Paint on Wanderlodges
10-28-2010, 12:47
Early Wanderlodges where painted with Dupont Imron which is a single stage
polyurethane product which is a long lasting product.I do not know what year Bluebird went to base coat clear coat but most likely was in the 90s and that was BASF. I know that some where in the late 90s 2000s they switched to PPG. Most jobbers Dupont,BASF,PPG,SW,SIkkens can be crossed to the product that the jobber sells but I have always had the best match by going to the OEM paint that was applied.Dupont,BASF,PPG etc. All have Color Scaners (Color Camera) which do a good job in matching colors.Base coats are hard to match with single stage colors it just depends on the quality of match that you want.Hope this helps. Lee Condosta 85 PT 40 Wilmington NC. Automotive Refinish Products.BASF(RM,Glasurit)Sikkens,SW Jobber. BASF,Dupont,Sikkens,SW certified applicator Dupont Certified Commercial applicator. My forty six year in the automotive paint business. |
10-28-2010, 13:03
Hi Lee; I believe it was the change over of the 90 coach with the new caps, that
basf and clear coat went on the Coaches. Wasn't there a rub with EPA about paint booths and Imron paint that made it more econ to change over? Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "lcondosta" Sender: WanderlodgeForum@yahoogroups.com Date: Fri, 29 Oct 2010 00:47:14 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Paint on Wanderlodges Early Wanderlodges where painted with Dupont Imron which is a single stage polyurethane product which is a long lasting product.I do not know what year Bluebird went to base coat clear coat but most likely was in the 90s and that was BASF. I know that some where in the late 90s 2000s they switched to PPG. Most jobbers Dupont,BASF,PPG,SW,SIkkens can be crossed to the product that the jobber sells but I have always had the best match by going to the OEM paint that was applied.Dupont,BASF,PPG etc. All have Color Scaners (Color Camera) which do a good job in matching colors.Base coats are hard to match with single stage colors it just depends on the quality of match that you want.Hope this helps. Lee Condosta 85 PT 40 Wilmington NC. Automotive Refinish Products.BASF(RM,Glasurit)Sikkens,SW Jobber. BASF,Dupont,Sikkens,SW certified applicator Dupont Certified Commercial applicator. My forty six year in the automotive paint business. ------------------------------------ Yahoo! Groups Links |
10-28-2010, 13:55
Ralph, In my Blue Box in my 91 I have detailed color drawings of the paint design on my Bird. It lists all Dupont Imron paint colors and there is some sort of paint warranty document from Dupont guaranteeing the finish for some number of years. I haven't looked at those documents in quite a while but they clearly indicate Dupont paints. Of course, it is possible mine was a skunks work coach, per some recent discussions, but it doesn't seem like there were any absolutes at Wanderlodge coachworks! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone
On Oct 28, 2010, at 8:03 PM, "Ralph" <"rlf47@swbell.net"> wrote:
10-28-2010, 16:12
Mine has the BASF Glasurite colors.
Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 10/28/2010 at 8:55 PM Michael Bulriss wrote: >Ralph, > >In my Blue Box in my 91 I have detailed color drawings of the paint design >on my Bird. It lists all Dupont Imron paint colors and there is some sort >of paint warranty document from Dupont guaranteeing the finish for some >number of years. I haven't looked at those documents in quite a while but >they clearly indicate Dupont paints. Of course, it is possible mine was a >skunks work coach, per some recent discussions, but it doesn't seem like >there were any absolutes at Wanderlodge coachworks! > >Mike Bulriss >1991 WB40 "Texas Minivan" >San Antonio, TX > >Sent from my iPhone > >On Oct 28, 2010, at 8:03 PM, "Ralph" > >> Hi Lee; I believe it was the change over of the 90 coach with the new >caps, that basf and clear coat went on the Coaches. Wasn't there a rub >with EPA about paint booths and Imron paint that made it more econ to >change over? >> Safe travels, Ralph & Charolette Fullenwider >> '84 FC35 "Ruff Diamond" >> Duncan, Oklahoma >> Sent via BlackBerry by AT&T >> >> -----Original Message----- >> From: "lcondosta" >> Sender: WanderlodgeForum@yahoogroups.com >> Date: Fri, 29 Oct 2010 00:47:14 >> To: >> Reply-To: WanderlodgeForum@yahoogroups.com >> Subject: [WanderlodgeForum] Paint on Wanderlodges >> >> Early Wanderlodges where painted with Dupont Imron which is a single >stage polyurethane product which is a long lasting product.I do not know >what year Bluebird went to base coat clear coat but most likely was in the >90s and that was BASF. I know that some where in the late 90s 2000s they >switched to PPG. Most jobbers Dupont,BASF,PPG,SW,SIkkens can be crossed to >the product that the jobber sells but I have always had the best match by >going to the OEM paint that was applied.Dupont,BASF,PPG etc. All have >Color Scaners (Color Camera) which do a good job in matching colors.Base >coats are hard to match with single stage colors it just depends on the >quality of match that you want.Hope this helps. Lee Condosta 85 PT 40 >Wilmington NC. Automotive Refinish Products.BASF(RM,Glasurit)Sikkens,SW >Jobber. BASF,Dupont,Sikkens,SW certified applicator Dupont Certified >Commercial applicator. My forty six year in the automotive paint business. >> >> >> >> ------------------------------------ >> >> Yahoo! Groups Links >> >> >> >> |
10-28-2010, 23:20
10-29-2010, 01:02
10-29-2010, 02:22
Which of the Dupont paints is it by name?
On 10/29/2010 at 6:02 AM Ron Thompson wrote: >Thanks Lee for your descriptive explanation of the paint codes on 90's >coaches.Ã You are certainly an expert after 46 years in the automotive >paint business. > >The paint that I just bought from Eastx Paint co. here in Houston is a >Dupont, two part paint consisting of the base color paint and a hardener >which mixes with the base color. > >Thanks again. > >Ron Thompson -Waller, Tx. > >1995 WLWB 42' > >(cockyfox@...) > >--- On Thu, 10/28/10, lcondosta > >From: lcondosta >Subject: [WanderlodgeForum] Paint on Wanderlodges >To: WanderlodgeForum@yahoogroups.com >Date: Thursday, October 28, 2010, 7:47 PM > > > > > > > >Ã > > > > > > > > > > Early Wanderlodges where painted with Dupont Imron which is a single >stage polyurethane product which is a long lasting product.I do not know >what year Bluebird went to base coat clear coat but most likely was in the >90s and that was BASF. I know that some where in the late 90s 2000s they >switched to PPG. Most jobbers Dupont,BASF,PPG,SW,SIkkens can be crossed to >the product that the jobber sells but I have always had the best match by >going to the OEM paint that was applied.Dupont,BASF,PPG etc. All have >Color Scaners (Color Camera) which do a good job in matching colors.Base >coats are hard to match with single stage colors it just depends on the >quality of match that you want.Hope this helps. Lee Condosta 85 PT >40 Wilmington NC. Automotive Refinish >Products.BASF(RM,Glasurit)Sikkens,SW Jobber. BASF,Dupont,Sikkens,SW >certified applicator Dupont Certified Commercial applicator. My forty six >year in the automotive paint business. |
