ceiling panel/overlays in 2000 LXI
10-12-2010, 11:19
We need to get at the underside of the center/2nd AC in order to get a look at
the AC condensate tube connection. We think that the tube may have come
disconnected from the AC due to the in/out movement of the slide. The result
was some ceiling water damage on just one occasion last spring. We want to get
it repaired. We're at Foretravel in Nacogdoches and they can't figure out how
to get it down let alone how to get it back up. Anyone been there? How do you
remove and reset them? Thanks.
2000 LXI in Nacogdoches
10-12-2010, 11:31
attach an air line on your drain tube and blow air up there. It must have some debris blocking the drain
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Tue, 10/12/10, luckyron1 wrote:
Subject: [WanderlodgeForum] ceiling panel/overlays in 2000 LXI
Date: Tuesday, October 12, 2010, 6:19 PM
We need to get at the underside of the center/2nd AC in order to get a look at the AC condensate tube connection. We think that the tube may have come disconnected from the AC due to the in/out movement of the slide. The result was some ceiling water damage on just one occasion last spring. We want to get it repaired. We're at Foretravel in Nacogdoches and they can't figure out how to get it down let alone how to get it back up. Anyone been there? How do you remove and reset them? Thanks.
