Headlight Relay - Searching
02-24-2006, 10:37
Getting ready to install headlight relays...
I'm not finding a battery combiner. Anyone know where it might be located on a 1987 PT38? I wonder if BB did not install one. I do find an insulated terminal in the gen. compartment. That terminal has two cables. One coming from way back in the coach, the other goes to the gen. battery +. With the 8V92 running, or with the battery chargers, not at the same time, that terminal tests about 14.4 volts. Remove the feed and the terminal tests 13.8 and continues to decrease to lower volts. Seems to me that terminal could be used to feed #30 on the headlight relays. Another option, maybe... I opened up the front of the bus and find 2 open circuit breakers, 10A each, 14.3 volts. The feed to that bus bar is at least a #10 wire and could be a #8. The Silver Star headlights draw a little over 4 amps. Am I safe using the 2 open circuits? I can replace the 10 amp circuit breakers with 20 or 30 amp breakers. Any and all input is appreciated. -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
02-24-2006, 11:45
Hi Curt,
I used the empty breakers you mentioned on my PT and on a friend's FC. In both cases, I ran 10 ga. wire to each relay from the empty breaker. If using standard Bosch relays, be sure to smear a ton of silicone on the end where the connectors go (after attaching them). Any moisture at all will ruin them- there can be no slits or openings for the moisture to get in. I had two fail, even with silcone, because I missed a few spots. Since sealing them up, no problems. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Getting ready to install headlight relays... > I'm not finding a battery combiner. Anyone know where it might be > located on a 1987 PT38? I wonder if BB did not install one. I do find an > insulated terminal in the gen. compartment. That terminal has two > cables. One coming from way back in the coach, the other goes to the > gen. battery +. With the 8V92 running, or with the battery chargers, not > at the same time, that terminal tests about 14.4 volts. Remove the feed > and the terminal tests 13.8 and continues to decrease to lower volts. > Seems to me that terminal could be used to feed #30 on the headlight > relays. > > Another option, maybe... > I opened up the front of the bus and find 2 open circuit breakers, 10A > each, 14.3 volts. The feed to that bus bar is at least a #10 wire and > could be a #8. The Silver Star headlights draw a little over 4 amps. Am > I safe using the 2 open circuits? I can replace the 10 amp circuit > breakers with 20 or 30 amp breakers. > > Any and all input is appreciated. > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
