air step repair and troubleshooting
06-22-2005, 11:56
in the interest of the forgoing post,,, before trying anything with
the step,, let all the air pressure off,,, and then, see if you can move the step by hand,, to see if it is jammed,, after that,,, just be careful,,, day jax fla 83 pt-40 In a message dated 6/22/2005 11:30:50 PM Eastern Standard Time, iwhotoo@... writes: > Subj: [WanderlodgeForum] Re: air step repair and troubleshooting > Date:6/22/2005 11:30:50 PM Eastern Standard Time > From:iwhotoo@... > Reply-to:WanderlodgeForum@yahoogroups.com > To:WanderlodgeForum@yahoogroups.com > Received from Internet: > > > > The step is stuck "in" --- 1979 FC35 the air leak is not massive-- > where are the microswitches...thanks Jeff > > MarioBarrios '79FC35 > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > >Running most there is the air ram, two microswitches ('84-on or one > >before '84), an additional lock air-ram ('84-ish), and the air > solenoid. > > > >As there were several configurations of air step controls, it would > be > >helpful to know your year and model, one size doesn't fit all. > > > >It could be that the step is jammed, if it is the version with the > >small lock air-ram under the edge of the doorway that could be > jammed > >and locking the step out. Be careful to keep any part of your body > that > >is important to you away from moving parts, it could suddenly free > up > >and slam open/closed. > > > >More information might help troubleshooting, model/year, and is the > >step stuck out or in? Is there sufficient air pressure? > > > > - Jeff Miller > > > > > >--- In WanderlodgeForum@yahoogroups.com, "iwhotoo" > wrote: > >>My airstep stopped working. When I hit the switch, I hear click > and > >air > >>but no movement. I stopped the engine and I hear air leaking out > of > >the > >>ram. There is a file in archives regarding troubleshooting but it > >seems > >>to be gone. Anyone have that info? > >> > >>Also, what are the two devices mounted under the coach behind the > >step? > >>Seems to be a solenoid and some sort of electric motor and > another > >>large thing that has air lines..anyone? > > > > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > [Non-text portions of this message have been removed] |
06-22-2005, 14:40
My airstep stopped working. When I hit the switch, I hear click and air
but no movement. I stopped the engine and I hear air leaking out of the ram. There is a file in archives regarding troubleshooting but it seems to be gone. Anyone have that info? Also, what are the two devices mounted under the coach behind the step? Seems to be a solenoid and some sort of electric motor and another large thing that has air lines..anyone? |
06-22-2005, 14:56
before '84), an additional lock air-ram ('84-ish), and the air solenoid. As there were several configurations of air step controls, it would be helpful to know your year and model, one size doesn't fit all. It could be that the step is jammed, if it is the version with the small lock air-ram under the edge of the doorway that could be jammed and locking the step out. Be careful to keep any part of your body that is important to you away from moving parts, it could suddenly free up and slam open/closed. More information might help troubleshooting, model/year, and is the step stuck out or in? Is there sufficient air pressure? - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "iwhotoo" > My airstep stopped working. When I hit the switch, I hear click and air > but no movement. I stopped the engine and I hear air leaking out of the > ram. There is a file in archives regarding troubleshooting but it seems > to be gone. Anyone have that info? > > Also, what are the two devices mounted under the coach behind the step? > Seems to be a solenoid and some sort of electric motor and another > large thing that has air lines..anyone? |
06-22-2005, 15:30
where are the microswitches...thanks Jeff MarioBarrios '79FC35 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > Running most there is the air ram, two microswitches ('84-on or one > before '84), an additional lock air-ram ('84-ish), and the air solenoid. > > As there were several configurations of air step controls, it would be > helpful to know your year and model, one size doesn't fit all. > > It could be that the step is jammed, if it is the version with the > small lock air-ram under the edge of the doorway that could be jammed > and locking the step out. Be careful to keep any part of your body that > is important to you away from moving parts, it could suddenly free up > and slam open/closed. > > More information might help troubleshooting, model/year, and is the > step stuck out or in? Is there sufficient air pressure? > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "iwhotoo" wrote: > > My airstep stopped working. When I hit the switch, I hear click and > air > > but no movement. I stopped the engine and I hear air leaking out of > the > > ram. There is a file in archives regarding troubleshooting but it > seems > > to be gone. Anyone have that info? > > > > Also, what are the two devices mounted under the coach behind the > step? > > Seems to be a solenoid and some sort of electric motor and another > > large thing that has air lines..anyone? |
06-22-2005, 23:22
sounds like soapy water is needed to find the leak,first! randydupree93wb
----- Original Message ----- From: iwhotoo To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 22, 2005 11:30 PM Subject: [WanderlodgeForum] Re: air step repair and troubleshooting The step is stuck "in" --- 1979 FC35 the air leak is not massive-- where are the microswitches...thanks Jeff MarioBarrios '79FC35 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > Running most there is the air ram, two microswitches ('84-on or one > before '84), an additional lock air-ram ('84-ish), and the air solenoid. > > As there were several configurations of air step controls, it would be > helpful to know your year and model, one size doesn't fit all. > > It could be that the step is jammed, if it is the version with the > small lock air-ram under the edge of the doorway that could be jammed > and locking the step out. Be careful to keep any part of your body that > is important to you away from moving parts, it could suddenly free up > and slam open/closed. > > More information might help troubleshooting, model/year, and is the > step stuck out or in? Is there sufficient air pressure? > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "iwhotoo" wrote: > > My airstep stopped working. When I hit the switch, I hear click and > air > > but no movement. I stopped the engine and I hear air leaking out of > the > > ram. There is a file in archives regarding troubleshooting but it > seems > > to be gone. Anyone have that info? > > > > Also, what are the two devices mounted under the coach behind the > step? > > Seems to be a solenoid and some sort of electric motor and another > > large thing that has air lines..anyone? ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-23-2005, 14:16
The microswitch (1) on the '79 is under the step, should be open when
the step is all of the way retracted. As far as extending the step, three-way switch wiring between the dash switch and stepwell switch is original, any problem with the wires or either switch will stop the switch from operating. Also check the doorjamb switch, has to be closed for the step to extend, can simply short the wires, ... the switch can be found in Autozone et al in the HELP brand of repair parts. There should also be a relay with a round-pin pattern either in the transfer switch compartment in earlier 'Birds it is on the forward wall of the generator bay. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "iwhotoo" wrote: > The step is stuck "in" --- 1979 FC35 the air leak is not massive-- > where are the microswitches...thanks Jeff > > MarioBarrios '79FC35? |
