FC vs PT re; Repairs and Complexities
09-16-2005, 10:41
As a relatively mechanically
challenged "wanabee" (maybe can handle a spin on oil filter!)...are the FC's less or maybe more difficult to keep running than say a mid 80's PT? Also, along the same theme...is a mid 90's PTs less likely to have repair "issues"? Other than the fact it is newer? Seems to me the BB's are substantially more mechanically complex...ie multiple of everything? Should I maybe look for a pop-up trailer? Or should I get a diesel mechanic on retainer? What say you??? Tom Rootness in Northern Minnesota P.S. I also posted on the other BB site...hope that is not against the Law! |
09-16-2005, 12:05
Tom,
ANY motorhome will have repair issues, even a new one. Typically, my experience has been with the various systems rather than the running gear, so diesel repairs is not really the issue (assuming a sound investment to begin with and good maintenance practices). As you get more amenities, you get more complex systems and more potential for failure/learning experiences. Wanderlodges are full of amenities. It is a worthwhile investment to get a good inspection from a knowledgable party before buying if you are totally unfamiliar with RVs. If you are truly mechanically challenged and unwilling to learn, then a new coach that can be taken to the dealer under warranty for everything that goes wrong may be the way to go. You bite the bullet on depreciation. If you are mechanically inexperienced, but willing to learn and try, then the various Wanderlodge forums will be there to help you out. If you out-source all the repairs, you bite the bullet on repair costs. As an example of the help available on the forums, one of our female members that inherited a vintage Bird just had the experience of learning how to remove, repair and replace a generator radiator with the help of the forum members. I think she learned that it isn't rocket science and that step by step input can save lots of otherwise out-sourced repair costs. Pop-up trailer?! Kind of a stretch versus a Bird. Are you seriously looking? On the other hand, we went from a tent to a PT, so I understand about stepping up in class! Good luck in your decision. And, yes, we have members on many other BB sites, so post away! Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "martymc_99" > As a relatively mechanically > challenged "wanabee" (maybe can handle a spin on oil filter!)...are the > FC's less or maybe more difficult to keep running than say a mid 80's > PT? Also, along the same theme...is a mid 90's PTs less likely to have > repair "issues"? Other than the fact it is newer? > > Seems to me the BB's are substantially more mechanically complex...ie > multiple of everything? Should I maybe look for a pop-up trailer? Or > should I get a diesel mechanic on retainer? > > What say you??? Tom Rootness in Northern Minnesota > > P.S. I also posted on the other BB site...hope that is not against the > Law! |
09-16-2005, 12:24
Hi Tom:
The systems in the Pt's and Fc's are much the same, save for locations and a couple of extra systems such as tag dump and air throttle, high idle systems. Some things are easier to maintain on the Pt's, but then there are some on the Fc's that are easier, again, location of components. Roominess is the key here really. There is more storage in the Pt vs the FC, so really we are talking apples and oranges in a way. One advantage of a Pt would be the engine. The piston cylinders are sleeved where the FC is not as a rule, so an in frame rebuild, if needed, is better. There are so many differences, yet similarities that answering your question is a hard one. Like Mike said, things are going to happen no matter what you have. I saw a guy with a pop up trailer with wheel bearings on fire and the small A/C unit on top was torn 1/2 off, so go figure. Thing is, once you become accustomed to what ever you end up with, you learn it's idiosyncrasies and go from there. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 10:41 PM 9/16/2005 +0000, you wrote: >As a relatively mechanically >challenged "wanabee" (maybe can handle a spin on oil filter!)...are the >FC's less or maybe more difficult to keep running than say a mid 80's >PT? Also, along the same theme...is a mid 90's PTs less likely to have >repair "issues"? Other than the fact it is newer? > >Seems to me the BB's are substantially more mechanically complex...ie >multiple of everything? Should I maybe look for a pop-up trailer? Or >should I get a diesel mechanic on retainer? > >What say you??? Tom Rootness in Northern Minnesota > >P.S. I also posted on the other BB site...hope that is not against the >Law! > > |
09-16-2005, 12:33
Mike...the pop of trailer was not serious.
What has been your observation having moved from your FC to the "newer" PT? Similar systems and challenges...other than a bit newer? I actually am not averse to mechanical efforts...just have learned that the "learning curve" is painful without direction. My preference after reading adds for a year is the '91-'95 PTs. Seems like the interiors are more "modern" and wife actually likes what they look like. One question is determining what they actually sell for...many are priced high and just sit there. Maybe you could share (by e-mail) your buying experience vs pricing in the various adds? Also, where did you find your PT? Thanks for your input...those BB's are sure unique!...Tom Rootness in Northern Minnesota |
09-16-2005, 13:03
I've been RVing since 77, had truck campers, fifth wheels, and several class As.
To me the FC Wanderlodge is a hard act to beat if one like retro things and doesn't need to have a new vehicle every couple of years. I got over that when I couldn't find the time to use the units we owned at the time but the payments came due every month. Worst experience was the 36' Southwind that was one year old and had to have a side replaced and the frame straightened. 7 mos. in the shop while I made the payments. It was under warrantee but I didn't like the experience. A Wanderlodge will last for generations if not subjected to the elements, left sitting under a tree in the grass for instance. That's what I want, don't need a slide room. Mike Hohnstein ----- Original Message ----- From: martymc_99 To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 16, 2005 7:33 PM Subject: [WanderlodgeForum] Re: FC vs PT re; Repairs and Complexities Mike...the pop of trailer was not serious. What has been your observation having moved from your FC to the "newer" PT? Similar systems and challenges...other than a bit newer? I actually am not averse to mechanical efforts...just have learned that the "learning curve" is painful without direction. My preference after reading adds for a year is the '91-'95 PTs. Seems like the interiors are more "modern" and wife actually likes what they look like. One question is determining what they actually sell for...many are priced high and just sit there. Maybe you could share (by e-mail) your buying experience vs pricing in the various adds? Also, where did you find your PT? Thanks for your input...those BB's are sure unique!...Tom Rootness in Northern Minnesota ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
09-16-2005, 14:06
Tom,
Moving from the 83 PT to the 91 PT was not too bad in terms of learning curve on the systems. Similar systems with similar challenges, but newer as you said. Lots of things don't seem to be where I left them! After eight years with the 83, I pretty much knew where every switch and load center was without hardly looking. Not much is the same in that regard. Haven't had time to read the manuals yet on the 91, so we have searched for some items and felt like newbies when we found them. Newer doesn't necessarily always mean better. I will miss the 83's Digitell (audio diagnostic unit - aka "the little talking man"). So far, I think the ducted cruise airs on the 83 are more efficient than the ducted roof top airs on the 91. I liked the big honking steel chrome bumpers on the 83, versus the fiberglass coated ones on the 91. In many ways, lots of other system things were much simpler in design/de-bug on the 83 than the 91. The one thing about both of the Birds is how solid they are built. Both of our Birds will most probably outlive me - and I don't intend to go away soon! Like Ralph mentioned, we were returning from South Padre Island a year ago and we saw a travel trailer that was totally indistinguishable as to what it used to be. There was a frame and the largest other piece was about 2 feet square and 2 inches thick. Contrast that to one of our members rolled a Bird over last year, down an incline and into a tree. They walked away. Looking at pictures of the Bird from the front, you would not really notice that there had been an accident, until you noticed the windshield they kicked out. Versus any comparable age SOB, the Birds remind me of the MasterCard ad - purchase cost: high; operating cost: expensive; comfort and safety factor: priceless. I sent you a note via email as requested with contact info to discuss the purchase related questions. Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "martymc_99" > Mike...the pop of trailer was not serious. > > What has been your observation having moved from your FC to the "newer" > PT? Similar systems and challenges...other than a bit newer? > > I actually am not averse to mechanical efforts...just have learned that > the "learning curve" is painful without direction. > > My preference after reading adds for a year is the '91-'95 PTs. Seems > like the interiors are more "modern" and wife actually likes what they > look like. One question is determining what they actually sell > for...many are priced high and just sit there. > > Maybe you could share (by e-mail) your buying experience vs pricing in > the various adds? Also, where did you find your PT? > > Thanks for your input...those BB's are sure unique!...Tom Rootness in > Northern Minnesota |
09-17-2005, 03:52
Tom
With the help of this and the other boards you can over come most of the problems, also find somewhere to fix the things like chassis and engine problems that might come up.We have a freind that keeps a fleet of trucks on the road and a fleet service place that will do what he dosn't have time to look at. A regular motorhome place will look at it and wonder what they are going to do with this thing! When we bought our FC we were overwhelmed to say the least, but with some help from here in time you can do what you thought you couldn't do at first.To me its like a part time job as there is always something that you could do,today I will remove and resecure the sewer hose holder, fix the banging under the bus from the step,and try to figure out how to fix the hole on the muffler for the perkins generator. Either a FC or a PT will be some work, but if we can own one of these fine coaches you can handle it too. Don't be like my neigbor and try and one up me by buying a 1981 Airstream motohome, now that is a coach I would never try and drive father than 30 miles much less through Chicago! Michelle and Jeff August 1980FCRB (6500 miles this summer) Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > Tom, > > Moving from the 83 PT to the 91 PT was not too bad in terms of > learning curve on the systems. Similar systems with similar > challenges, but newer as you said. Lots of things don't seem to be > where I left them! After eight years with the 83, I pretty much knew > where every switch and load center was without hardly looking. Not > much is the same in that regard. Haven't had time to read the manuals > yet on the 91, so we have searched for some items and felt like > newbies when we found them. > > Newer doesn't necessarily always mean better. I will miss the 83's > Digitell (audio diagnostic unit - aka "the little talking man"). So > far, I think the ducted cruise airs on the 83 are more efficient than > the ducted roof top airs on the 91. I liked the big honking steel > chrome bumpers on the 83, versus the fiberglass coated ones on the 91. > In many ways, lots of other system things were much simpler in > design/de-bug on the 83 than the 91. > > The one thing about both of the Birds is how solid they are built. > Both of our Birds will most probably outlive me - and I don't intend > to go away soon! Like Ralph mentioned, we were returning from South > Padre Island a year ago and we saw a travel trailer that was totally > indistinguishable as to what it used to be. There was a frame and the > largest other piece was about 2 feet square and 2 inches thick. > Contrast that to one of our members rolled a Bird over last year, down > an incline and into a tree. They walked away. Looking at pictures of > the Bird from the front, you would not really notice that there had > been an accident, until you noticed the windshield they kicked out. > Versus any comparable age SOB, the Birds remind me of the MasterCard > ad - purchase cost: high; operating cost: expensive; comfort and > safety factor: priceless. > > I sent you a note via email as requested with contact info to discuss > the purchase related questions. > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale > 91 PT40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "martymc_99" > > > Mike...the pop of trailer was not serious. > > > > What has been your observation having moved from your FC to the "newer" > > PT? Similar systems and challenges...other than a bit newer? > > > > I actually am not averse to mechanical efforts...just have learned that > > the "learning curve" is painful without direction. > > > > My preference after reading adds for a year is the '91-'95 PTs. Seems > > like the interiors are more "modern" and wife actually likes what they > > look like. One question is determining what they actually sell > > for...many are priced high and just sit there. > > > > Maybe you could share (by e-mail) your buying experience vs pricing in > > the various adds? Also, where did you find your PT? > > > > Thanks for your input...those BB's are sure unique!...Tom Rootness in > > Northern Minnesota |
09-17-2005, 04:17
Thanks Jeff...for the encouragement! I have been studying for over a
year...and keep coming back to the BBs! I do think I need to plan the garage before I take the plinge...I know I am not willing to work on it outside...except in emergency. BTW where is Plymouth, WI. We have a home North of Duluth and a townhouse in Eden Prairie...a Mpls suburb. Thank You...Tom Rootness |
09-17-2005, 10:23
Tom,
While you are looking at FC & PT, don't forget the BMC line. You will be able to purchase a 4 - 5 year newer bird for same money of PT. Have updated interiors and bullet proof cummings engine. You will not have all the amnenties as the wanderlodge but the systems you do have will be 4 - 5 years newer. You will get better fuel mileage on the BMC compared to the PT. The BMC will get 8 mpg running all day at interstate speeds. BMC is a best kept secret of Bluebird. Al & Kathy Johnson Mandeville, Louisiana ( being a lumberjack for a long time due to the wrath of Ms. Katrina. ) Someday we will have all the trees cleaned off our property. --- In WanderlodgeForum@yahoogroups.com, "martymc_99" > Mike...the pop of trailer was not serious. > > What has been your observation having moved from your FC to the "newer" > PT? Similar systems and challenges...other than a bit newer? > > I actually am not averse to mechanical efforts...just have learned that > the "learning curve" is painful without direction. > > My preference after reading adds for a year is the '91-'95 PTs. Seems > like the interiors are more "modern" and wife actually likes what they > look like. One question is determining what they actually sell > for...many are priced high and just sit there. > > Maybe you could share (by e-mail) your buying experience vs pricing in > the various adds? Also, where did you find your PT? > > Thanks for your input...those BB's are sure unique!...Tom Rootness in > Northern Minnesota |
09-17-2005, 10:24
Tom,
Sorry we also own a '96 BMC 37' and love it! Al & Kathy Johnson Mandeville, Lousiana '96 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "martymc_99" > Mike...the pop of trailer was not serious. > > What has been your observation having moved from your FC to the "newer" > PT? Similar systems and challenges...other than a bit newer? > > I actually am not averse to mechanical efforts...just have learned that > the "learning curve" is painful without direction. > > My preference after reading adds for a year is the '91-'95 PTs. Seems > like the interiors are more "modern" and wife actually likes what they > look like. One question is determining what they actually sell > for...many are priced high and just sit there. > > Maybe you could share (by e-mail) your buying experience vs pricing in > the various adds? Also, where did you find your PT? > > Thanks for your input...those BB's are sure unique!...Tom Rootness in > Northern Minnesota |
