gen. door, radiator....
08-16-2005, 04:58
Mike
I got the genset slide to come out partway, can see better. Not sure
why it won't come out further but that's another project. Do I remove
the fan shroud from the radiator, duh?! I'm going to try to take the
hose off the water pump.
Wish I had taken time to learn some mechanics from my dad and
brothers when they were around....
thanks
Rose Mary
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...>
> Rose Mary,
> You just have to reach way down in there and do the same thing as
you
> did on the top hose. It is tough to get to down in that tray, so it
> might be easier to take the bottom hose off from the water pump
> instead and leave the hose connected to the radiator until you get
it
> out. I'm thinking that's what I might have done to get my 83
radiator
> out of the genset tray when I re-did the radiator.
> Good luck.
> Mike Bulriss
> 83 PT40 "Stagecoach" - FOR SALE
> 91 PT40 "Texas Minivan"
> San Antonio, TX
> --- In WanderlodgeForum@yahoogroups.com, "Rose Mary"
> > Using a screwdriver I was able to work around the top hose and
get it
> > off.....duh, how the heck do you get to the bottom one....or
whatever
> > is holding the bottom of the radiator from coming out.
> > Rose Mary
> > 82 FC 33
> > Oregon
> > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles"
> > wrote:
> > > Send Jeff Miller an email he has made doors and may be able to
help
> > > you out if that fails why not go to a sheet metal shop and have
> > > metal bent and replace the door
> > > Stephen 77fc35
> > > wrote:
> > > > Hi, thanks for the responses.
> > > > The louvre grill isn't really damaged and think I can get the
> > door to
> > > > work ok, hopefully.
> > > > I've got the radiator unbolted and the main hose clamp
loosened
> > but
> > > > the hose isn't wanting to come off easily. Got too hot, so
will
> > get
> > > > back to it in the cool am. Do I just need more muscle, twist
> > groan,
> > > > a knife or what?
> > > > Don't think we have a local bluebird bus dealer around here.
I
> > did
> > > > talk with the fellow who runs the local school district bus
shop
> > once
> > > > but he just jobs any repairs (engine etc) to a local truck
shop.
> > Body
> > > > work I don't know.
> > > > of course hoping for a quick fix as were hoping to use to
coach
> > this
> > > > upcoming weekend for a jaunt.
> > > > Haven't tried the gen set slide, afraid if it was damaged
I'll
> > never
> > > > get the gen. pushed back in....
> > > > thanks for your help
> > > > Rose Mary
> > > > 82 FC 33
> > > > Hot days in Oregon lately!
> > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner
> > > > wrote:
> > > > > Rosemary I replaced my generator door when I hit it with a
curb
> > > > late at
> > > > > night. My local Bluebird Bus dealer made me a new one
identical
> > to
> > > > the OEM
> > > > > one for $50. These dealers have everything to make a new
panel
> > for
> > > > any part
> > > > > of our Forward control coaches. Then I had it painted by a
> > local
> > > > body shop
> > > > > for $40. Very very reasonable. You might check with your
BB
> > school
> > > > bus
> > > > > dealer in your area. You will also find lots of parts there
at
> > a
> > > > cheaper
> > > > > price for some reason then directly from BB.
> > > > > Tom
> > > > > 1982 FC35
> > > > > Vernon Center,NY
> > > > > At 12:09 AM 8/16/2005 +0000, you wrote:
> > > > > >I got the gen door removed and am working on getting the
> > radiator
> > > > out
> > > > > >so it can go to the radiator shop and hopefully be
repaired.
> > The
> > > > bent
> > > > > >door caused the framing around the louvres to push into
> > > > radiator....
> > > > > >I think I can straighten the door without a problem,
didn't
> > crease
> > > > it
> > > > > >or anything. Hoping it didn't mess up the slide....kinda a
> > greasy
> > > > job
> > > > > >but have more time than $$ so hope by taking the radiator
out
> > and
> > > > in
> > > > > >myself I can cut down the $ to fix my own stupid mistake!
> > > > > >Rose Mary
> > > > > >82 FC 33
> > > > > >Really hot Oregon!
08-16-2005, 06:00
Rose Mary,
You're doing great. Hang in there.
I sent you additional notes offline regarding removing the fan shroud.
> Mike
> thanks
> Rose Mary
> > Rose Mary,
> you
> it
> radiator
> > Good luck.
> > Mike Bulriss
> > San Antonio, TX
> get it
> whatever
> > > Rose Mary
> > > 82 FC 33
> > > Oregon
> help
> the
> > > > Stephen 77fc35
> > > door to
> > > > > work ok, hopefully.
> loosened
> > > but
> will
> > > get
> > > groan,
> > > > > a knife or what?
> I
> > > did
> shop
> > > once
> shop.
> > > Body
> > > > > work I don't know.
> coach
> > > this
> I'll
> > > never
> > > > > Rose Mary
> > > > > 82 FC 33
> curb
> > > > > late at
> identical
> > > to
> > > > > the OEM
> panel
> > > for
> > > > > any part
> > > local
> > > > > body shop
> BB
> > > school
> > > > > bus
> at
> > > a
> > > > > cheaper
> > > > > > Tom
> > > > > > 1982 FC35
> > > > > > Vernon Center,NY
> > > radiator
> > > > > out
> repaired.
> > > The
> > > > > bent
> the
> > > > > radiator....
> didn't
> > > crease
> > > > > it
> > > greasy
> > > > > job
> out
> > > and
> > > > > in
> > > > > > >Rose Mary
> > > > > > >82 FC 33
> > > > > > >Really hot Oregon!
08-16-2005, 11:29
Mike,
the radiator sits to the left of the engine. Have the top two bolts
removed from the shroud, the bottom 2 are really going to be a time,
they are sitting up in a groove where a wrench can't get and so far
haven't found the right size extension to be able to use a 7/16
socket, I'll get it figured... going by braille I have managed to
reach the one on the left, the right is still a reach as I haven't
the bottom hose loose yet. I can see the screw on the hose clamp but
can't quite get to it. Hoping if I get the shroud loose I will be
able to reach it.
I think I am beginning to understand where the term 'monkey wrench'
came from, I think I could use their dexterity to reach and
manipulate some of these things! or is it from the way you hold your
mouth and make sounds when trying to reach and use the wrench?! Also
the term grease monkey, my hands have more grease than removing a few
bolts should produce!
How in the world does one reach to everything to reattach....ha!?
(another dumb question, the bottom screws which reach up through the
shroud, once I get ahold of them, do I still turn counter to loosen?
Don't think real well standing on my head....!
thanks
Rose Mary
> Rose Mary,
shroud.
> Mike Bulriss
> San Antonio, TX
> > Mike
sure
remove
> > thanks
> > Rose Mary
<mbulriss@y...>
> > wrote:
> > > Rose Mary,
as
> > you
so it
get
> > it
> > radiator
> > > Good luck.
> > > Mike Bulriss
> > > San Antonio, TX
> > get it
> > whatever
> > > > Rose Mary
> > > > 82 FC 33
> > > > Oregon
to
> > help
have
> > the
> > > > > Stephen 77fc35
> > > > door to
> > > > > > work ok, hopefully.
> > loosened
> > > > but
so
> > will
> > > > get
twist
> > > > groan,
> > > > > > a knife or what?
here.
> > I
> > > > did
bus
> > shop
> > > > once
truck
> > shop.
> > > > Body
> > > > > > work I don't know.
> > coach
> > > > this
> > I'll
> > > > never
> > > > > > Rose Mary
> > > > > > 82 FC 33
with a
> > curb
> > > > > > late at
> > identical
> > > > to
> > > > > > the OEM
new
> > panel
> > > > for
> > > > > > any part
by a
> > > > local
> > > > > > body shop
your
> > BB
> > > > school
> > > > > > bus
there
> > at
> > > > a
> > > > > > cheaper
> > > > > > > Tom
> > > > > > > 1982 FC35
> > > > > > > Vernon Center,NY
> > > > radiator
> > > > > > out
> > repaired.
> > > > The
> > > > > > bent
into
> > the
> > > > > > radiator....
> > didn't
> > > > crease
> > > > > > it
slide....kinda a
> > > > greasy
> > > > > > job
radiator
> > out
> > > > and
> > > > > > in
mistake!
> > > > > > > >Rose Mary
> > > > > > > >82 FC 33
> > > > > > > >Really hot Oregon!
08-16-2005, 12:09
Rose Mary
If you were planning to come to the rally in Woodland Washington, it
is much cooler up here this week. You will probably not need your air
conditioning. If you come to the Woodland Rally , I will help you
remove that radiator. Such a deal.
Steve Anderson
79 FC 35
Poulsbo, Wa
On our way to the 4th PNW Blue Bird Rally in Woodland Washington.
> Rose Mary,
shroud.
> Mike Bulriss
> San Antonio, TX
> > Mike
sure
remove
> > thanks
> > Rose Mary
<mbulriss@y...>
> > wrote:
> > > Rose Mary,
as
> > you
so it
get
> > it
> > radiator
> > > Good luck.
> > > Mike Bulriss
> > > San Antonio, TX
> > get it
> > whatever
> > > > Rose Mary
> > > > 82 FC 33
> > > > Oregon
to
> > help
have
> > the
> > > > > Stephen 77fc35
> > > > door to
> > > > > > work ok, hopefully.
> > loosened
> > > > but
so
> > will
> > > > get
twist
> > > > groan,
> > > > > > a knife or what?
here.
> > I
> > > > did
bus
> > shop
> > > > once
truck
> > shop.
> > > > Body
> > > > > > work I don't know.
> > coach
> > > > this
> > I'll
> > > > never
> > > > > > Rose Mary
> > > > > > 82 FC 33
with a
> > curb
> > > > > > late at
> > identical
> > > > to
> > > > > > the OEM
new
> > panel
> > > > for
> > > > > > any part
by a
> > > > local
> > > > > > body shop
your
> > BB
> > > > school
> > > > > > bus
there
> > at
> > > > a
> > > > > > cheaper
> > > > > > > Tom
> > > > > > > 1982 FC35
> > > > > > > Vernon Center,NY
> > > > radiator
> > > > > > out
> > repaired.
> > > > The
> > > > > > bent
into
> > the
> > > > > > radiator....
> > didn't
> > > > crease
> > > > > > it
slide....kinda a
> > > > greasy
> > > > > > job
radiator
> > out
> > > > and
> > > > > > in
mistake!
> > > > > > > >Rose Mary
> > > > > > > >82 FC 33
> > > > > > > >Really hot Oregon!
08-16-2005, 13:08
Rose Mary,
You're making good headway! Nothing magic to this one, just grunt work.
Braille method is an excellent description of reaching those bottom
bolts and screws. I seem to remember some bolts that took barely an
8th to 16th of a turn at a time with a wrench to get them off. Sounds
like you only have one more to go. Once you get the fan shroud loose,
I believe on your 82 that it is a two piece assembly with two or three
bolts/screws that hold the two major halves together. If you take
those off, you can then get the fan shroud totally out of your way for
the rest of the project. Reference the picture I sent you offline.
> few bolts should produce!
Orange GoJo with Pumice..... before, during and after!
Yes, counter clockwise to loosen. Or as my wife says: righty-tighty;
lefty-loosey!
Gee, you're almost done getting it apart! You know Steve made you a
REAL nice offer for help at the rally. If you don't get totally done
before then, maybe you can bring the repaired parts and get help
putting it back together at the rally. Committee repairs are always
fun events on Bluebirds! It's the stuff that future rally stories are
built from.
Hang in there.
> Mike,
> able to reach it.
> thanks
> Rose Mary
> > Rose Mary,
> shroud.
> > Mike Bulriss
> > San Antonio, TX
> > wrote:
> > > Mike
> sure
> remove
> the
> > > thanks
> > > Rose Mary
> <mbulriss@y...>
> > > wrote:
> > > > Rose Mary,
> as
> > > you
> so it
> get
> > > it
> > > radiator
> > > > Good luck.
> > > > Mike Bulriss
> > > > San Antonio, TX
> and
> > > get it
> > > whatever
> > > > > Rose Mary
> > > > > 82 FC 33
> > > > > Oregon
> to
> > > help
> have
> > > the
> > > > > > Stephen 77fc35
> the
> > > > > door to
> > > > > > > work ok, hopefully.
> > > loosened
> > > > > but
> so
> > > will
> > > > > get
> twist
> > > > > groan,
> > > > > > > a knife or what?
> here.
> > > I
> > > > > did
> bus
> > > shop
> > > > > once
> truck
> > > shop.
> > > > > Body
> > > > > > > work I don't know.
> > > coach
> > > > > this
> > > I'll
> > > > > never
> > > > > > > Rose Mary
> > > > > > > 82 FC 33
> with a
> > > curb
> > > > > > > late at
> > > identical
> > > > > to
> > > > > > > the OEM
> new
> > > panel
> > > > > for
> > > > > > > any part
> by a
> > > > > local
> > > > > > > body shop
> your
> > > BB
> > > > > school
> > > > > > > bus
> there
> > > at
> > > > > a
> > > > > > > cheaper
> > > > > > > > Tom
> > > > > > > > 1982 FC35
> > > > > > > > Vernon Center,NY
> the
> > > > > radiator
> > > > > > > out
> > > repaired.
> > > > > The
> > > > > > > bent
> into
> > > the
> > > > > > > radiator....
> > > didn't
> > > > > crease
> > > > > > > it
> slide....kinda a
> > > > > greasy
> > > > > > > job
> radiator
> > > out
> > > > > and
> > > > > > > in
> mistake!
> > > > > > > > >Rose Mary
> > > > > > > > >82 FC 33
> > > > > > > > >Really hot Oregon!
08-16-2005, 14:23
Mike,
got the shroud & radiator loose except for the one bolt on the bottom
right of the shroud....reckon I need another pair of hands to hold
the radiator at the right angle so I can reach it (you're right, just
small part turns once I get ahold of it...)
Wish indeed I could have it apart & radiator fixed so I could take it
to the rally ..with extra hands to put it back together, with
everything loose as it is now the bird won't be going anywhere...rats.
Maybe tomorrow I will be able to get that last bolt loose so I can
get the radiator to the shop....
it is always an adventure...
Rose Mary
82 FC 33
Oregon
> Rose Mary,
work.
Sounds
loose,
three
for
loosen?
tighty;
> lefty-loosey!
done
are
> built from.
> Hang in there.
> Mike Bulriss
> San Antonio, TX
> > Mike,
bolts
time,
far
haven't
but
> > able to reach it.
wrench'
your
Also
few
loosen?
> > thanks
> > Rose Mary
<mbulriss@y...>
> > wrote:
> > > Rose Mary,
> > shroud.
> > > Mike Bulriss
> > > San Antonio, TX
> > > wrote:
> > > > Mike
Not
> > sure
I
> > remove
take
> > the
> > > > thanks
> > > > Rose Mary
> > <mbulriss@y...>
> > > > wrote:
> > > > > Rose Mary,
thing
> > as
> > > > you
tray,
> > so it
pump
you
> > get
> > > > it
83
> > > > radiator
> > > > > Good luck.
> > > > > Mike Bulriss
> > > > > San Antonio, TX
hose
> > and
> > > > get it
one....or
> > > > whatever
> > > > > > Rose Mary
> > > > > > 82 FC 33
> > > > > > Oregon
Birtles"
able
> > to
> > > > help
> > have
> > > > the
> > > > > > > Stephen 77fc35
get
> > the
> > > > > > door to
> > > > > > > > work ok, hopefully.
clamp
> > > > loosened
> > > > > > but
hot,
> > so
> > > > will
> > > > > > get
muscle,
> > twist
> > > > > > groan,
> > > > > > > > a knife or what?
around
> > here.
> > > > I
> > > > > > did
district
> > bus
> > > > shop
> > > > > > once
> > truck
> > > > shop.
> > > > > > Body
> > > > > > > > work I don't know.
use to
> > > > coach
> > > > > > this
damaged
> > > > I'll
> > > > > > never
> > > > > > > > Rose Mary
> > > > > > > > 82 FC 33
> > with a
> > > > curb
> > > > > > > > late at
one
> > > > identical
> > > > > > to
> > > > > > > > the OEM
a
> > new
> > > > panel
> > > > > > for
> > > > > > > > any part
painted
> > by a
> > > > > > local
> > > > > > > > body shop
with
> > your
> > > > BB
> > > > > > school
> > > > > > > > bus
parts
> > there
> > > > at
> > > > > > a
> > > > > > > > cheaper
> > > > > > > > > Tom
> > > > > > > > > 1982 FC35
> > > > > > > > > Vernon Center,NY
getting
> > the
> > > > > > radiator
> > > > > > > > out
> > > > repaired.
> > > > > > The
> > > > > > > > bent
> > into
> > > > the
> > > > > > > > radiator....
problem,
> > > > didn't
> > > > > > crease
> > > > > > > > it
> > slide....kinda a
> > > > > > greasy
> > > > > > > > job
> > radiator
> > > > out
> > > > > > and
> > > > > > > > in
> > mistake!
> > > > > > > > > >Rose Mary
> > > > > > > > > >82 FC 33
> > > > > > > > > >Really hot Oregon!
Mary"
