shore power switch
03-05-2011, 16:00
shore power switch
i just got a 77 33fc and i cannot find the shore, power generator switch
cannot figure out how to get the shore power hooked up dana |
03-05-2011, 16:26
shore power switch
03-05-2011, 17:43
shore power switch
Hi Dana, Congrats on getting the new to you BB... Look in the step area, on left side as you go up the the steps there is a door that open to the switch... That is if it is the same as mine... HTH Sea YaLarry 84' 35fcsb 'Pura Vida' From: df0226 To: WanderlodgeForum@yahoogroups.com Sent: Sat, March 5, 2011 11:26:36 PM Subject: [WanderlodgeForum] shore power switch i just got a 77 33fc and i cannot find the shore, power generator switch cannot figure out how to get the shore power hooked up dana |
03-05-2011, 18:29
shore power switch
On my 1977 FC31, it is located under the seat nearest the entrance door, of the dining table. At the steps look to your left, and open the carpeted door, there is your transfer switch. From the OFF position, start your gen., after it warms up, turn the switch to Gen. If you are to use shore power, the switch should again be in the OFF position, connect your power cord to your RV, then turn the switch to Shore. I have heard that it is wise to have all appliances etc. turned off before you turn the transfer switch to either the  Gen. or Shore position. Makes sense to me. To shut down the Gen. or disconnect the shore power cord, turn your appliances, lights, etc. off, turn the switch to OFF, then disconnect the power cord, or let the Gen. run a few minutes to cool down, before shutting it down. Good Luck, George Burke 1977 FC31 Charlotte [ P.S. The Shore Power connects on the drivers side, near the rear of the bus.]
On Sat, Mar 5, 2011 at 11:26 PM, df0226 <"df0226@comcast.net"> wrote:
03-06-2011, 05:39
shore power switch
thanks george
found it --- In WanderlodgeForum@yahoogroups.com, George Burke > > On my 1977 FC31, it is located under the seat nearest the entrance door, of > the dining table. At the steps look to your left, and open the carpeted > door, there is your transfer switch. From the OFF position, start your gen., > after it warms up, turn the switch to Gen. If you are to use shore power, > the switch should again be in the OFF position, connect your power cord to > your RV, then turn the switch to Shore. I have heard that it is wise to have > all appliances etc. turned off before you turn the transfer switch to either > the Gen. or Shore position. Makes sense to me. To shut down the Gen. or > disconnect the shore power cord, turn your appliances, lights, etc. off, > turn the switch to OFF, then disconnect the power cord, or let the Gen. run > a few minutes to cool down, before shutting it down. Good Luck, George Burke > 1977 FC31 Charlotte [ P.S. The Shore Power connects on the drivers side, > near the rear of the bus.] > > On Sat, Mar 5, 2011 at 11:26 PM, df0226 > > > > > > > i just got a 77 33fc and i cannot find the shore, power generator switch > > cannot figure out how to get the shore power hooked up > > dana > > > > > > > |
