Generator Switch Box
03-06-2013, 11:53
Post: #21
RE: Generator Switch Box
(03-06-2013 09:51)davidmbrady Wrote: Hish, David, You and the other LXI owners are lucky to be able to run 1 on an inverter. The inverters in the 95 are 2500 watts each so if what happened to you in the desert happened to me........hot would be an understatement! FWIW by middle and back AC's are on 1 leg, the front is on the other leg.
03-07-2013, 13:34
Post: #22
I can run all three cruise airs on mine with the genny no problem.
