ARO Step control valve
11-14-2010, 07:18
Chuck. I replaced the valve on my 83 PT with Alfa valve from Grainger. Had to make minor change in mounting but easy to install. Hope this helps.
Alfa A2125D 012-D
Flow valve 42J85-1
12volt coil 2G503-2
Paul Downey
Versailles Ky
In a message dated 11/14/2010 6:19:30 P.M. Eastern Standard Time, cwheeler@... writes:
We developed a bad leak in the ARO step control valve during our trip last weekend. The spool valve was easy to rebuild using “O” rings from the faucet section of ACE hardware (3/4” X 1/8” thick - $0.29 each). The problem is that the rubber on the back port of one of the pilot air valves is bad so there is a leak when it is energized. There used to be kits available for these valves but I can’t find any since IR bought ARO.
- Has anyone found any parts to rebuild one of these valves lately?
- Or does any one have an old valve around that I could buy for parts?
- Or, lastly, does anyone have a part number for a valve that would replace the current one? (ARO Part#5840-2929-02)
We head north for the holidays and in very cold weather even a small leak creates problems.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
11-14-2010, 11:19
- Chuck
Wheeler-
11-14-2010, 13:06
We have step control valves
Stephen 97 bmc 37
dupree Procucts
> weekend. The spool valve was easy to rebuild using "O" rings from the
> faucet section of ACE hardware (3/4" X 1/8" thick - $0.29 each). The problem
> these valves but I can't find any since IR bought ARO.
> creates problems.
> - Chuck Wheeler-
11-14-2010, 13:46
Chuck,
I also replaced both the step and generator valves with the A212SD012 valve assembly. Bought them from Stearns Corp. in Houston cost about $120.00, but that was in 2006. I had trouble with one of them and got a repair kit, primarily the spool valve, from Applied Industrial Technologies here in Austin. Cost was $32.00 in 2008. Applied has an office in Dallas (972-506-0612) and Arlington (817-649-3094). Their catalog lists A212SD--- valves, but only in 120 volt and 24 volt. Hope this is of some value to you.
Chet Geist
1981FC33
Austin, Texas
-----Original Message-----
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of antique405@...
Sent: Sunday, November 14, 2010 6:18 PM
Subject: Re: [WanderlodgeForum] ARO Step control valve
Alfa A2125D 012-D
Flow valve 42J85-1
12volt coil 2G503-2
Paul Downey
Versailles Ky
- Chuck Wheeler-
11-14-2010, 14:15
Thanks Paul! I’ll give it a
look. We have a Granger right down the street.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of antique405@...
6:18 PM
Alfa A2125D 012-D
Flow valve 42J85-1
12volt coil 2G503-2
Paul Downey
Versailles Ky
writes:
lately?
parts?
- Chuck Wheeler-
1982 FC 31SB Fort
Worth
TX
11-15-2010, 00:39
I have the same problem. When it is cold, that thing leaks air like crazy. I usually keep the step out till the temps warm up.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sun, 11/14/10, Chuck Wheeler wrote:
Subject: [WanderlodgeForum] ARO Step control valve
Date: Sunday, November 14, 2010, 5:19 PM
- Chuck Wheeler-
11-15-2010, 00:41
Come to think of it, I believe mine leaks out the cylinder.
83PT40
Wanderlodge
--- On Sun, 11/14/10, cape0001 <sbirtles@...> wrote:
Subject: [WanderlodgeForum] Re: ARO Step control valve
Date: Sunday, November 14, 2010, 7:06 PM
Stephen 97 bmc 37
dupree Procucts
> creates problems.
> - Chuck Wheeler-
11-15-2010, 02:34
Ernie,
The cylinder is easy to rebuild. There is
a little shop in Hurst
that has all the seals. I just take the cylinder number to him and he puts
together a “kit”.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie Ekberg
Sent: Monday, November 15, 2010
6:42 AM
83PT40
Wanderlodge
valves
Stephen 97 bmc 37
dupree Procucts
last
from the
each). The problem
bad so
for
replace
leak
> creates problems.
> - Chuck Wheeler-
TX
11-15-2010, 05:39
Thanks, Chuck, I'll get under there and check it out
83PT40
Wanderlodge
--- On Mon, 11/15/10, Chuck Wheeler wrote:
Subject: RE: [WanderlodgeForum] Re: ARO Step control valve
Date: Monday, November 15, 2010, 8:34 AM
Ernie,
The cylinder is easy to rebuild. There is a little shop in Hurst that has all the seals. I just take the cylinder number to him and he puts together a “kit”.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of Ernie Ekberg
Sent: Monday, November 15, 2010 6:42 AM
Subject: Re: [WanderlodgeForum] Re: ARO Step control valve
83PT40
Wanderlodge
Stephen 97 bmc 37
dupree Procucts
> creates problems.
> - Chuck Wheeler-
11-15-2010, 14:46
Stephen,
Do you have more information?
Cost?
Direct
replacement or modification required?
Can it
be rebuilt?
- Chuck
Wheeler-
Behalf Of
cape0001
7:06 PM
To:
Stephen 97 bmc 37
dupree Procucts
--- In "WanderlodgeForum%40yahoogroups.com",
The problem
so
replace
> creates problems.
> - Chuck Wheeler-
TX
