WaGu Browsing Performance Issues
04-10-2015, 19:05
Post: #21
RE: WaGu Browsing Performance Issues
David, something happened, positive. Much better, thank you. I sent you a link to whatever you asked for.
04-11-2015, 11:25 (This post was last modified: 04-11-2015 11:36 by davidbrady.)
Post: #22
(04-10-2015 19:05)ernie ekberg Wrote:  David, something happened, positive. Much better, thank you. I sent you a link to whatever you asked for.
Thanks Ernie. I'm happy to hear that at least some of the woes are behind us; I haven't thrown in the towel yet! I got your http://www.webpagetest.org results. This particular test actually looks okay. There's an 8 second delay to negotiate the SSL Certificate, but that's probably because it was the initial test and the certificate wasn't cached. A repeat test should show an improvement in speed. Thanks for the data.
Thanks Chuck and Randy for your data. First view of around 2s and repeat view of around 1s is pretty standard and is what I also tend to see. Looking good! Smile
04-11-2015, 12:47
Post: #23
Just to experiment a little I got rid of the googe SEO (search engine optimization) which eliminates all those time consuming rewrite rules and I moved us from https back to http which eliminates the time consuming SSL certificate negotiation. Let's run like this for a while to see if it's an improvement. From my latest http://www.webpagetest.org output it looks like things are quite fast with these new settings: İmage
04-21-2015, 09:07
Post: #24
For the last week, I have had major problems with the site, but this morning everything works well, thanks for whatever you did.
04-21-2015, 10:46
Post: #25
Thanks Steve, I appreciate the feedback. Turns out I did make a change yesterday. I had to reinstall our google seo (search engine optimization) to get our google custom site search working again. This change could certainly have had an effect on WaGu performance. We'll run like this for a while and see how it goes. Folks, please keep me informed if you're having issues. Thanks!
04-21-2015, 23:25
Post: #26
When I was having troubles getting on, I could not send a message. I did try sending smoke signals and calling.
04-25-2015, 23:00
Post: #27
Been doing some more performance tweeks. Let me know if you're having problems: dmb993@earthlink.net
04-26-2015, 10:34
Post: #28
Sorry folks, a little outage there as I backed up the database.
04-26-2015, 20:50
Post: #29
A LARGE improvement. Thank you, sir
04-27-2015, 10:06 (This post was last modified: 04-27-2015 13:08 by davidbrady.)
Post: #30
(04-26-2015 20:50)erniecarpet Wrote:  A LARGE improvement. Thank you, sir
This is not quite fixed. Both patticake and erniecarpet are having issues. Turns out both typically connect to WaGu over a Verizon Hotspot. If any of you do the same then you're probably having WaGu connection issues too. I can reproduce the problem on my PC using my Android HTC1 Verizon phone with the Hotspot enabled. Sometimes the page loads without a problem, sometimes it spins, sometimes it times-out with the message that I've attached. I can connect to other websites with no issues. Now I can play with it till I figure out a fix. First up is a call to Verizon. Thanks.
