Snowbird?
07-20-2005, 08:08
Snowbird?
Michael, Tom Meservey spent the winter in Ohio. perhaps he will post on his
experiences. Ernie- 83pt 40 in Montana [Non-text portions of this message have been removed] |
07-20-2005, 11:34
Snowbird?
I'm still contemplating a Wanderlodge purchase. Currently have my eye
on a 1980 model. Maybe this is a weird question while people's ACs are pooping out at 103F, but does anyone on the list have significant experience in their machine (boondocking or with hookups) in the winter. Are Wanderlodges better than other RVs in the heat department as in almost every other consideration? We may need to spend a good bit of this winter in PA and IN and in between. Has your parked coach heat been adequate? How much does it cost to heat it? I figure once I have water in the lines I shouldn't let anything get near freezing. If you have to be away for awhile, can you set the thermostat at 40 and be safe from bursting pipes, or does it need to be higher than that? Michael |
07-20-2005, 13:07
Snowbird?
I installed a diesel boiler in my front curbside compartment, very convenient to
the heater hoses. I chose a ProHeat but there are other brands on the market. The boiler keeps the chassis heaters working well but extensive dry camping would be a stretch in the winter, birds need lots of electric power. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: Michael Geurink To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 20, 2005 6:34 PM Subject: [WanderlodgeForum] Snowbird? I'm still contemplating a Wanderlodge purchase. Currently have my eye on a 1980 model. Maybe this is a weird question while people's ACs are pooping out at 103F, but does anyone on the list have significant experience in their machine (boondocking or with hookups) in the winter. Are Wanderlodges better than other RVs in the heat department as in almost every other consideration? We may need to spend a good bit of this winter in PA and IN and in between. Has your parked coach heat been adequate? How much does it cost to heat it? I figure once I have water in the lines I shouldn't let anything get near freezing. If you have to be away for awhile, can you set the thermostat at 40 and be safe from bursting pipes, or does it need to be higher than that? Michael ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
