Water leaking out tank filler inlet
08-23-2010, 06:46
Hi Folks -
Filled our tank last night for our trip which is supposed to start today. Water
is now leaking out the tank filler connection. Pump is on, filler sporlan valve
switch "off". We will be in campgrounds the next three days but after that we
are dry camping and need to conserve water. Any ideas?
Thanks!
Greg
1986 PT-40
Oceanside, CA
08-23-2010, 09:35
Greg,
Sounds like a check valve malfunction in the Inlet/Regulator/
Check Valve unit. I replace out by taking the unit out and going to a GOOD plumbing store. I told the fellow that I wanted a nipple/check valve/hose connection combination that equaled the same length as what I handed him. Took him maybe 5 minutes to come up with all the parts. I made the mounting out of aluminum.
I did without the regulator and bought one that I can attach to the Hose/water faucet at the camp grounds. Saves the hose too.
A writeup and photos should be out on this site. Might try WOG site as well. I'd email you the writeup and photos but right my main computer is out of commission and the info. is on it.
Good luck.
Curt Sprenger
Anaheim Hills, CA
On Mon, Aug 23, 2010 at 11:46 AM, Greg Young <"gregy1@yahoo.com"> wrote:
Hi Folks -
Filled our tank last night for our trip which is supposed to start today. Water is now leaking out the tank filler connection. Pump is on, filler sporlan valve switch "off". We will be in campgrounds the next three days but after that we are dry camping and need to conserve water. Any ideas?
Thanks!
Greg
1986 PT-40
Oceanside, CA
08-23-2010, 10:35
A quick -Ernie fix-- turn your water pump on, stick a pencil in the inlet and pull it back out, see if that resets your valve.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Mon, 8/23/10, Curt Sprenger wrote:
Subject: Re: [WanderlodgeForum] Water leaking out tank filler inlet
Date: Monday, August 23, 2010, 4:35 PM
Greg,
Good luck.
Curt Sprenger
Anaheim Hills, CA
On Mon, Aug 23, 2010 at 11:46 AM, Greg Young <gregy1@...> wrote:
Hi Folks -
Thanks!
Greg
1986 PT-40
Oceanside, CA
08-23-2010, 15:32
Ernie,
GREAT FIX. I like it.
Curt Sprenger
Anaheim Hills, CA
83PT40
Wanderlodge
Greg,
Good luck.
Curt Sprenger
Anaheim Hills, CA
Hi Folks -
Thanks!
Greg
1986 PT-40
Oceanside, CA
08-23-2010, 17:29
You're both brilliant and kind! But I'm trying Ernie's fix first.
Greg
Home is where my iPhone is.
On Aug 23, 2010, at 8:32 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
Ernie,
Curt Sprenger
Anaheim Hills, CA
83PT40
Wanderlodge
Greg,
Good luck.
Curt Sprenger
Anaheim Hills, CA
Hi Folks -
Thanks!
Greg
1986 PT-40
Oceanside, CA
08-25-2010, 17:19
A quick fix if you are on the road is to
pick up a hose fitting with a shutoff valve in it. Install it and turn it off.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Greg Young
Sent: Tuesday, August 24, 2010
12:29 AM
first.
Greg
Ernie,
Curt Sprenger
Anaheim Hills, CA
On Mon, Aug 23, 2010 at 3:35 PM, Ernie Ekberg <"ernietex@yahoo.com""ernietex@yahoo.com">
83PT40
Wanderlodge
--- On Mon, 8/23/10, Curt Sprenger <"curtsprenger@gmail.com""curtsprenger@gmail.com">
From: Curt Sprenger <"curtsprenger@gmail.com""curtsprenger@gmail.com">
To: "WanderlodgeForum@yahoogroups.com""WanderlodgeForum@yahoogroups.com"
Greg,
out of aluminum.
Good luck.
Curt Sprenger
Anaheim Hills, CA
On Mon, Aug 23, 2010 at 11:46 AM, Greg Young <[url=http://us.mc812.mail.yahoo.com/mc/compose?to=gregy1@yahoo.com]"gregy1@yahoo.com">
Hi Folks -
ideas?
Thanks!
Greg
1986 PT-40
Oceanside, CA
