8K Onan Generator
10-21-2005, 08:05
8K Onan Generator
Hi Everyone,
Has anyone removed the 7.5/8K Onan from a late model FC.
It appears to hangs from four long rod bolts.
Looks simple enough, but we all know how these jobs turn
into major projects. I want to replace insulation and
service the radiator, hoses and cooling motor.
Any advice will be appreciated.
Bill 88 FC Michigan
10-22-2005, 07:55
8K Onan Generator
> removing generator...my ole 77fc had 4 bolts..i put two jacks
underneat the steel platform holding it and then let it down after
undoing the bolts etc..??this make any sense??
regards,
Haqnk Hannigan
ole 77FC33 now 90Sp36
> Hi Everyone,
> Bill 88 FC Michigan
10-23-2005, 01:48
8K Onan Generator
Hank,
Yep, you make sense.
I had the Bird in storage and was looking for ideas.
Now that it is home, it looks as you say, a steel platform and four
big bolts. The problem will be removing the rusty exhaust and
getting the motivation for a project. I may wait until next
Spring/Summer. Stephen is shipping the insulation.
I must first winterize the plumbing, change the oil, filters, and
squirt some grease into the chassis ( I hate that dirty job )
Going to change the propane detector, solenoid shut-off and propane
regulator. We had some intermittent propane pressure problems last
winter. 35 degrees this morning, Will use an additive and fill with
winter diesel. Still around $3.00/gal
THanks,
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> regards,
> Haqnk Hannigan
> > Hi Everyone,
> > Bill 88 FC Michigan
10-23-2005, 09:27
8K Onan Generator
-Bill: watch out how u hook up the exhaust pipe for genny when u
do the job..i learned the hard way as it was hooked too close to
passenger side back BRAKE HOSE..and I lost it AFTER arriving in RENO
from california...lucky it did not burn out comming down the
mountain...happened in a parking in RENO...i had spare hose and was
on my way in an hour.
Hank Hannigan
90sp36
in Hawaii for now
> Hank,
four
propane
with
> THanks,
> Bill 88 FC Michigan
after
> > regards,
> > Haqnk Hannigan
> > > Hi Everyone,
> > > Bill 88 FC Michigan
