Ramco mirrors
03-04-2006, 05:52
Ramco mirrors
I am going to repaint my ramco mirrors and would like to know what the procedure
is removing them,are the motors in the mirror head? or are they elsewhere and
controlled with cables?
If the motors are in the head I would think there is a wire loom disconnect
somewhere close to the bracket mount.
Thanks in advance.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge PT41
03-04-2006, 06:05
Ramco mirrors
I had mine off my 89 SP & there was a plug just under the base that mounts on
the coach. Unplug it & then the wires will feed up through the arm & in to the
mirrors. Hope this helps. Ramco heat remote with motor in the head
Don
89 SP 36'
Butler, PA In Cocoa, FL
-----Original Message-----
To: wanderlodgeforum@yahoogroups.com
Sent: Sat, 4 Mar 2006 10:52:50 -0700
Subject: [WanderlodgeForum] Ramco mirrors
Thanks in advance.
Fred & Jeanne Hulse
Morristown Arizona
Yahoo! Groups Links
03-04-2006, 06:10
Ramco mirrors
Hi Fred,
The motors are in the head and there is a multiple wire cable that
goes from the controls to the head. Normally the pigtail that comes
from the head is "butt connected" to the main cable. Putting a plug
type disconnect would be unusual though possible. If you have to cut
the wires, be certain to note the color coding so you can put it back
the same.
George Lowry
'06 Alpine Apex - Formerly '95 WBDA 4203
Spearfish, SD - now in Gila Bend, AZ
procedure is removing them,are the motors in the mirror head? or are they
elsewhere and controlled with cables?
> Thanks in advance.
> Fred & Jeanne Hulse
> Morristown Arizona
> Yahoo! Groups Links
03-04-2006, 07:19
Ramco mirrors
Don
Thanks for the help,I was hoping there would be a plug,and the motors in the
head.
We will get after it!
Fred & Jeanne Hulse
Morristown Arizona
03-04-2006, 07:22
Ramco mirrors
George
Thanks for the information and help,I am grateful it is that simple.
How long are you going to be in Gila Bend?
Fred & Jeanne Hulse
Morristown Arizona
03-04-2006, 09:48
Ramco mirrors
Hi Fred,
We are departing Gila Bend on Monday heading for Wilderness Lakes TTN
for about ten days and then heading into Pomona for the FMCA
Convention. From there we are going to Las Vegas TTN for a couple of
weeks then up to Norcal for a rally and Dr.'s appointments. After the
grandson's wedding, heading north for the cool weather....
George
Fred Hulse wrote:
> George
> Fred & Jeanne Hulse
> Morristown Arizona
> Yahoo! Groups Links
03-04-2006, 15:35
Ramco mirrors
George,
We will have a litle time later this month and was going down to Ajo for a
few days and
was hoping to stop and visit,but we will see you next fall maybe.
Thanks for the information on the mirrors.
Fred & Jeanne Hulse
Morristown Arizona
George
10-27-2009, 14:50
Ramco mirrors
InVue,...ZONE DEFENSE accident avoidance systems...anyone made a purchase? Experience?
http://www.ramco-eng.com/InVue/InVue.htm
I received the aluminum (plastic no longer available) split shells (that's what I call them) from Ramco Engineering. They anchor the mirror head ball to the arm. Ramco shipped them at not cost to me. Installed the drivers side today. The mirror sits a little lower in the ball vs. the plastic split shells...guess this is good. Used PB Blaster and worked the two set screws out after several hours and playing with them. Coated the new shells with Anti-Seize, the set screws too, and all seems to be good.
Curt Sprenger
Anaheim Hills, CA
10-28-2009, 10:25
Ramco mirrors
Curt,
that sounds really interesting. Would you please post a photo of this
mirror instlled on your coach?
TIA,
Liz Pearce
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
D'Hanis, TX
Buena Vista, CO
Currently in Spring Branch, TX
> *InVue*,...ZONE DEFENSE accident avoidance systems...anyone made a
purchase?
> Experience?
(that's
ball
drivers side
split
screws
with
> Curt Sprenger
> Anaheim Hills, CA
10-28-2009, 10:47
Ramco mirrors
Liz,
The first paragraph I was inquiring about that mirror. http://www.ramco-eng.com/InVue/InVue.htm .
The second paragraph I was reporting the fix to our mirror problem. Sorry for the confusion.
Curt Sprenger
Anaheim Hills, CA
On Wed, Oct 28, 2009 at 2:25 PM, homesicktexans_33009 <"jacklizpearce@gmail.com"> wrote:
Curt,
TIA,
Liz Pearce
Regards,
Jack and Liz Pearce
D'Hanis, TX
Buena Vista, CO
--- In "WanderlodgeForum%40yahoogroups.com", Curt Sprenger
purchase?
> Experience?
(that's
ball
drivers side
split
screws
with
> Curt Sprenger
> Anaheim Hills, CA
