Tachometer still not working
09-15-2005, 15:28
I finished troubleshooting the tachometer, I hope. Maybe someone here
can confirm my findings. Turning on the ignition, motor not running, causes the tach needle to spin 1 complete revolution ending up pointing straight down. When the motor is started the tach needle will occasionally appear to work but not with any consistency. Ussually points straight south. I replaced the drive unit on the motor with no change. Tonight I began removing wires 1 at a time and testing for any change. Eventually I ended up removing the guage and connecting a jumper wire to the power and 1 to the ground. At this point the needle aligns to zero. When I add a single wire to the "S" terminal the needle spins all the way around and points south. This happens even when the wire attached to the "S" terminal is new wire still on the spool. I'm thinking the guage is junk. Can anyone confirm this? Troy, Waconia MN 1983 FC33 |
09-15-2005, 16:35
Troy, I have the same problem but it is on my speedo. with the key on
or with the gen running the tac reads 1k and the speedo reads 15mph and even clocks the miles. I was told I have 'electrical noise' and the wire that runs the speedo is picking up a stray current. Maybe you have a wire leaning up against the tac wire that is bleeding 'electrical noise. Dont know, sounds SiFi but I plan on giving it a look at before I go to a Speedo shop Greg O'Connor 94pt40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > I finished troubleshooting the tachometer, I hope. Maybe someone here > can confirm my findings. > > Turning on the ignition, motor not running, causes the tach needle to > spin 1 complete revolution ending up pointing straight down. When the > motor is started the tach needle will occasionally appear to work but > not with any consistency. Ussually points straight south. I replaced > the drive unit on the motor with no change. Tonight I began removing > wires 1 at a time and testing for any change. Eventually I ended up > removing the guage and connecting a jumper wire to the power and 1 to > the ground. At this point the needle aligns to zero. When I add a > single wire to the "S" terminal the needle spins all the way around > and points south. This happens even when the wire attached to the "S" > terminal is new wire still on the spool. I'm thinking the guage is > junk. Can anyone confirm this? > > > Troy, Waconia MN > 1983 FC33 |
