110 volt air compressor
09-27-2018, 17:36
I may need to replace my 110 volt air compressor.
What brand and model is a good replacement for the original Gast air pump?
Richard Ramsey
09-28-2018, 11:29
RE: 110 volt air compressor
Most air compressors are really noisy. My Vantare has a Jun-Air which is very quiet. I believe it's a Model 3, 120VAC, but I'll check for you.
For a less expensive but still quiet solution some have installed Silentaire's, the 30TC or the 50TC: https://www.dixieart.com/SilentaireIllustration.html
10-06-2018, 00:50
I use a Viair portable compressor...can be had either as a 110v or 12v. I have the 12v. Sure, some noise, but I'm sorta deaf anyways!Big Grin
Bob Lawrence
1984 PT36
On the road in the west Cool
10-09-2018, 09:18
Thanks. I will research that.
I have been looking at California Air, Senior, and Husky air compressors. Thinking of robbing the compressor from their unit.
Will order one when I get home.
Richard Ramsey
10-13-2018, 12:37
Like David said, my Jun-Air in my 2001 LXi is pretty quiet and packs a punch. I thought it had a problem, so I plumbed it into one my portable compressors (6 gal) and it built pressure so fast, it blew the 100psi pop-off valve before I could run back in the bus to hit the off switch.
FWIW,
2001 LXi 43' DS Millennium Edition
