Webasto Control Panel
12-12-2013, 10:17
I have a '06 Wanderlodge 450Lxi that I can not locate the control panel on the Webasto heating system. It will not fire up and if I could find the panel then I am hoping there will be a fault code? Any suggestions
12-12-2013, 10:49
RE: Webasto Control Panel
(12-12-2013 10:17)Peter Amos Wrote: I have a '06 Wanderlodge 450Lxi that I can not locate the control panel on the Webasto heating system. It will not fire up and if I could find the panel then I am hoping there will be a fault code? Any suggestions I'm not a 450 guy and I'm sure one will be along,but I would suggest you make sure you have at least a half tank of fuel. The fuel pickups for the genny and Webasco are higher in the tank by design and it the easiest thing to do first ![]() Pete and Donna Chin 95 42' WLWB On The Road Always! :-) " We'll raise up our glasses against evil forces singing, Whiskey for my men, and beer for my horses!"-Toby Keith & Willie Nelson - The bridge from Toby Keith's title album track "beer for my horses" |
12-12-2013, 12:24
(This post was last modified: 12-12-2013 13:09 by dentmac.)
Hi,
The description in the manual is not for the unit. It also describes a separate fluid fill and lights on the control panel . Never found the panel. The fluid in the system is part of engine antifreeze/cooling system. I have run the webasto with less then 1/4 tank but perhaps that is my unit only. Ross (12-12-2013 10:17)Peter Amos Wrote: I have a '06 Wanderlodge 450Lxi that I can not locate the control panel on the Webasto heating system. It will not fire up and if I could find the panel then I am hoping there will be a fault code? Any suggestions Ross MacKillop Wiarton Ontario 2006 450 Lxi |
12-13-2013, 12:57
Hi,
Here are the schematics. Now just to find the control module! R (12-12-2013 10:17)Peter Amos Wrote: I have a '06 Wanderlodge 450Lxi that I can not locate the control panel on the Webasto heating system. It will not fire up and if I could find the panel then I am hoping there will be a fault code? Any suggestions [/quote] Ross MacKillop Wiarton Ontario 2006 450 Lxi |
12-14-2013, 10:35
(This post was last modified: 12-14-2013 10:36 by Hisham Amaral.)
Mr. Amos
The fuse for the Webasto is in bay two street side the big gray box. You have to unscrew the front cover and at the right end you will see the fuses marked Webasto one of these fuses may have burned out on you. They are 24 volts and marked as such. Good luck Hish Hisham and Sue Amaral 2004 Prevost XL2 Marathon (sold) 2003 Liberty H3-45 2 slide Titusville, Florida 248-935-5390 |
12-16-2013, 13:38
Did you solve the problem and find the controls?
01-21-2014, 10:21
(12-14-2013 10:35)Hisham Amaral Wrote: Mr. AmosThanks for the response and I apologize for being a while in getting back with you. We have just been able to get back on this. I am in the process now of locating the fuses. The control panel is still MIA, but we will locate it. Thanks and I will let you know as soon as we get it. Don |
01-22-2014, 01:44
(01-21-2014 10:21)Peter Amos Wrote:(12-14-2013 10:35)Hisham Amaral Wrote: Mr. AmosThanks for the response and I apologize for being a while in getting back with you. We have just been able to get back on this. I am in the process now of locating the fuses. The control panel is still MIA, but we will locate it. Try the 3rd bay curb side center of the bay . The webasto unit is inside the sheet metal |
