Diesel Smell
03-07-2006, 13:33
Diesel Smell
Good point, George. I had the diesel smell in my bays on the '95
for the first few months. Strong when opening a bay door. I had
the AquaHot fully serviced when it stopped firing and the diesel
smell disappeared. Worth a try.
Tom McCarthy
--- In WanderlodgeForum@yahoogroups.com, George Lowry
> Jim,
> Vehicle Systems had a problem with the fuel pump in the Aquahot
> leaking a few years ago. Mine did in the '95 Bird. Took me quite a
> while to find it. Meanwhile all the carpeting in the bays were
soaked.
> Got most of it out by soaking the carpet with vinegar, vacuuming.
then
> washing with soap an water with lots of vacuuming.
> The leak could be in either the supply or return lines of either
> generator or the Aquahot. I think that BB should stand behind it
also.
> George Lowry
> '06 Alpine Apex - Formerly '95 WBDA 4203
> Spearfish, SD - Enroute to Wilderness Lakes TTN, CA
> Scott wrote:.
> > Jim, a 04 M380, lemme get this right (at the risk of being a
smart a$$)
> > You paid several hundred thousand for a new coach and it smells
like
> > diesel, and has for some time. I am sure you have contacted BB
for
> > advise and to fix the problem, under warranty of course! Just
curious
> > what they said and have done. Ya know they resevered 14+million
for
> > warranty issues, in their self professed revival. None the less
what
> > did they say?? Have they left you to figure it out yourself??
Some
> > time soon, I know that they will be sending a tech with a coach
(a new
> > 450) to the left coast to redeliver it since in appx a year the
coach
> > has had several "false starts" This coach has never made it to
the home
> > of the owner! Last attempt it made it appx 100 miles from Ft
Valley!
> > Maybe, the Tech could come to your location when delivering that
coach.
> > Anyway, I rememeber a post from another owner on this forum that
had a
> > similar issue. Jim Scoggins owns a M380 (not his coach leaking)
and is
> > very knowledgable owner. (mebbe he will chime in here) but I
think they
> > had fuel leaking into one of the bays as well. There has to be a
fuel
> > line as Greg suggests leaking. Keep in mind that diesel can
follow a
> > fuel line for a long ways before finally dripping off.
Especially, if
> > the coach sits in one place for any period of time. I would
check very
> > closely the heating system for a fuel leak, this may take some
> > creative thinking and lots of flashlight batteries. Can you see
> > fuel line from underneath the coach (be very careful) from the
fuel
> > tank forward? What about the top, sides of the storeage bays,
you have
> > access to the rear of the refer? A fuel leak around a flame is a
very
> > dangerous issue. I would think it is somewhat of a small leak
(even
> > though it probably smells like a refinery) otherwise you would
see fuel
> > dripping on the pavement, or the underside of the coach and/or
your
> > towed and the back of the coach would look like it has a sheen,
or
> > specks of road dust from the diesel fuel.
> > Best of luck and hope you get to the bottom of this. Let us know
what
> > you find.
> > Scott B
> > 86FC35
> > SC
> > --- In WanderlodgeForum@yahoogroups.com, "sizzbiz2" <sizzbiz2@>
> > wrote:
> >>We have a 2004 M380 and despite the efforts of the factory, we
> > continue
> >>to get the smell of raw diesel in the coach as well as in the
first
> >>three bins. The smell in the coach seems to come in via the
heater
> >>vents and from the air intake vent under the refrigerator.
> >>I would appreciate knowing of others who have had this problem
> > what
> >>solutions have been developed.
> >>Thanks for the help.
> >>Jim McGinnis
> >>M380 # 151
> >>Los Angeles
> > Yahoo! Groups Links
03-07-2006, 18:12
Diesel Smell
Curt, Kerry, maybe you could enlighten me. First of all, would you
please tell me how long it takes diesel fuel to evaporate, I have a
spot in my drive! As we all know diesel has alot of oil in it.
While I fully understand how the tester works I am struggling with
this application. The tester while very sensitive, does not "think".
If a fuel leak were to travel down a wire loom, or along a frame rail
and then drip, would the sniffer take you to the source of the leak?
I would think that it sniffs you to the highest concentration of the
source. THE DRIP! NOT THE LEAK. The real solution, finding the leak,
might be 15ft away. I am sorry visual inspection is necessary! (Jim,
you gotta have batteries) If the leak drips onto the carpet in the
bay in this case, and you sniff within inches, it will sound off like
a banshee, corrrect? Again, the highest concentration of the
hydrocarbons (uh was that the term?). But the fitting 15' down the
fuel line is actually the cause "the leak" Curt, in your test you
were getting closer to the source fuel in the tank. I realize we have
gotten off topic, somewhat, but I am trying to help Jim keep from
chasing dead ends with the wrong tester...seems he has done enough of
that. His heating system is probably the culpret.
Maybe I am the one that was sleeping in science class, but I was sure
awake during "problem solving"
Scott B
86FC35
Murrells Inlet SC "just a redneck with a brain and a bird"
> Kerry,
> Seems that would work. I just went out and used my elec. sniffer at
> fuel tank filler neck. At the top of the opening the sniffer
squeals
> some. The squeal intensifies as the the sniffer is moved in the
> direction of the diesel fuel.
> Curt Sprenger 1987 PT38, Anaheim Hills, Calif.
> davidkerryedwards wrote:
> > If they are detecting hydrocarbons, I don't see why it wouldn't
work
> > on diesel. I've used my relatively cheap version to trace natural
> > gas leaks, and I've watched Public Service people use them to
trace
> > a leak back to its source. The smell must be evaporated diesel
> > the concentration will be higher near the source. Why not?
> > Kerry
> > --- In WanderlodgeForum@yahoogroups.com, "Scott"
> > wrote:
> > > Kerry, FYI several members have such a "sniffer" they are great
> > tools
> > > for propane leaks, ac leaks, even natrl gas leaks...BUT for a
fuel
> > > leak??? You may not know or have had enough experiance with
diesel
> > > fuel. Diesel fuel is very oily and can run a long way on a fuel
> > line,
> > > wiring harness, structural support among other things, then drip
> > on top
> > > of some carpet in the storage bay. Generally, all are obvious
upon
> > > visual inspection. Are telling me that the "sniffer" can follow
> > that
> > > leak back to the source better than a visual inspection??? Mebee
> > on the
> > > left coast they have such a tool but here on the right coast I
> > have not
> > > seen one. George is the member I was thinking about and he
is "on"
> > it
> > > now..Good luck Jim with the leak..
> > > Scott B
> > > 86FC35
> > > SC
> > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards"
> > > wrote:
> > > > If I'm not mistaken, the leak detectors the Public Service
> > companies
> > > > use to detect gas leaks in houses are hydrocarbon detectors.
If
> > you
> > > > could rent or borrow one, and set the sensitivity level
> > appropriately,
> > > > I think it would be possible to trace back the smell to the
area
> > of
> > > > highest concentration. Those detectors are much more
sensitive
> > than
> > > > our noses and this would be much better than a visual
inspection.
> > > > Kerry
> > SPONSORED LINKS
> > Recreational vehicles
> > <http://groups.yahoo.com/gads?
t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w
3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O
bWmSYTw>
> > Wanderlodge
t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti
ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh
icles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
> > Automotive maintenance
t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&
w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34
cC1O9CxA>
> > Recreational vehicle dealer
t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl
odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+
recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY
HfELr6o72IW1A>
> > Used recreational vehicles
t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo
dge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+r
ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-
kXbDI4ZSadEw>
> > Automotive radiators
t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3
=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat
ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq
_4GlXA>
> > YAHOO! GROUPS LINKS
> > * Visit your group "WanderlodgeForum
> > <http://groups.yahoo.com/group/WanderlodgeForum>" on the
web.
> > * To unsubscribe from this group, send an email to:
> > WanderlodgeForum-unsubscribe@yahoogroups.com
> > subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/>.
03-08-2006, 01:22
Diesel Smell
Jim, It sounds like the oder source is key to your repair. As Curt
said the Sniffer may be the best tool. In the very least it would
document the existance of a problem that the manufacturer has with
their underwarranty product. After reading the helpful responces to
your post, I would isolate each diesel appliance and rule them out one
ata time. ( now I would start with P test on Aquahot supply) Without
reguard to who must or should do the repairs, you truly need a repair.
AZ Bus 800-843-1287 ( near Ontario Ca airport) may have a fresh set of
mechanics to solve the problem. I see Wanderlodge coaches in their
facility all the time. With their relationship to Bluebird, they may be
able to talk with the tech that returned your coach unrepaired and
avoid retesting the proven appliances. The next step is to call Curt,
he can fix anything
--- In WanderlodgeForum@yahoogroups.com, "sizzbiz2" <sizzbiz2@...>
continue
> to get the smell of raw diesel in the coach as well as in the first
> three bins. The smell in the coach seems to come in via the heater
> I would appreciate knowing of others who have had this problem and
what
> Jim McGinnis
> M380 # 151
> Los Angeles
03-08-2006, 01:48
Diesel Smell
You will never find the leak using a sniffer on diesel fuel. The
simplest was is to use dye in the system you are trying to find a
leak in. Tracer products makes a full line of additives for this
purpose. Buy a bottle of Dye-Lite TP3700, add it to your diesel fuel
and then you can find even the smallest leak with a UV light. It
costs about $20.
http://www.tracerline.com/faq.html
http://www.tooldesk.com/products/default.aspx+searchString+Dye%20Lite
Tom Warner
1982 FC35
Vernon Center,NY
>Scott B
>86FC35
> > Kerry,
>the
>squeals
>work
>trace
>and
> > > Kerry
> > > tools
>fuel
>diesel
> > > line,
> > > on top
>upon
> > > that
> > > on the
> > > have not
>is "on"
> > > it
> > > > Scott B
> > > > 86FC35
> > > > SC
> > > companies
>If
> > > you
> > > appropriately,
>area
> > > of
>sensitive
> > > than
>inspection.
> > > > > Kerry
> > > SPONSORED LINKS
> > > <<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?
>bWmSYTw>
> > > Wanderlodge
>cC1O9CxA>
>HfELr6o72IW1A>
>kXbDI4ZSadEw>
>_4GlXA>
> > > YAHOO! GROUPS LINKS
<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/W\
anderlodgeForum>"
> on the
>web.
> > > Service
> <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>.
>SPONSORED LINKS
ObWmSYTw>Recreational
>vehicles
anderlodge
4cC1O9CxA>Automotive
>maintenance
YHfELr6o72IW1A>Recreational
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
03-08-2006, 12:08
Diesel Smell
Is this true? I admit that I haven't tried it, but mine has been able
to find LP, Freon, even anti-freeze (Glycol).
Following this post I was thinking that might be another use for the
detector, why won't it work?
- Jeff Miller
in Holland, MI
> You will never find the leak using a sniffer on diesel fuel.<<snip>>
03-08-2006, 13:35
Diesel Smell
No joke Jeff. Do you suppose it might find bad bathroom smell origins????
Rob, Sue & Merlin
94 WLWB
Quoting Jeff Miller :
> - Jeff Miller
> in Holland, MI
> SPONSORED LINKS
> Wanderlodge
> YAHOO! GROUPS LINKS
> Visit your group "WanderlodgeForum" on the web.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
03-08-2006, 13:42
Diesel Smell
If it's methane I don't see why not. Easy test. Eat some beans and
pull out the tester.
Kerry
origins????
> Rob, Sue & Merlin
> 94 WLWB
> > - Jeff Miller
> > in Holland, MI
> > SPONSORED LINKS
> > Wanderlodge
> > YAHOO! GROUPS LINKS
Service.
03-08-2006, 13:47
Diesel Smell
Rob,
The sniffer will probable do that, Rob. That's how I determined where
the toilet tank stink is coming from in our Bird.
> Rob, Sue & Merlin
> 94 WLWB
> > - Jeff Miller
> > in Holland, MI
> > SPONSORED LINKS
> > Wanderlodge
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
03-08-2006, 17:16
Diesel Smell
Hmmmmmmmm. Would you possibly be bringing said 'stink sniffer' to rally?????
Rob, Sue & Merlin
94 WLWB
Quoting Curt Sprenger :
> Rob,
> > Rob, Sue & Merlin
> > 94 WLWB
> > > - Jeff Miller
> > > in Holland, MI
> > >     SPONSORED LINKS
> > >         Wanderlodge
> > >   YAHOO! GROUPS LINKS
> > SPONSORED LINKS
t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot
ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6
=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>
> >       Wanderlodge
t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainte
nance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotiv
t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automo
tive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w
6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>
t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=A
utomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehic
les&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>
t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au
tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicl
es&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>
t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti
ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=
Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> Wanderlodge
> YAHOO! GROUPS LINKS
03-09-2006, 03:42
Diesel Smell
Rob,
I'll bring the 'stink sniffer' to the rally.
> rally?????
> Rob, Sue & Merlin
> 94 WLWB
> > Rob,
> origins????
> > > Rob, Sue & Merlin
> > > 94 WLWB
> able
> > > > - Jeff Miller
> > > > in Holland, MI
> fuel.<<snip>>
> > > > SPONSORED LINKS
> > > > Wanderlodge
> > > > YAHOO! GROUPS LINKS
> Service.
> > > SPONSORED LINKS
> > > Wanderlodge
> > > YAHOO! GROUPS LINKS
> > SPONSORED LINKS
> > Wanderlodge
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
bWmSYTw>
> Wanderlodge
cC1O9CxA>
HfELr6o72IW1A>
kXbDI4ZSadEw>
_4GlXA>
> YAHOO! GROUPS LINKS
