basement door strut part number
11-06-2005, 12:12
Does anyone have a part number for the basement compartment doors,
both the large front door(PT40) and the smaller rear compartment(PT40)? I had replaced the struts on the front compoartment door on the curb side. The numbers on the gas springs don't jive with anything at Orr & Orr. If you have part numbers for these 2 different doors, would appreciate that information. Thanks Jay Darst 85PT40 Springfield, IL |
11-06-2005, 14:15
Jay,
Are you looking for the gas struts are for doors. Howard truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 06, 2005 7:12 PM Subject: [WanderlodgeForum] basement door strut part number Does anyone have a part number for the basement compartment doors, both the large front door(PT40) and the smaller rear compartment(PT40)? I had replaced the struts on the front compoartment door on the curb side. The numbers on the gas springs don't jive with anything at Orr & Orr. If you have part numbers for these 2 different doors, would appreciate that information. Thanks Jay Darst 85PT40 Springfield, IL SPONSORED LINKS Recreational vehicles Automotive maintenance ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-06-2005, 14:28
I need the gas springs or struts that hold the doors open.
Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Jay, > > Are you looking for the gas struts are for doors. > > Howard truitt > Camilla, Ga. > 86 8V92 PT40 > ----- Original Message ----- > From: Jay Darst > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, November 06, 2005 7:12 PM > Subject: [WanderlodgeForum] basement door strut part number > > > Does anyone have a part number for the basement compartment doors, > both the large front door(PT40) and the smaller rear compartment (PT40)? > > I had replaced the struts on the front compoartment door on the curb > side. The numbers on the gas springs don't jive with anything at Orr & > Orr. > > If you have part numbers for these 2 different doors, would appreciate > that information. > > Thanks > > Jay Darst > 85PT40 > Springfield, IL > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
11-06-2005, 15:06
Jay,
Every strut on my coach is bad. I priced replacements at a local auto parts store they were about $40.00 per set. I use bungie cords to hold them open works great cost $4.74 for all I needed at Wal Mart. If you want to make something that will hold them up get you some heavy or thick wall PVC or Copper Pipe and cut it the length of the extended ram. Unfasten one end of the strut and slide the pipe over the strut and reattach the strut. If you have it cut to the right length when you open the door the ram pulls out from the strut and the pipe drops under the edge of the strut and holds the door open. When you get ready to close the door push up on the door, push in slightly on the pipe so the strut can slide down inside the pipe. You only need one pipe per door and put it on the right side if you are right handed. You will never have to worry about struts again. I have a more elaborate one on the rear engine access door. I guess it was OE. Howard O. Truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 06, 2005 9:28 PM Subject: [WanderlodgeForum] Re: basement door strut part number I need the gas springs or struts that hold the doors open. Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Jay, > > Are you looking for the gas struts are for doors. > > Howard truitt > Camilla, Ga. > 86 8V92 PT40 > ----- Original Message ----- > From: Jay Darst > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, November 06, 2005 7:12 PM > Subject: [WanderlodgeForum] basement door strut part number > > > Does anyone have a part number for the basement compartment doors, > both the large front door(PT40) and the smaller rear compartment (PT40)? > > I had replaced the struts on the front compoartment door on the curb > side. The numbers on the gas springs don't jive with anything at Orr & > Orr. > > If you have part numbers for these 2 different doors, would appreciate > that information. > > Thanks > > Jay Darst > 85PT40 > Springfield, IL > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Automotive maintenance ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-06-2005, 16:47
Jay
get hold of Curt Sprenger he has the ppropriate numbers for the Gas Springs Stephen 77gc35 still using strings and chains --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > I need the gas springs or struts that hold the doors open. > > Thanks > Jay Darst > 85PT40 > Springfield, IL > > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Jay, > > > > Are you looking for the gas struts are for doors. > > > > Howard truitt > > Camilla, Ga. > > 86 8V92 PT40 > > ----- Original Message ----- > > From: Jay Darst > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, November 06, 2005 7:12 PM > > Subject: [WanderlodgeForum] basement door strut part number > > > > > > Does anyone have a part number for the basement compartment > doors, > > both the large front door(PT40) and the smaller rear compartment > (PT40)? > > > > I had replaced the struts on the front compoartment door on the > curb > > side. The numbers on the gas springs don't jive with anything at > Orr & > > Orr. > > > > If you have part numbers for these 2 different doors, would > appreciate > > that information. > > > > Thanks > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance > > > > > > ------------------------------------------------------------------- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ------------------------------------------------------------------- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
11-07-2005, 00:32
Howard, that is what I have on my engine compartment. It has held that heavy
door for years. I'm going to add those pipes to the rest of the lower compartments. Ernie-83pt40- on my way out of town,again. -----Original Message----- From: Howard O. Truitt Sent: Sun, 6 Nov 2005 22:06:11 -0500 Subject: Re: [WanderlodgeForum] Re: basement door strut part number Jay, Every strut on my coach is bad. I priced replacements at a local auto parts store they were about $40.00 per set. I use bungie cords to hold them open works great cost $4.74 for all I needed at Wal Mart. If you want to make something that will hold them up get you some heavy or thick wall PVC or Copper Pipe and cut it the length of the extended ram. Unfasten one end of the strut and slide the pipe over the strut and reattach the strut. If you have it cut to the right length when you open the door the ram pulls out from the strut and the pipe drops under the edge of the strut and holds the door open. When you get ready to close the door push up on the door, push in slightly on the pipe so the strut can slide down inside the pipe. You only need one pipe per door and put it on the right side if you are right handed. You will never have to worry about struts again. I have a more elaborate one on the rear engine access door. I guess it was OE. Howard O. Truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 06, 2005 9:28 PM Subject: [WanderlodgeForum] Re: basement door strut part number I need the gas springs or struts that hold the doors open. Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Jay, > > Are you looking for the gas struts are for doors. > > Howard truitt > Camilla, Ga. > 86 8V92 PT40 > ----- Original Message ----- > From: Jay Darst > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, November 06, 2005 7:12 PM > Subject: [WanderlodgeForum] basement door strut part number > > > Does anyone have a part number for the basement compartment doors, > both the large front door(PT40) and the smaller rear compartment (PT40)? > > I had replaced the struts on the front compoartment door on the curb > side. The numbers on the gas springs don't jive with anything at Orr & > Orr. > > If you have part numbers for these 2 different doors, would appreciate > that information. > > Thanks > > Jay Darst > 85PT40 > Springfield, IL > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Automotive maintenance ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Yahoo! Groups Links [Non-text portions of this message have been removed] |
11-07-2005, 05:33
Jay, I have replaced all the gas springs on my Bird. Used SOSPA a
manufacture here in Mi. all were under $20. If you would like I can get the #'s for you. Oene --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Does anyone have a part number for the basement compartment doors, > both the large front door(PT40) and the smaller rear compartment (PT40)? > > I had replaced the struts on the front compoartment door on the curb > side. The numbers on the gas springs don't jive with anything at Orr & > Orr. > > If you have part numbers for these 2 different doors, would appreciate > that information. > > Thanks > > Jay Darst > 85PT40 > Springfield, IL > |
11-07-2005, 06:00
> > I need the gas springs or struts that hold the doors open. > > Thanks > Jay Darst > 85PT40 > Springfield, IL > > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Jay, > > > > Are you looking for the gas struts are for doors. > > > > Howard truitt > > Camilla, Ga. > > 86 8V92 PT40 > > ----- Original Message ----- > > From: Jay Darst > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, November 06, 2005 7:12 PM > > Subject: [WanderlodgeForum] basement door strut part number > > > > > > Does anyone have a part number for the basement compartment > doors, > > both the large front door(PT40) and the smaller rear compartment > (PT40)? > > > > I had replaced the struts on the front compoartment door on the > curb > > side. The numbers on the gas springs don't jive with anything at > Orr & > > Orr. > > > > If you have part numbers for these 2 different doors, would > appreciate > > that information. > > > > Thanks > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > Jay, I also replaced my gas springs. Ordered from orrorr.com-- I thing the shorter ones were around $12, and the longer ones were $20. hope this helps ED GARDELS 89SP ARLINGTON TEXAS > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance > > > > > > ----------------------------------------------------------------- -- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ----------------------------------------------------------------- -- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
11-07-2005, 06:00
11-07-2005, 06:06
Jay,
I did a quick search on the archives and here are some relevant posts: ------------- Date: Sun, 11 Jan 2004 20:00:24 -0000 From: "ac7880" Subj: gas struts - help w/ part numbers & source I located my receipt for the struts. H9412-35, gas prop - 35 lb (I used these for inside overhead cabinets), $10.05 each (ordered March 2002). FBN12G, Gas spring - 90 lb (I used for outside compartments. "Very Strong" spring, consider replacing in pairs to avoid chancing warping the door. If they have a lighter pound spring consider it.) $22.55 each, in March 2002. Free catalog, part no MH2000/20 . http://www.orrorr.com Orr & Orr, 3520 S. Morgan St. Chicago, IL 60609-1524 (773)254-0022 Dan, 83 FC35 ------------------- Date: Thu, 11 Mar 2004 09:19:02 -0700 From: Frederick Leonhardt Subj: Orr & Orr Door Strut Part Numbers >From Orr & Orr I used the 35lb strut inside (H9412-35) and the 80lb strut outside (FBN12E). On the inside units, there's a metal retaining clip that you have to pry out to release the old strut (new ones pop right in). On the outside struts, you can just twist off the old old ones, and pop the new ones in place. Try to prop open the door with some wood so you don't have to hold the door on your head while you try to wrestle the new strut into place. A paint stirring stick works good for the inside doors; a 2X4 for the outside doors. Alb. Rick (1985 FC-31) ----------------------- >I threw this one in just incase someone else needs this info< Date: Fri, 29 Aug 2003 01:53:21 -0000 From: "John Ely" Subj: gas struts Jay, I have an 86PT40, but have that side door. I don't have the Stabilus number but the number on my struts is SPO-5200-60A from Service Parts Distributors, Inc., Bensalen, PA 19020 215.639.7810. This info is as old as my coach, so it may not be good anymore. Good luck, John Ely, San Jose, CA 86PT40 --- In Wanderlodge@yahoogroups.com, "jdarstpt40" > Can anyone give me a Stabilus part # for gas struts for the curb > side engine access panel(battery, air cleaner, Raycor) on 1985 40PT? > > I called Bluebird, they gave me a part number and I now have struts > for the rear engine door. > > Any help is appreciated... > > Jay Darst > 1985 40PT 6V92 --------------------------------- There you go. Hope these help. Mike Bulriss 83 PT40 "Stagecoach" - For Sale - Now with Financing! 91 PT40 "Texas Minivan San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Does anyone have a part number for the basement compartment doors, > both the large front door(PT40) and the smaller rear compartment(PT40)? > > I had replaced the struts on the front compoartment door on the curb > side. The numbers on the gas springs don't jive with anything at Orr & > Orr. > > If you have part numbers for these 2 different doors, would appreciate > that information. > > Thanks > > Jay Darst > 85PT40 > Springfield, IL > |
