shore power
10-09-2011, 16:28
shore power
Im a neebie with a fc33 problem.
I turned the switch to shore power, plugged in the power cord, turned on the breakers. All the 110 accessories work but it appears there is no converted power (12 volt) to any of the 12 volt accessories, interior lights etc. The voltmeter on the wall only reads 20? volts and the batteries go dead. The generator was removed before I got the coach so I dont know what was disconnected in the removal, but where should I go looking for the problem? I am a certified mechanic from the 80's but I seem to be lost on where to begin looking and the bluebird manual is sorely lacking on any information for repairs. Does anybody sell a repair manual or information for repairs on the Wanderlodges? dana fransen w/ BOB (the big ol bus)fc33 valley springs ca 40 miles east of stocton |
10-09-2011, 16:54
shore power
10-09-2011, 22:58
shore power
So lets break this down logically. If you have 120 power off shore and that is working fine, you are good there. Generator is just an alternate source for 120/shore power, so disconnecting that shouldn't be of any concern right now. Your 12 volt system is separate, and if you say the batteries go dead you have an issue there somewhere. The only connection between 120 and 12 volt should be battery chargers of some sort that take 120 power to keep your batteries charged. I'd start there to see what you have going on, is the charger turned on, is it working, etc.
Markus To: WanderlodgeForum@yahoogroups.com From: df0226@... Date: Mon, 10 Oct 2011 04:28:03 +0000 Subject: [WanderlodgeForum] shore power
10-10-2011, 03:17
shore power
Great start, here is just a little more info: You likely have two batteries -- an engine and a house battery. I presume we are discussing the house. Your 12VDC house system should have one master switch, most loads are connected after the master relay. You probably also have one disconnect switch, a few loads [like refer] connect after disconnect and before master. The master on my BMC37 is next to the entry door, the disconnect is in the battery compartment. The charger is normally wired directly to the battery so it works even with the disconnect switch open. Instruments like the voltmeter on the wall might be wired anywhere... I am a bit worried by your 20V reading, it doesn't match any normal reading for either 12 or 120 or 240 system. Please get yourself an inexpensive hand held volt meter for diagnostics, leave the wall meter for monitoring. Start with the disconnect [and master] switched OFF. It is good practice to verify connections are tight, clean, dry, no trace of white [or green] corrosion. Healthy no-load DC voltages are APPROXIMATELY like: 14.2VDC peak charge current to a healthy battery 13.8VDC float [or trickle] charge to maintain a full charge on the battery 12.5VDC full charge battery after charger turned off for days 11.5VDC mostly discharged in a normal cycle of use 10.5 or less // a really dead battery without a charger connected A dead battery will not take many repetitions of re-charge, try to keep the battery above 11.5VDC to extend it's life of service. If a dead battery takes re-charge and maintains 12.5VDC for a day after charging at no-load it may be a good battery. If a dead battery takes some recharge current, and maintains some voltage after a day of no-charging, then some cells are good. After a day without charging, turn on the disconnect and master and a few lights -- do NOT turn on big loads like an inverter. If the battery voltage under light load [without the charger running] does not dip below 12.25VDC there is some hope for the battery... Have a great hunt. Skip On 10/10/2011 06:58 AM, Markus Meyer wrote:  |
10-10-2011, 14:48
shore power
Dana I have a 33fc give me a call I can help you figure this out.
buster80wl
"lakelandcouch@yahoo.com"
dave krolick
612 418 2926 |
10-10-2011, 15:26
shore power
Great offer! For those that don't know, Dave also re-models Birds and other RVs so this is a double great offer IMO. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone
On Oct 10, 2011, at 9:48 PM, Dave Krolick <"buster80wl@yahoo.com"> wrote:
10-12-2011, 13:28
shore power
Thanks Mike for the intro. Im moving into a larger building the 1st nov.so I can handel more than one couch at a time. I have in door and outside storage for those that want to have work
done in the midwest.
buster80wl
"lakelandcoach@yahoo.com"
.dave krolick
612 418 2926 |
