wrote:
> > From: cape0001 <sbirtles@>
> > ÂÂ
> > Stephen 97 bmc37
suggestions?
> > > thanks
> > > Bob&Carol Howald
> > > Bunker Hill, Il.
> > > 99LX-SK
