step air leak
11-16-2005, 12:50
step air leak
I have a leak at the control box- if that is the correct term, by my
step. The cylinder is fine. The leak is not at a fitting, but at
another part of that control. Anyone have this situation? Ernie-83PT40
in Weatherford, Tx- YUP--AT HOME!!
11-16-2005, 14:13
step air leak
Ernie, I had the same prob as a symtom to a bad seal in the ram. When
I would tug the step fully open the air hissing would stop. (My
94pt40 has a non spring ram with two air ports) If you remove the ram
and blow air in, to push the stroke out , the air should stop blowing
out the other port when the stroke bottoms out. if the air continues
to blow out the other port the seal is bad in the ram. You may be
able to remove both airlines to the ram and test it without removing
the ram first. I tried to split the ram open to replace the seal but
the Clippar ram used on my bus could not be serviced.
94PT40 Romoland California
my
83PT40
11-16-2005, 15:04
step air leak
Ernie,
As a suggestion,I would, first of all, contact Bennie Collier at BlueBird
Customer Service and get a detailed schematic of the step air system and ask him
where you should start trouble shooting. He usually knows the weaknesses &
common failures and can save you some time. I do all my own work on my '91
(except computers) and (1)reading the manual, (2)checking the blueprints, and
(3)then calling Bennie are my first steps in fixing stuff. They often have
better drawings and he will fax them to you. My '78 FC 31' had a tempermental
step. Cold weather made it slow.
I'm getting ready to work on my TV antenna system and I'm trying to "tone
out" my coax cables, so I will probably be asking for a diagram of them soon. I
usually only have to call him about once a year!
I live just west of Lewisville, Texas (940-241-2244) if you need any
help.
Bob & Judy Johannesen
'91 WLWB 40' "Seldom Blue", FMCA F72567, WL# 1986, Vintage Birds #345
Argyle, Texas
my
83PT40
SPONSORED LINKS
Recreational vehicles Wanderlodge Automotive maintenance
YAHOO! GROUPS LINKS
Yahoo! FareChase - Search multiple travel sites in one click.
11-16-2005, 19:38
step air leak
Thanks Greg, am probably going to get one of those fancy leak detectors to
pinpoint ALL of my air leaks. Ernie 83pt40 in texas
11-16-2005, 19:40
step air leak
Hi Bob, I believe Ralph came to your place to help you with your coach. Come
on down to our Lone Star Birds rally in Boerne. Ernie- in weatherford
11-17-2005, 00:56
step air leak
Tom- what section of walmart has the rectorseek? Ernie- kinda cheap in texas
11-17-2005, 03:35
step air leak
Ernie I have one of the expensive ultrasonic leak detectors and it
works. But I also have a small bottle of Rectorseek that you can buy
at Walmart and it works just as good. You swab it on all of the
places you think there might be a leak and no matter how small the
leak is this stuff will form a bubble around it locating the exact
spot. Its a couple of dollars a
bottle. http://www.rectorseal.com/ac.htm#leak%20locators
Tom Warner
1982 FC35
Vernon Center,Ny
11-17-2005, 04:51
step air leak
Thanks Tom- will get some tomorrow, The forum is up and running- maybe a
yahoo hiccup. Ernie
11-17-2005, 09:17
step air leak
Ernie today someone else has been occupying my body. I meant Home
Depot and its in the heating and air conditioning section. Its in a
plastic bottle and is an orange color. This stuff sticks like snot
but will wash off easily or dry without harming anything you swab it
on to. Believe me if there is even the tiniest leak it will start
forming a bubble even hours later.
Tom
>SPONSORED LINKS
ObWmSYTw>Recreational
>vehicles
anderlodge
4cC1O9CxA>Automotive
>maintenance
YHfELr6o72IW1A>Recreational
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
11-18-2005, 08:41
step air leak
Bill, I think that may be the same stuff Tom Warner alerted me to, yesterday.
Sorry- but only drink stuff from a box. Ernie-83pt40 with air and oil leaks
intexas
