Pulling the engine on a 83 FC
01-07-2006, 11:28
I have finally decided to fix the head leak on my otherwise cherry 83
FC . Pulling the heads on one of these does not look like any fun at all. I am considering pulling the whole engine so that if I find that the problem on the rebuilt engine is more than a simple gasket, I will have the option of changing out the engine. Has anyone pulled the engine before, if so how did you go about it, and what all had to be removed to get it out. I have tryed to find an acceptable engine to replace the 3208, but have not found anything that will reasonably fit and give me more horsepower. If there is an option I am willing to give it a go, but I do not want to reinvent the wheel. Jim Hutchings 83 FCRB Yorba Linda, CA |
01-07-2006, 20:06
I've got a 83FCRB I found in Texas, blown engine. Had it hauled to Milwaukee
and spent 18 months getting it ready for use. I have a lot of experience with the 3208, enough to know I would consider an alternative. There is none that will fit in the confines of the FC with out major modifications that are ill advised to undertake. Got my start with 3208s due to my L8000 Phord toter home that is so powered. I have spent way too much time and money making a hot rod out of the truck and I have succeeded. It's turned up to 375 hp marine specs and has a 13 speed Roadranger and 4:11 rear ratio. Loafs at 80 mph @ 2150 rpm. The problem with the bird is the small engine bay, nothing else comes close to fitting. Being familiar with the western topography, an FC is going to be a slow ride. My bird has a very well tuned 250 hp and it's a turd back here with no grades. Rolling hills give it a hard time, it won't keep up with the trucks, that's for sure. I plan on hanging a charge air cooler in front of the radiator and move the bumper ahead to accommodate. Will have to craft a radiator shell over the cooler to make it look good, this will enable the tune up to 300hp specs. I might have a chance of staying with most of the traffic after this work. My recommendation is install a fresh engine if you need to pull the heads. It's doubtful there is enough short block life remaining to justify cutting corners. Real hard to beat a reman Cat deal. There is no way I would consider tying to do a cylinder head service in chassis, but that's me. I used a reman engine from another source, engine is good but the injector pump went out at 4000 miles and the bastards didn't stand behind it. I'm lucky the engine is a good runner, no leaks and no oil consumption. Cat has a nation wide warrantee and tons of facilities. I don't love Cat or the 3208 however there are few choices with a FC. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: bluebird3208 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 07, 2006 5:28 PM Subject: [WanderlodgeForum] Pulling the engine on a 83 FC I have finally decided to fix the head leak on my otherwise cherry 83 FC . Pulling the heads on one of these does not look like any fun at all. I am considering pulling the whole engine so that if I find that the problem on the rebuilt engine is more than a simple gasket, I will have the option of changing out the engine. Has anyone pulled the engine before, if so how did you go about it, and what all had to be removed to get it out. I have tryed to find an acceptable engine to replace the 3208, but have not found anything that will reasonably fit and give me more horsepower. If there is an option I am willing to give it a go, but I do not want to reinvent the wheel. Jim Hutchings 83 FCRB Yorba Linda, CA SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
01-08-2006, 10:33
I am going to pull the engine on my 83 FC to do the heads. It seams
like this is the easiest way to get to everything, and insure a quaility job. If anyone has pulled the engine before please outline the basic steps. Or let me know if I am crazy to pull the engine. I have a nice flat spot and a forklift. Jim Hutchings 83 FC Yorba Linda CA |
01-08-2006, 11:59
Perhaps my posted response to your issue was missed or I didn't get to the main
question you asked. I have personally removed and replaced the whole drive train in a 83 FC, I used a fork lift under the front cross member and truck transmission jack under the transmission. Pulled the whole package out. I feel it would much more difficult to deal with the engine transmission separation in chassis. You may find the fly wheel inner bore, where the torque converter pilots, excessively worn. Very common problem and the flywheels can be difficult to find. It's acceptable to bore and resleeve. The converter pilot should be checked for size and roundness. I had my trans and converter rebuilt (150k miles) many hard parts needed replacement, consider the wisdom of stretching the service life of a Allison. I replaced all the accessories on the engine when it was out and replaced as a completed module. I did do some trimming on the frame rails for clearance and replaced the front airbags as they were very accessible with the drive train out of the way. I fitted the exhaust system with thermal blankets after the engine was in the hole, it would have been easier to do before installation. It's a tight fit but it sounds like you have the basic tools needed to do the job. If you do exchange the engine beware of the crank shaft fly wheel bolt discrepancy. Most cranks require some bolt holes to be plugged as some fly wheels don't use all the available holes. Missing that one results in a major oil leak. I wouldn't do the job with out a Cat engine shop manual # SEBRO541-03. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: bluebird3208 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, January 08, 2006 4:33 PM Subject: [WanderlodgeForum] Pulling the engine on a 83 FC I am going to pull the engine on my 83 FC to do the heads. It seams like this is the easiest way to get to everything, and insure a quaility job. If anyone has pulled the engine before please outline the basic steps. Or let me know if I am crazy to pull the engine. I have a nice flat spot and a forklift. Jim Hutchings 83 FC Yorba Linda CA ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
01-08-2006, 13:33
_____
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Sunday, January 08, 2006 4:00 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Pulling the engine on a 83 FC Perhaps my posted response to your issue was missed or I didn't get to the main question you asked. I have personally removed and replaced the whole drive train in a 83 FC, I used a fork lift under the front cross member and truck transmission jack under the transmission. Pulled the whole package out. I feel it would much more difficult to deal with the engine transmission separation in chassis. You may find the fly wheel inner bore, where the torque converter pilots, excessively worn. Very common problem and the flywheels can be difficult to find. It's acceptable to bore and resleeve. The converter pilot should be checked for size and roundness. I had my trans and converter rebuilt (150k miles) many hard parts needed replacement, consider the wisdom of stretching the service life of a Allison. I replaced all the accessories on the engine when it was out and replaced as a completed module. I did do some trimming on the frame rails for clearance and replaced the front airbags as they were very accessible with the drive train out of the way. I fitted the exhaust system with thermal blankets after the engine was in the hole, it would have been easier to do before installation. It's a tight fit but it sounds like you have the basic tools needed to do the job. If you do exchange the engine beware of the crank shaft fly wheel bolt discrepancy. Most cranks require some bolt holes to be plugged as some fly wheels don't use all the available holes. Missing that one results in a major oil leak. I wouldn't do the job with out a Cat engine shop manual # SEBRO541-03. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: bluebird3208 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, January 08, 2006 4:33 PM Subject: [WanderlodgeForum] Pulling the engine on a 83 FC I am going to pull the engine on my 83 FC to do the heads. It seams like this is the easiest way to get to everything, and insure a quaility job. If anyone has pulled the engine before please outline the basic steps. Or let me know if I am crazy to pull the engine. I have a nice flat spot and a forklift. Jim Hutchings 83 FC Yorba Linda CA Thanks for the post. I may replace the engine with a rebuild if I do not find an obvious head gasket leak. Then engine and trans only have 20,000 miles on them since rebuild. The problem was I was not the one who did the rebuild. The previous owner reused the head bolts, and one of them snapped. I managed to get the old bolt out in frame and replace it but the damage was done. Thanks for the tips, I have redone every oil gasket on the engine and stopped all the leaks but one.. The rear seal area, Ill bet it is the lack of bolts in the fly wheel. Jim Hutchings 83 FC Yorba Linda CA ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
01-08-2006, 15:47
--- In WanderlodgeForum@yahoogroups.com, "bluebird3208"
wrote: > > I have finally decided to fix the head leak on my otherwise cherry 83 > FC . Pulling the heads on one of these does not look like any fun at > all. I am considering pulling the whole engine so that if I find that > the problem on the rebuilt engine is more than a simple gasket, I will > have the option of changing out the engine. Has anyone pulled the > engine before, if so how did you go about it, and what all had to be > removed to get it out. I have tryed to find an acceptable engine to > replace the 3208, but have not found anything that will reasonably fit > and give me more horsepower. If there is an option I am willing to > give it a go, but I do not want to reinvent the wheel. > > Jim Hutchings > 83 FCRB > Yorba Linda, CA Jim this Jon up here in Washington and I was wondering how you determind that you had a head leak? And the other question is how many miles do you have on your FC. I'm kind of interested just to know as I know some of these engines run for 300 thousand miles and no problem and Im trying figure out what will cause one of these engines to fail at low miliage. Jon Jon Lechich 1978 Wanderlodge Bremerton Washington > |
01-09-2006, 04:04
_____
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon Sent: Sunday, January 08, 2006 7:48 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Pulling the engine on a 83 FC --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > I have finally decided to fix the head leak on my otherwise cherry 83 > FC . Pulling the heads on one of these does not look like any fun at > all. I am considering pulling the whole engine so that if I find that > the problem on the rebuilt engine is more than a simple gasket, I will > have the option of changing out the engine. Has anyone pulled the > engine before, if so how did you go about it, and what all had to be > removed to get it out. I have tryed to find an acceptable engine to > replace the 3208, but have not found anything that will reasonably fit > and give me more horsepower. If there is an option I am willing to > give it a go, but I do not want to reinvent the wheel. > > Jim Hutchings > 83 FCRB > Yorba Linda, CA Jim this Jon up here in Washington and I was wondering how you determind that you had a head leak? And the other question is how many miles do you have on your FC. I'm kind of interested just to know as I know some of these engines run for 300 thousand miles and no problem and Im trying figure out what will cause one of these engines to fail at low miliage. Jon Jon Lechich 1978 Wanderlodge Bremerton Washington >The failure on this engine is due to the fact that the previous owner used the old head bolts to reassemble the engine without testing them first. I know I have a leak due to three things: The engine overheats slightly. There are air bubbles and too much pressure in the radiator. I purchased a product of combustion detector made for radiators and the test showed exhaust gas in the radiator. In addition I had a water leak at a head bolt. When I tried to tighten it, it snapped. I managed to remove it in frame and replace it, but the damage was done long ago. So to answer your question the engine did not fail. the mechanic did. This is turbo charged model generating 250 HP, these engines can be pushed up to 425 HP but only in marine use. Why? because in the ocean you have unlimited cooling capacity. So the main enemy of these engines in over the road vehicles is heat. If you take them up a grade on a hot day and lug them the whole way it is just a matter of time. Early failures are due to improper build, maintenance, and operator abuse. Other than that they will go a long time. Jim Hutchings > 83 FCRB > Yorba Linda, CA _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
