Primus Parts
12-30-2005, 23:21
Primus Parts
Just ordered 2 circ pumps from Vechicle Systems.
Spoke with David Haynes a customer rep. Asked him if would recommend converson to webasto burner instead. He said no as long as primus burners are working its a good systmem. Mike with Bluebird said its one of the best systems they used only problem was availability of parts. Vehicle Systems website is vehiclesys.com Davids number is 1800-685-4298 his ext is 127. The part number was PLX-CM3-P71. Price was 192.50 each Hope this helps. I am going to have Foothill RV in Taylorsville NC put mine in. He says he is familiar and carries parts for primus. john redden 91PT40 [Non-text portions of this message have been removed] |
12-30-2005, 23:25
Primus Parts
to check the pumps you can change the power supply wire from the outside
post to the center post on the relay and get constant 12V power to the pumps. Then take a light and look in the resiviour tanks and see if you get the stream of water flowing into the tanks. If its there and strong then your pumps are ok. If not replacement would be a considered option. Bennie with BB told me about switching the wires to test the pumps. Call him if you have questions. David with Vehicle Systems agreed that the weak part of all hydronic systems is the circ pumps john redden 91PT40 [Non-text portions of this message have been removed] |
12-31-2005, 02:07
Primus Parts
Ihave a 92 WB coach with a Primus heat system. I think I need a
circulation pump, does anyone have any info where i can get replacement parts. |
12-31-2005, 02:29
Primus Parts
Get in touch with Stephen Birtles on this Forum. He carries Primus parts.
Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:07 PM 12/31/2005 +0000, you wrote: >Ihave a 92 WB coach with a Primus heat system. I think I need a >circulation pump, does anyone have any info where i can get >replacement parts. > > > > |
01-02-2006, 21:58
Primus Parts
--- In WanderlodgeForum@yahoogroups.com, jvredden@a... wrote:
> > to check the pumps you can change the power supply wire from the outside > post to the center post on the relay and get constant 12V power to the pumps. > Then take a light and look in the resiviour tanks and see if you get the > stream of water flowing into the tanks. If its there and strong then your pumps > are ok. If not replacement would be a considered option. Bennie with BB told > me about switching the wires to test the pumps. Call him if you have > questions. David with Vehicle Systems agreed that the weak part of all hydronic > systems is the circ pumps > > john redden 91PT40 > > > [Non-text portions of this message have been removed] >thank you for the info have a happy new year rick |
