High Voltage Readings and Fluctuation 1980 33FC
08-15-2005, 11:28
Recently after starting and for the first 20 minutes my amp gauge
fluctuates and flickers back and forth from 0-20 amps and the volts 14- 16. Now it does it all the time. Checked the voltage at the alternator and reads a steady 14.2 at 1500 rpm. Any suggestions? |
08-15-2005, 13:36
I think I fixed it. I replaced the solenoid at the batteries.
I was getting 12.5 volts on one side but 11.5 on the other side of the solenoid. Voltage appears steady. --- In WanderlodgeForum@yahoogroups.com, "vabroker1" wrote: > Recently after starting and for the first 20 minutes my amp gauge > fluctuates and flickers back and forth from 0-20 amps and the volts 14- > 16. > > Now it does it all the time. > > Checked the voltage at the alternator and reads a steady 14.2 at 1500 > rpm. > > Any suggestions? |
