Need recommendations in San Antonio area
06-21-2012, 07:03
Hello,
I live in San Antonio and my 85 PT40 seems to have an electrical/starting issue. It worked fine until parked....when I turn the key, the dash lights dim and the motor doesn't turn over. I'm thinking it may be a starter issue but would like to have someone local to San Antonio take a look so I don't burn it up..... Who would you recommend locally to take a look at it. I would prefer a house call so I don't have to have it towed off my property. Thanks. Jerry 85PT40 |
06-21-2012, 07:17
06-21-2012, 07:32
And also all the ground strap connections in the engine compartment.
Which area of SA are you in? I'm near Boerne. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > clean your battery cables, first > > > Ernie Ekberg > 88 PT40 Wanderlodge > Weatherford, Texas > 817-475-3991 > http://www.ernieekbergflooring.net > > --- On Thu, 6/21/12, jburgessx2 > > > From: jburgessx2 > Subject: [WanderlodgeForum] Need recommendations in San Antonio area > To: WanderlodgeForum@yahoogroups.com > Date: Thursday, June 21, 2012, 2:03 PM > > > > Ã > > > > Hello, > > I live in San Antonio and my 85 PT40 seems to have an electrical/starting issue. It worked fine until parked....when I turn the key, the dash lights dim and the motor doesn't turn over. I'm thinking it may be a starter issue but would like to have someone local to San Antonio take a look so I don't burn it up..... > > Who would you recommend locally to take a look at it. I would prefer a house call so I don't have to have it towed off my property. > > Thanks. > > Jerry > 85PT40 > |
06-21-2012, 07:53
Sounds like a loose ground wire.
-----Original Message-----
From: jburgessx2 To: WanderlodgeForum Sent: Thu, Jun 21, 2012 2:03 pm Subject: [WanderlodgeForum] Need recommendations in San Antonio area Hello,
06-21-2012, 08:00
I agree that cables/grounds are quite likely, but I would point out that the
symptoms also match low-battery levels. On 6/21/2012 at 3:53 PM Elliot wrote: >Sounds like a loose ground wire. > > > >-----Original Message----- >From: jburgessx2 >To: WanderlodgeForum >Sent: Thu, Jun 21, 2012 2:03 pm >Subject: [WanderlodgeForum] Need recommendations in San Antonio area > > > > >Hello, > >I live in San Antonio and my 85 PT40 seems to have an electrical/starting >issue. It worked fine until parked....when I turn the key, the dash lights >dim and the motor doesn't turn over. I'm thinking it may be a starter >issue but would like to have someone local to San Antonio take a look so I >don't burn it up..... > >Who would you recommend locally to take a look at it. I would prefer a >house call so I don't have to have it towed off my property. > >Thanks. > >Jerry >85PT40 |
06-21-2012, 08:07
Mike,
I'm in Thousand Oaks area (1604 and Red Land Rd).
I appreciate everyones comments. I will check the battery connections and ground wires. How many ground strap connections are in the engine compartment?
Jerry
85PT40
From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 21, 2012 2:32 PM Subject: [WanderlodgeForum] Re: Need recommendations in San Antonio area And also all the ground strap connections in the engine compartment. Which area of SA are you in? I'm near Boerne. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg > > clean your battery cables, first > > > Ernie Ekberg > 88 PT40 Wanderlodge > Weatherford, Texas > 817-475-3991 > http://www.ernieekbergflooring.net/ > > --- On Thu, 6/21/12, jburgessx2 > > > From: jburgessx2 > Subject: [WanderlodgeForum] Need recommendations in San Antonio area > To: "WanderlodgeForum%40yahoogroups.com" > Date: Thursday, June 21, 2012, 2:03 PM > > > > Ãâ > > > > Hello, > > I live in San Antonio and my 85 PT40 seems to have an electrical/starting issue. It worked fine until parked....when I turn the key, the dash lights dim and the motor doesn't turn over. I'm thinking it may be a starter issue but would like to have someone local to San Antonio take a look so I don't burn it up..... > > Who would you recommend locally to take a look at it. I would prefer a house call so I don't have to have it towed off my property. > > Thanks. > > Jerry > 85PT40 > |
06-21-2012, 08:40
My plus cables go to one terminal and that nut works loose and can make it do that
Connected by DROID on Verizon Wireless -----Original message-----
07-20-2012, 02:01
Good morning,
As usual, I haven't had much time to troubleshoot lately but I did manage to do some and isolate the problem I cleaned and tightened all the ground straps I could find including the one from the starter. And, I installed new 6volt batteries to ensure clean power.
I spoke with Mike Mulbriss and he recommended trying to start the coach from the rear start. I'm not sure why I didn't think of that........ But, I finally found the key (on a spare ring) and switched to "rear start" and she fired right up without hesitation. So.....it's not a starter problem like I thought. Mike also suggested checking the solenoid "clicks" from the front overhead. When I turn the front start, the solenoids do click but nothing else happens. I did get into the overhead and checked all the cable connections behind the rubber curtain and all seems well.
So, I can start it from the rear but I still can't start it from the front. Also, I've noticed that the batteries are drained if I leave them hooked up. I have searched the coach over and can't seem to find any lights on, frig, or anything else that would be drawing power.
What should I check next? What could be draining my batteries? Is it the ignition switch?
As always, I appreciate the help and assistance of you all.
Jerry
85 PT40
From: Jerry Burgess To: "WanderlodgeForum@yahoogroups.com" Sent: Thursday, June 21, 2012 3:07 PM Subject: Re: [WanderlodgeForum] Re: Need recommendations in San Antonio area Mike,
Jerry
85PT40
07-20-2012, 02:08
Jerry,
Are you a relatively new owner? When I first purchased mine, I wasn't aware there are always drains on the batteries - too many things going - quite complex. I too got new batteries when I first bought mine, and they were dead after about 4-5 days. Bottom line - need to either keep them charged/plugged in, or have a master disconnect/shutoff switch and turn it off it parked for more than a few days. Markus 86 PT40 To: WanderlodgeForum@yahoogroups.com From: jburgessx2@... Date: Fri, 20 Jul 2012 07:01:59 -0700 Subject: Re: [WanderlodgeForum] Re: Need recommendations in San Antonio area Good morning,
Jerry
85 PT40
Jerry
85PT40
From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 21, 2012 2:32 PM Subject: [WanderlodgeForum] Re: Need recommendations in San Antonio area And also all the ground strap connections in the engine compartment. Which area of SA are you in? I'm near Boerne. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg > > clean your battery cables, first > > > Ernie Ekberg > 88 PT40 Wanderlodge > Weatherford, Texas > 817-475-3991 > http://www.ernieekbergflooring.net/ > > --- On Thu, 6/21/12, jburgessx2 > > > From: jburgessx2 > Subject: [WanderlodgeForum] Need recommendations in San Antonio area > To: "WanderlodgeForum%40yahoogroups.com" > Date: Thursday, June 21, 2012, 2:03 PM > > > > Ã > > > > Hello, > > I live in San Antonio and my 85 PT40 seems to have an electrical/starting issue. It worked fine until parked....when I turn the key, the dash lights dim and the motor doesn't turn over. I'm thinking it may be a starter issue but would like to have someone local to San Antonio take a look so I don't burn it up..... > > Who would you recommend locally to take a look at it. I would prefer a house call so I don't have to have it towed off my property. > > Thanks. > > Jerry > 85PT40 > |
07-20-2012, 02:13
Markus,
No, I've owned for quite some time. In fact, we lived full time for years and only moved into a house last fall. So, the coach was always running down the road, on the genny, or hooked to shore power. As such, I've never had the thing just parked without power - I didn't know it would drain on it's own. But, I do now
![]() Jerry
85 PT40
From: Markus Meyer To: wanderlodgeforum@yahoogroups.com Sent: Friday, July 20, 2012 9:08 AM Subject: RE: [WanderlodgeForum] Re: Need recommendations in San Antonio area Jerry, Are you a relatively new owner? When I first purchased mine, I wasn't aware there are always drains on the batteries - too many things going - quite complex. I too got new batteries when I first bought mine, and they were dead after about 4-5 days. Bottom line - need to either keep them charged/plugged in, or have a master disconnect/shutoff switch and turn it off it parked for more than a few days.
Markus 86 PT40
Jerry
85 PT40
Jerry
85PT40
