estimated cost for repairs
12-12-2005, 06:41
Mike- where is this coach located? Perhaps one of our members has seen this
coach? Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
12-12-2005, 07:54
Ralph can do an inspection. the rear bath is larger then on the side bath
coaches. The only drawback- you have twin beds- which isn't all that bad. Ernie-83pt40 in Texas- all prepped for coach surgery Tuesday [Non-text portions of this message have been removed] |
12-12-2005, 10:25
Hi all-
I am looking at a 85 FC '35 that looks to be in good shape but needs the following repairs/maintenance. I would like to know what it would cost for the following so I can figure it into the price. It has a recent oil change/lube and oil analysis which showed normal. The tires are 5-6 years old and should be replaced before a trip but are ok to drive local. The oil needs to be changed in the front wheel bearings. The refrigerator and head have already been replaced with newer models. The retarder is not working and the leveling system is not working but both can be fixed. Two roof ac's need covers. Power steering pump has a leak. Thanks Mike |
12-12-2005, 10:53
tires 250- 600 each dependent on brand rating plus installation
air conditioning covers around 100 each plus installation ps pump 300-600 for low end for rebuilt high end for new plus installation Retarder any idea why it is not working maybe just a loose wire but trouble shooting time is involved front wheel bearings probably get charged 2 hours at your local neighbourhood truck or bus mechanic any where from 60 to 125 an hour for labour Levelors same deal truoble shoot and fix parts extra Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "cobraheat1" <mike.meister@i...> wrote: > > Hi all- > I am looking at a 85 FC '35 that looks to be in good shape but needs > the following repairs/maintenance. I would like to know what it would > cost for the following so I can figure it into the price. > > It has a recent oil change/lube and oil analysis > which showed normal. The tires are 5-6 years old and should be > replaced before a trip but are ok to drive local. The oil needs to be > changed in the front wheel bearings. The refrigerator and head have > already been replaced with newer models. The retarder is not working > and the leveling system is not working but both can be fixed. Two > roof ac's need covers. Power steering pump has a leak. > > > Thanks > Mike > |
12-12-2005, 11:00
No +, no - for the engine oil change/lube, head and refer.
New tires: Toyos: $2,400 mounted, new stems, balanced. Add a hundred $$$ each for the Michelin. Leveling System: Is it an HWH system? If you are close to Moscow Iowa, the HWH factory, take it there. The labor is cheap...compared to So Calif. it's about half. Order parts from HWH. AC Covers: Not sure you can find them. Check with Camping World. Someone on the forum will make comment. Front Wheel Bearing Oil Change: Needed? Not sure about the cost. I'd guess less than two hours labor plus seals/oil. Retarder: Check for wiring problem, maybe ground, before taking it to a shop. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. cobraheat1 wrote: > Hi all- > I am looking at a 85 FC '35 that looks to be in good shape but needs > the following repairs/maintenance. I would like to know what it would > cost for the following so I can figure it into the price. > > It has a recent oil change/lube and oil analysis > which showed normal. The tires are 5-6 years old and should be > replaced before a trip but are ok to drive local. The oil needs to be > changed in the front wheel bearings. The refrigerator and head have > already been replaced with newer models. The retarder is not working > and the leveling system is not working but both can be fixed. Two > roof ac's need covers. Power steering pump has a leak. > > > Thanks > Mike > > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-12-2005, 11:52
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote:
> > Mike- where is this coach located? Perhaps one of our members has seen this > coach? Ernie-83pt40 in Texas > > > [Non-text portions of this message have been removed] > 1985 Wanderlodge FC 35' Rear Bath model Original Blue and Cream exterior paint. Blue interior. Six new deep cycle coach batteries. 12.5KW generator runs good has new battery. New Xantrex computerized attery charger. Three roof ac's, one roof pod, awnings all around, rediline generator, lots of panels, gauges, and switches. This is a good running coach that may need a little fixing up and interior work but could be used as it is. Located in Jackson, MS. |
12-12-2005, 12:16
Hey,
This sounds like routine maintenance, It also sounds like it is worth the trouble and expense. The covers may not be available, but something could be made to fit. I will guess at $4 to 5K now and $5k more over the next year for the stuff that you do not know about yet. Have someone check it out, So there are no big surprizes. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "cobraheat1" <mike.meister@i...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > > > Mike- where is this coach located? Perhaps one of our members has > seen this > > coach? Ernie-83pt40 in Texas > > > > > > [Non-text portions of this message have been removed] > > > 1985 Wanderlodge FC 35' Rear Bath model Original Blue and Cream > exterior paint. Blue interior. Six new deep cycle coach batteries. > 12.5KW generator runs good has new battery. New Xantrex computerized > attery charger. Three roof ac's, one roof pod, awnings all around, > rediline generator, lots of panels, gauges, and switches. This is a > good running coach that may need a little fixing up and interior work > but could be used as it is. Located in Jackson, MS. > |
12-12-2005, 12:36
Hi Mike:
The '85 FC is a good coach. Need to check the power to the master switch for the HWH jacks. That switch enables the solenoid that is located to the front of the entry step under the coach. There are fuses (or at least there was in my '85FC) for the drive line retarder located in the main control box located just above the retarder proper. Also need to check the power from the retarder switch. Seems like both power enables to those switches go through "C" plug under the dash then on to the cb's and conversely to the enable solenoids. Those cb's are located behind the drivers front head light. Power steering pump I had rebuilt, not sure but in the neighborhood of 95.00. Ah, also check the bolts to the steering box and tighten them, bet a nickle they are lose as well. The ac covers, depends on what brand,, probably Brisk airs. Some are still available. I had some of those ok to drive local tires, then promptly had 2 blow outs. Tires are expensive but in the long run, cheap insurance, because these tires can take out wheel wells. Good luck with her. If I can help let me know. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 10:25 PM 12/12/2005 +0000, you wrote: >Hi all- >I am looking at a 85 FC '35 that looks to be in good shape but needs >the following repairs/maintenance. I would like to know what it would >cost for the following so I can figure it into the price. > >It has a recent oil change/lube and oil analysis >which showed normal. The tires are 5-6 years old and should be >replaced before a trip but are ok to drive local. The oil needs to be >changed in the front wheel bearings. The refrigerator and head have >already been replaced with newer models. The retarder is not working >and the leveling system is not working but both can be fixed. Two >roof ac's need covers. Power steering pump has a leak. > > >Thanks >Mike > > > > > > |
12-12-2005, 12:46
> > Hi Mike: > > The '85 FC is a good coach. > > Need to check the power to the master switch for the HWH jacks. That switch > enables the solenoid that is located to the front of the entry step under > the coach. > > There are fuses (or at least there was in my '85FC) for the drive line > retarder located in the main control box located just above the retarder > proper. Also need to check the power from the retarder switch. Seems like > both power enables to those switches go through "C" plug under the dash > then on to the cb's and conversely to the enable solenoids. Those cb's are > located behind the drivers front head light. > > Power steering pump I had rebuilt, not sure but in the neighborhood of > 95.00. Ah, also check the bolts to the steering box and tighten them, bet a > nickle they are lose as well. > > The ac covers, depends on what brand,, probably Brisk airs. Some are still > available. > > I had some of those ok to drive local tires, then promptly had 2 blow outs. > Tires are expensive but in the long run, cheap insurance, because these > tires can take out wheel wells. > > Good luck with her. If I can help let me know. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 10:25 PM 12/12/2005 +0000, you wrote: > >Hi all- > >I am looking at a 85 FC '35 that looks to be in good shape but needs > >the following repairs/maintenance. I would like to know what it would > >cost for the following so I can figure it into the price. > > > >It has a recent oil change/lube and oil analysis > >which showed normal. The tires are 5-6 years old and should be > >replaced before a trip but are ok to drive local. The oil needs to be > >changed in the front wheel bearings. The refrigerator and head have > >already been replaced with newer models. The retarder is not working > >and the leveling system is not working but both can be fixed. Two > >roof ac's need covers. Power steering pump has a leak. > > > > > >Thanks > >Mike > > > > > > > > > > > > > Thanks everyone. (I don't know anything about these things) Looks like it is safe to assume 5k in after purchase tires/maintenance. 1. Who does inspections in the midwest? 2. It also it has rear bath. Is that a positive/negative or moot point? |
12-12-2005, 12:58
Moot,,, personal preference,
Condition of coach is most important. Bill 88 Fc --- In WanderlodgeForum@yahoogroups.com, "cobraheat1" <mike.meister@i...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Mike: > > > > The '85 FC is a good coach. > > > > Need to check the power to the master switch for the HWH jacks. > That switch > > enables the solenoid that is located to the front of the entry > step under > > the coach. > > > > There are fuses (or at least there was in my '85FC) for the drive > line > > retarder located in the main control box located just above the > retarder > > proper. Also need to check the power from the retarder switch. > Seems like > > both power enables to those switches go through "C" plug under the > dash > > then on to the cb's and conversely to the enable solenoids. Those > cb's are > > located behind the drivers front head light. > > > > Power steering pump I had rebuilt, not sure but in the > neighborhood of > > 95.00. Ah, also check the bolts to the steering box and tighten > them, bet a > > nickle they are lose as well. > > > > The ac covers, depends on what brand,, probably Brisk airs. Some > are still > > available. > > > > I had some of those ok to drive local tires, then promptly had 2 > blow outs. > > Tires are expensive but in the long run, cheap insurance, because > these > > tires can take out wheel wells. > > > > Good luck with her. If I can help let me know. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 10:25 PM 12/12/2005 +0000, you wrote: > > >Hi all- > > >I am looking at a 85 FC '35 that looks to be in good shape but > needs > > >the following repairs/maintenance. I would like to know what it > would > > >cost for the following so I can figure it into the price. > > > > > >It has a recent oil change/lube and oil analysis > > >which showed normal. The tires are 5-6 years old and should be > > >replaced before a trip but are ok to drive local. The oil needs > to be > > >changed in the front wheel bearings. The refrigerator and head > have > > >already been replaced with newer models. The retarder is not > working > > >and the leveling system is not working but both can be fixed. Two > > >roof ac's need covers. Power steering pump has a leak. > > > > > > > > >Thanks > > >Mike > > > > > > > > > > > > > > > > > > > > > Thanks everyone. (I don't know anything about these things) > > Looks like it is safe to assume 5k in after purchase > tires/maintenance. > > 1. Who does inspections in the midwest? > > 2. It also it has rear bath. Is that a positive/negative or moot > point? > |
