Excessive oil useage.
07-05-2005, 07:06
Anyone know any reason (other than bad rings) why a Cat 3208 with 87k
on it would use excessive amounts of oil (4qts in 900 miles).
07-05-2005, 07:28
Check the fill plugs on both valve covers for tightness. If there is no
leaks, skip this check.
dandarst86fc35rbhuntleyil.
>From: "williamcharrison"
>Subject: [WanderlodgeForum] Excessive oil useage.
>Date: Tue, 05 Jul 2005 19:06:13 -0000
07-05-2005, 08:45
How about some more information first. Are you leaking oil anyplace, rear
main seal, valve covers, positive crankcase vent on the valve covers?
tom
1982 FC35
Vernon Center,NY
>Yahoo! Groups Links
07-05-2005, 11:54
dirty air filter is one,leaks are another. not trying to be smart about it,but
do you have any more info? did it just start using oil,did you just change the
oil? etc..randy93wb
Sent: Tuesday, July 05, 2005 3:06 PM
YAHOO! GROUPS LINKS
07-05-2005, 13:28
Could be your over filling the oil, most diesel engine will blow
out the extra oil, your better of running a quart or two low then to
over fill. When you change oil put in the 20 quarts, this includs the
filler, then check the dip stick, (the dip stick could be off)it
should be close to full, if the dip stick shows low, then your dip
stick is off.
David Thompson 89 fc- Cameron Wi
about it,but do you have any more info? did it just start using
oil,did you just change the oil? etc..randy93wb
> From: williamcharrison
> YAHOO! GROUPS LINKS
Service.
07-05-2005, 13:37
--- In WanderlodgeForum@yahoogroups.com, "David Thompson"
to
> stick is off.
with 87k
> > I didnt notice if you mentioned if the 3208 was turbo charged or
not, if it is a bad seal in the turbo will put a lot of oil through
the engine.
Dick & Carolyn sevey 83fc 33 Pahrump, Nv.
> > YAHOO! GROUPS LINKS
Terms of
> Service.
07-05-2005, 20:55
I recently changed the oil in our generator. After a short trip of about 40
miles I checked the oil and found it to be about a pint low. I apparently left
the washer off of the drain plug (probably in old oil). New washer--no
leaks. Put a piece of cardboard under your engine to see if you have an oil
leak.
Bill & Rita in Roanoke, VA
1987 FC-35
07-06-2005, 01:55
Thanks for your time Tom,
There are no leaks that I can see. It does blow some blue smoke
when the engine is revved up after starting but only on the way up
the rpm range. There is a ~ 1" breather? hose below the engine that
blows oil vapor when the engine is hot.
several seconds In WanderlodgeForum@yahoogroups.com, Tom Warner
anyplace, rear
covers?
> tom
> 1982 FC35
> Vernon Center,NY
87k
> >Yahoo! Groups Links
07-06-2005, 02:08
I just got the coach 2 months ago. I did change the air filter
and the oil was changed the day I picked it up (along with the oil
filters). Since I am a diesel rookie I didn't notice anything but
what I considered excessive black exhaust smoke under heavy loads.
--- In WanderlodgeForum@yahoogroups.com, randydupree
with 87k
> YAHOO! GROUPS LINKS
of Service.
07-06-2005, 02:11
Thanks for your time Richard and Carol,
Yes it is turbo charged. How can I tell if it is the turbo seal?
-- In WanderlodgeForum@yahoogroups.com, "Richard Sevey & Carolyn
blow
then
> to
includs
> the
dip
> > stick is off.
smart
> with 87k
or
through
> the engine.
> > > YAHOO! GROUPS LINKS
> Terms of
> > Service.
