PARTS
09-19-2011, 10:49
Post: #21
PARTS
09-19-2011, 13:29
Post: #22
PARTS
Ron, Just let me know. Mike McMahan 96 42' Wanderlodge
--- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > Mike, I do want the Rock Guard.à I am running right now with the mudflaps on the tag axle.à But need that Rock Guard to provide some protection for my Jeep tow vehicle.à I am sort of tied up right at the moment trying to get a metal building bought.à I will get back with you in a couple of days to set up a time to come get the rock guard if that is ok with you.à I sure thank you for putting that notice out there on the forum. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Mon, 9/19/11, Mike <mmcmahan1952@...> wrote: > > From: Mike <mmcmahan1952@...> > Subject: [WanderlodgeForum] Re: Parts > To: WanderlodgeForum@yahoogroups.com > Date: Monday, September 19, 2011, 2:43 PM > > > > > > > > > > > > > > > > > à > > > > > > > > > > Ron, I do still have the rockguard if yo want it. It is not one that says wanderlodge on it but it looks ok and worked ok. I am in Waco. Mike > > > > --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > > > > Mike, > > > Do you still have that RockGuard.Ãâà I have a 1995 42' Wide Body Wanderlodge and need a Rock Guard.Ãâà Mine was damaged on a high spot while turning around in a very tight place.Ãâà I am in Waller Texas which is a small town northwest of Houston out about 35 miles on Hwy 290 Expressway. > > > > > > Where are you located if you still have the RockGuard? > > > > > > > > > Ron Thompson -Waller, Tx. > > > > > > 1995 WLWB 42' > > > > > > (cockyfox@) > > > > > > --- On Mon, 9/19/11, carmart@ > > > > > > From: carmart@ > > > Subject: Re: [WanderlodgeForum] Parts > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Monday, September 19, 2011, 8:39 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I don't have the rockguard but I am parting out a 1992 model if you need anything elseSent via BlackBerry by AT&TFrom: "Mike" <mmcmahan1952@> > > > Sender: WanderlodgeForum@yahoogroups.com > > > Date: Mon, 19 Sep 2011 13:34:59 -0000To: > > > Subject: [WanderlodgeForum] Parts > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > Barbara and I may be attending the LSB Rally at the end of the month. I have one of the rear rock guards that go all the way across the back of a Bluebird that someone could have. Also have 8V92 air filter that I wold like to sell. It is in Waco and anyone coming thru here can pick it up. May have some other items also. Will post other items later. Mike McMahan 96 42' Wanderlodge > > > > |
09-19-2011, 13:31
Post: #23
PARTS
I also found one Bluebird rear mud flap and a lubrifiner filter for anyone
interested. Got some more stuff but lost my list. Look for it tomorrow. Mike McMahan 96 42' Wanderlodge --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > Mike, I do want the Rock Guard.à I am running right now with the mudflaps on the tag axle.à But need that Rock Guard to provide some protection for my Jeep tow vehicle.à I am sort of tied up right at the moment trying to get a metal building bought.à I will get back with you in a couple of days to set up a time to come get the rock guard if that is ok with you.à I sure thank you for putting that notice out there on the forum. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Mon, 9/19/11, Mike <mmcmahan1952@...> wrote: > > From: Mike <mmcmahan1952@...> > Subject: [WanderlodgeForum] Re: Parts > To: WanderlodgeForum@yahoogroups.com > Date: Monday, September 19, 2011, 2:43 PM > > > > > > > > > > > > > > > > > à > > > > > > > > > > Ron, I do still have the rockguard if yo want it. It is not one that says wanderlodge on it but it looks ok and worked ok. I am in Waco. Mike > > > > --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > > > > Mike, > > > Do you still have that RockGuard.Ãâà I have a 1995 42' Wide Body Wanderlodge and need a Rock Guard.Ãâà Mine was damaged on a high spot while turning around in a very tight place.Ãâà I am in Waller Texas which is a small town northwest of Houston out about 35 miles on Hwy 290 Expressway. > > > > > > Where are you located if you still have the RockGuard? > > > > > > > > > Ron Thompson -Waller, Tx. > > > > > > 1995 WLWB 42' > > > > > > (cockyfox@) > > > > > > --- On Mon, 9/19/11, carmart@ > > > > > > From: carmart@ > > > Subject: Re: [WanderlodgeForum] Parts > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Monday, September 19, 2011, 8:39 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I don't have the rockguard but I am parting out a 1992 model if you need anything elseSent via BlackBerry by AT&TFrom: "Mike" <mmcmahan1952@> > > > Sender: WanderlodgeForum@yahoogroups.com > > > Date: Mon, 19 Sep 2011 13:34:59 -0000To: > > > Subject: [WanderlodgeForum] Parts > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > Barbara and I may be attending the LSB Rally at the end of the month. I have one of the rear rock guards that go all the way across the back of a Bluebird that someone could have. Also have 8V92 air filter that I wold like to sell. It is in Waco and anyone coming thru here can pick it up. May have some other items also. Will post other items later. Mike McMahan 96 42' Wanderlodge > > > > |
09-19-2011, 15:38
Post: #24
PARTS
Greetings to all,
I'm needing both shower faucet screw-in "cartridges" for a 1991 WL PT40 - walk-through bath. Plumbing supply sources list literally hundreds of different styles, bur are unable to positively identify the manufacturer or model of mine. Does anyone have good ones or can offer a source?
Regards,
Donn Borden
Ronan, MT
09-20-2011, 00:34
Post: #25
PARTS
Try Moen
Fred & Jeanne Hulse Morristown,Arizona 97 WLWB41 |
09-20-2011, 01:33
Post: #26
PARTS
As Fred said, it is a Moen. One added note: My 91 required a good cartridge puller to get the old one out. Was able to borrow one from the Ace Hardware store were I got the replacement insert cartridge. If you have not done this before, there is a helpful video on UTube. Search on Moen shower cartridge replacement. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone
On Sep 20, 2011, at 7:34 AM, "Fred Hulse" <"fhulse@wildblue.net"> wrote:
09-20-2011, 01:37
Post: #27
PARTS
My 91 was Moen. Once I removed the parts I was able to identify the correct replacements from Moen's web site which had diagrams of the various faucets and parts.
Roger Webb
91 WL
Cedar Rapids, IA
Mooresville, NC
RWW
-----Original Message----- From: PDMcCripe To: WanderlodgeForum Sent: Tue, Sep 20, 2011 3:31 am Subject: [WanderlodgeForum] Parts Greetings to all,
Regards,
Donn Borden
Ronan, MT
09-21-2011, 13:21
Post: #28
PARTS
I've gotten lost here, Who is parting out the 92 model? Thanks Don
---------- Original Message ---------- From: "Mike" <mmcmahan1952@...> To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Parts Date: Tue, 20 Sep 2011 01:31:37 -0000 I also found one Bluebird rear mud flap and a lubrifiner filter for anyone interested. Got some more stuff but lost my list. Look for it tomorrow. Mike McMahan 96 42' Wanderlodge --- In "WanderlodgeForum%40yahoogroups.com", Ron Thompson > > > Mike, I do want the Rock Guard.à I am running right now with the mudflaps on the tag axle.à But need that Rock Guard to provide some protection for my Jeep tow vehicle.à I am sort of tied up right at the moment trying to get a metal building bought.à I will get back with you in a couple of days to set up a time to come get the rock guard if that is ok with you.à I sure thank you for putting that notice out there on the forum. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Mon, 9/19/11, Mike <mmcmahan1952@...> wrote: > > From: Mike <mmcmahan1952@...> > Subject: [WanderlodgeForum] Re: Parts > To: "WanderlodgeForum%40yahoogroups.com" > Date: Monday, September 19, 2011, 2:43 PM > > > > > > > > > > > > > > > > > à > > > > > > > > > > Ron, I do still have the rockguard if yo want it. It is not one that says wanderlodge on it but it looks ok and worked ok. I am in Waco. Mike > > > > --- In "WanderlodgeForum%40yahoogroups.com", Ron Thompson > > > > > > Mike, > > > Do you still have that RockGuard.Ãâà I have a 1995 42' Wide Body Wanderlodge and need a Rock Guard.Ãâà Mine was damaged on a high spot while turning around in a very tight place.Ãâà I am in Waller Texas which is a small town northwest of Houston out about 35 miles on Hwy 290 Expressway. > > > > > > Where are you located if you still have the RockGuard? > > > > > > > > > Ron Thompson -Waller, Tx. > > > > > > 1995 WLWB 42' > > > > > > (cockyfox@) > > > > > > --- On Mon, 9/19/11, carmart@ > > > > > > From: carmart@ > > > Subject: Re: [WanderlodgeForum] Parts > > > To: "WanderlodgeForum%40yahoogroups.com" > > > Date: Monday, September 19, 2011, 8:39 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I don't have the rockguard but I am parting out a 1992 model if you need anything elseSent via BlackBerry by AT&TFrom: "Mike" <mmcmahan1952@> > > > Sender: "WanderlodgeForum%40yahoogroups.com" > > > Date: Mon, 19 Sep 2011 13:34:59 -0000To: <"WanderlodgeForum%40yahoogroups.com">ReplyTo: "WanderlodgeForum%40yahoogroups.com" > > > Subject: [WanderlodgeForum] Parts > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > Barbara and I may be attending the LSB Rally at the end of the month. I have one of the rear rock guards that go all the way across the back of a Bluebird that someone could have. Also have 8V92 air filter that I wold like to sell. It is in Waco and anyone coming thru here can pick it up. May have some other items also. Will post other items later. Mike McMahan 96 42' Wanderlodge > > > > ____________________________________________________________ Penny Stock Jumping 3000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com |
09-21-2011, 14:13
Post: #29
PARTS
I am parting out a 92 40 ft Sent via BlackBerry by AT&T From: "catfish_bartlett@..." Date: Thu, 22 Sep 2011 01:21:16 GMT To: Subject: Re: [WanderlodgeForum] Re: Parts I've gotten lost here, Who is parting out the 92 model? Thanks Don ---------- Original Message ---------- From: "Mike" <mmcmahan1952@...> To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Parts Date: Tue, 20 Sep 2011 01:31:37 -0000 I also found one Bluebird rear mud flap and a lubrifiner filter for anyone interested. Got some more stuff but lost my list. Look for it tomorrow. Mike McMahan 96 42' Wanderlodge --- In "WanderlodgeForum%40yahoogroups.com", Ron Thompson > > > Mike, I do want the Rock Guard.à I am running right now with the mudflaps on the tag axle.à But need that Rock Guard to provide some protection for my Jeep tow vehicle.à I am sort of tied up right at the moment trying to get a metal building bought.à I will get back with you in a couple of days to set up a time to come get the rock guard if that is ok with you.à I sure thank you for putting that notice out there on the forum. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Mon, 9/19/11, Mike <mmcmahan1952@...> wrote: > > From: Mike <mmcmahan1952@...> > Subject: [WanderlodgeForum] Re: Parts > To: "WanderlodgeForum%40yahoogroups.com" > Date: Monday, September 19, 2011, 2:43 PM > > > > > > > > > > > > > > > > > à > > > > > > > > > > Ron, I do still have the rockguard if yo want it. It is not one that says wanderlodge on it but it looks ok and worked ok. I am in Waco. Mike > > > > --- In "WanderlodgeForum%40yahoogroups.com", Ron Thompson > > > > > > Mike, > > > Do you still have that RockGuard.Ãâà I have a 1995 42' Wide Body Wanderlodge and need a Rock Guard.Ãâà Mine was damaged on a high spot while turning around in a very tight place.Ãâà I am in Waller Texas which is a small town northwest of Houston out about 35 miles on Hwy 290 Expressway. > > > > > > Where are you located if you still have the RockGuard? > > > > > > > > > Ron Thompson -Waller, Tx. > > > > > > 1995 WLWB 42' > > > > > > (cockyfox@) > > > > > > --- On Mon, 9/19/11, carmart@ > > > > > > From: carmart@ > > > Subject: Re: [WanderlodgeForum] Parts > > > To: "WanderlodgeForum%40yahoogroups.com" > > > Date: Monday, September 19, 2011, 8:39 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I don't have the rockguard but I am parting out a 1992 model if you need anything elseSent via BlackBerry by AT&TFrom: "Mike" <mmcmahan1952@> > > > Sender: "WanderlodgeForum%40yahoogroups.com" > > > Date: Mon, 19 Sep 2011 13:34:59 -0000To: <"WanderlodgeForum%40yahoogroups.com">ReplyTo: "WanderlodgeForum%40yahoogroups.com" > > > Subject: [WanderlodgeForum] Parts > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > Barbara and I may be attending the LSB Rally at the end of the month. I have one of the rear rock guards that go all the way across the back of a Bluebird that someone could have. Also have 8V92 air filter that I wold like to sell. It is in Waco and anyone coming thru here can pick it up. May have some other items also. Will post other items later. Mike McMahan 96 42' Wanderlodge > > > > ____________________________________________________________ Penny Stock Jumping 3000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com |
09-26-2011, 02:52
Post: #30
PARTS
Ron, Email me your phone or email. Thanks, Mike McMahan mmcmahan1952@...
