1982 FC35SB @ Craig's List 05-07-16
05-09-2016, 16:56
F.Y.I.
http://phoenix.craigslist.org/wvl/rvs/5575628644.html 23 Pictures, Cream, Brown & Beige. 40K Miles - Rebuilt. Swing-out Radiator. $12.5K. Near Phoenix, AZ. "All original 82 Wanderlodge by Bluebird Bus Company. 35 feet long front engine. This one has most every option available at the time including the swing-out radiator, air horns, musical horns, security system, built-in safe, 3 roof air conditioner units as well as original cab a/c, aqua hot system, full walk on roof diamond plate, goat rail, elect. spotlight, exhaust brake, hydraulic leveling system, air suspension, air brakes, backup camera,original intercom phone system, tow hitch, propane heat as well as engine heat in house and elect., engine block heater. There is a lot to these big bus motorhomes and Iknow very little about this one as far as what does or does not work on it. Runs and shifts great. I only drove it about 70 miles when I originally purchased it from the far east valley to where it is stored in Peoria now. It has a Cat 3208 with Allison 4 speed trans. approx 160,000 miles with far less on the engine that was replaced. I think the engine has approx 40,000 miles on it. I know because I have the original Bluebird blue box with most all of its prior history included in it. I have never had it plugged into a land line to check out all of the a/c power features nor have I ever hooked it up to water. According to the previous owner most everything works in it but I myself do not know. It holds 265 gallons of diesel fuel. It does not have a generator; it was stolen. I do have the original insulated generator compartment door though. All tires will need replacing because of good old Arizona sun sidewall cracking. As stated I know very little about this coach and it is sold as is where it is. It runs fine but needs to be driven. It's been sitting in storage for 19 months now. I start it and warm it up religiously every 3 weeks but you cannot test drive it off the premises as it is neither tagged nor insured. Text or call for more info or an appointment to see it @ #602-317-6174. No emails." Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
05-17-2016, 01:22
RE: 1982 FC35SB @ Craig's List 05-07-16 & 05-13-16
F.Y.I.
http://phoenix.craigslist.org/wvl/rvs/5584177716.html This coach has been re-posted for $11.8K. Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
05-25-2016, 00:38
(This post was last modified: 06-22-2016 13:03 by PhrankinPhoenix.)
RE: 1982 FC35SB @ Craig's List 05-07-16 & 06-15-16
F.Y.I.
ditto re-posted 05-19-16 & 06-15-16 http://phoenix.craigslist.org/wvl/rvs/5594001487.html http://phoenix.craigslist.org/wvl/rvs/5636989627.html Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
