Chassis A/C
08-21-2005, 09:02
Chassis A/C
Does any one happen to know where the T-stat switch
for the chassis A/C on a 1991 SP36 is located. My
system would love to work but the compressor will not
kick in unless jumped. Then it works,so i supect the
T-Stat switch fails to tell the compressor "ITS HOT
MAN, START COOLING....". All other stuff works, so no
C/B popped etc. Randy? Jeff? Mike? George?
Juergen in PA
1991 WLSP36
Do You Yahoo!?
http://mail.yahoo.com
08-21-2005, 12:58
Chassis A/C
Juergen, In my 90 SP it is located on the drivers side in the upper
dash overhead compartment. But just a thought. If your system has a
low pressure switch?? That could be the problem too.
Tom 90 SP36
--- In WanderlodgeForum@yahoogroups.com, john duke
> Juergen in PA
> 1991 WLSP36
> Do You Yahoo!?
08-21-2005, 15:00
Chassis A/C
I don't know the specifics of the coach, but mobile air
thermostats are located at the evaporator (the actual cooling
coils for the AC). There will be a copper tube
that leads to it.
If it's the pressure switch, that's usually under
the hood and has a 2 wire switch to it. You can unplug
the switch and put a jumper wire connecting the
2 connectors together. Then the compressor should
come on.
It will look like an oil pressure sending unit screwed
into the AC line with 2 wires coming off it.
Hope this helps.
George Witt
81 FC 35
Lincoln, Nebraska
> Tom 90 SP36
> > Juergen in PA
> > 1991 WLSP36
> > Do You Yahoo!?
08-22-2005, 15:25
Chassis A/C
Hi John,
Don't know about your coach, but I found out on my coach that I had to
turn on the blower before the compressor will come on. There is also
a compressor switch on the heat/AC control panel. Once I found those
two, it works great.
George
> Juergen in PA
> 1991 WLSP36
> Do You Yahoo!?
> Yahoo! Groups Links
03-04-2006, 08:05
Chassis A/C
Before an after a 100 mile drive I checked to see if the compressor
was clutching-up and it wasn't. Does anyone know what kind of
circuit breakers or fuses are in the compressor control path? a
schematic would be very useful. I have a decent set of tools with
me so any suggestions for diagnosing are greatly appreciated.
Thanks again,
David Brady
'02 LXi, Smokey, Va
Gregory OConnor wrote:
>David, does the engine fan clutch up? did you try this with the
>engine running and warm and the interior thermostat set lower than
>interior temp? some systems will not clutch up during startup of the
>vehicle. I have a 92 cummings M14 in a truck that stores codes for
>the ac functions. Having the computer read reveals volumns.
>Greg--- In Wanderlodge_all@yahoogroups.com, David Brady
>wrote:
>>Folks,
>>My chassis air conditioning isn't working. I haven't
>>found any blown fuses or circuit breakers. The control
>>switch wiring looks okay. If I turn on the key and toggle
>>the dash ac switch I don't see any voltage changes on the
>>wires going to the compressor (in the engine compartment),
>>nor do I hear any relay chatter. The compressor doesn't
>>seem to be engaging. Any ideas on what I can check?
>>Thanks,
>>David Brady
>>'02 LXi, Smokey, Va
>>No virus found in this outgoing message.
>>Checked by AVG Free Edition.
>>Version: 7.1.375 / Virus Database: 268.1.1/272 - Release Date:
>3/1/2006
>Yahoo! Groups Links
Version: 7.1.375 / Virus Database: 268.1.2/274 - Release Date: 3/3/2006
03-04-2006, 08:15
Chassis A/C
David:
If your talking about the Coach aA/C compressor, it should be fuses 5 and 6
that control that.
Ralph
>Thanks again,
>David Brady
>'02 LXi, Smokey, Va
> >wrote:
> >>Folks,
> >>Thanks,
> >>David Brady
> >>'02 LXi, Smokey, Va
> >3/1/2006
> >Yahoo! Groups Links
>Yahoo! Groups Links
Safe travels,
03-04-2006, 10:01
Chassis A/C
David,
Had a similar problem with our '95 bird. At the compressor, you should
find a wire that goes to the clutch. Mine had a connector that I could
unplug, If it is a butt connector, just cut the wire. Two checks.
First; with the key in the on position and the A/C controls set for
cooling, check the wire end that comes from the harness for 12 volts.
If you are not getting 12 volts, you probably have a blown fuse or
other similar problem. Second; using an ohm meter, check the wire
going to the clutch for continuity. The clutch is internally grounded
so you should get a very low resistance reading. If it shows infinite
resistance, the clutch coil is open and needs to be replaced. A
confirming test is to use a jumper wire and connect 12 volts to the
wire to the clutch. If the clutch is ok, it will pull in. That will
give you a starting point.
George Lowry
'06 Alpine Apex - Formerly '95 Wbda 4203
Spearfish, SD Now in Gila Bend, AZ
> Thanks again,
> David Brady
> '02 LXi, Smokey, Va
>>wrote:
>>>Folks,
>>>Thanks,
>>>David Brady
>>>'02 LXi, Smokey, Va
>>3/1/2006
>>Yahoo! Groups Links
03-04-2006, 12:21
Chassis A/C
Thanks Ralph, at which load center are those fuses located.
I have a load center at the rear of the bus, one above the
pilot area, and one at the copilot's footwell. There's
also a fuse/relay box on the outside of the bus below the
pilot's side window.
Thanks,
David Brady
'02 LXi, Smokey, Va
Ralph L. Fullenwider wrote:
>David:
>that control that.
>Ralph
>>Thanks again,
>>David Brady
>>'02 LXi, Smokey, Va
>>>wrote:
>>>>Folks,
>>>>Thanks,
>>>>David Brady
>>>>'02 LXi, Smokey, Va
>>>3/1/2006
>>>Yahoo! Groups Links
>>Yahoo! Groups Links
>Safe travels,
>Yahoo! Groups Links
03-04-2006, 12:22
Chassis A/C
Thanks for the suggestion Randy, but no go on the wiggle.
I'll be visition Josam's in Orlando on Monday, maybe they
can have a look at it.
David
'02 LXi, Smokey, Va
randydupree wrote:
>if you wiggle the wires on the low pressure switch on the compressor does it
>make it work? i have to do this alot on the GM cars we have. with the ac
>turned on,engine running,wiggle the wires on the comp. and on the hoses..
>randy
>----- Original Message -----
>From: "David Brady"
>To:
>Sent: Saturday, March 04, 2006 2:56 PM
>Subject: Re: [Wanderlodge_all] Re: Chassis A/C
>>Thanks again,
>>David Brady
>>'02 LXi, Smokey, Va
>>>wrote:
>>>>Folks,
>>>>Thanks,
>>>>David Brady
>>>>'02 LXi, Smokey, Va
>>>3/1/2006
>>>Yahoo! Groups Links
>>Yahoo! Groups Links
>Yahoo! Groups Links
03-04-2006, 12:58
Chassis A/C
Dave:
It should be in the outside electrical compartment.
Ralph
>Thanks,
>David Brady
>'02 LXi, Smokey, Va
> >David:
> >that control that.
> >Ralph
> >>Thanks again,
> >>David Brady
> >>'02 LXi, Smokey, Va
> >>>wrote:
> >>>>Folks,
> >>>>Thanks,
> >>>>David Brady
> >>>>'02 LXi, Smokey, Va
> >>>3/1/2006
> >>>Yahoo! Groups Links
> >>Yahoo! Groups Links
> >Safe travels,
> >Yahoo! Groups Links
>Yahoo! Groups Links
Safe travels,
