Television
03-12-2006, 15:13
Television
I have several questions about the TV in my 1983 FC-35.
the TV screen comes on no rear picture, but the previous owner
installed a 5" tv on the dash and the back up camera works fine on
this TV.
Is the silver box located above the drivers seat the actual TV? when i
move some on the knobs i see movement on the TV sreen ( the orginal TV
screen)verical, contrast etc.
has anyone had one of these units repaired?
can i installed another TV in place of the orginal and get rid of the
silver box.?
is there an indicator that shows the TV antenna is rotating?
does the CB radio run through the silver box?
how is the silver box mounted, mine is setting loose on the shelf.
That for all the help I know I will get, this is a great site and you
folks have a lot of knowledge
re brake 1983 FC-35
03-12-2006, 15:19
Television
"The silver box" is part of the electronics for the Cathode Ray tube
mounted over the front of the driver. PMMI took apart a TV set and
put part of it in the "Silver Box" and part in the overhead in front
of the driver. There is really not enough room to replace the TV
screen with a TV so I made a cherry cabinet mounted on too of the dog
house for mine. I repaired mine and it works fine now.
tom warner
1982 FC35
Vernon Center,NY
>this TV.
>silver box.?
>re brake 1983 FC-35
>SPONSORED LINKS
ObWmSYTw>Recreational
>vehicles
anderlodge
4cC1O9CxA>Automotive
>maintenance
YHfELr6o72IW1A>Recreational
>vehicle dealer
-kXbDI4ZSadEw>Used
>recreational vehicles
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
03-13-2006, 09:23
Television
Years ago, when we had our 84 35fC, we set a color tv on the doghouse.
Something happened to the color in that set.Is there any electrical field that
may
have interfered with the color on that tv- or was it the tv's time to go
south? Ernie-83pt40 in louisiana
03-13-2006, 14:02
Television
Thanks Tom: am i to understand you repaired the silver box.? when you installed
the TV on the dog house do you use the TV connector on the floor by the
co-pilot. where is your back up monitor??i was thinking of installing it in
place of the orginal TVscreen. Thanks again for responding.
-------------- Original message from Tom Warner :
tom warner
1982 FC35
Vernon Center,NY
>this TV.
>silver box.?
>re brake 1983 FC-35
>SPONSORED LINKS
>vehicles
anderlodge
>maintenance
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
YAHOO! GROUPS LINKS
03-14-2006, 09:11
Television
you are probably correct, Jeff. of course when you buy cheap stuff~
ernie-headed to texas in am
03-14-2006, 13:47
Television
A TV on the doghouse can use the antenna connection at the co-pilot's
feet.
The "silver box" is the TV electronics for the backup monitor, a
Toshiba AC/DC color TV is split in two for the installation. If the
TV still works properly, and they're pretty durable, it makes an
excellent backup monitor. One issue with these monitor sets is the
original RCA Vidicron-tube camera, not very good at this age. The
monitor is color, you can use it with a color camera, the problem
becomes reversing the video in the TV to accomodate a new-style
camera. This is easily accomplished by reversing the red and blue
wire in the four-wire connector in the tuner-box/siver-box, just
reversing the wires shouldn't take more than 15minutes.
- Jeff Miller
in Holland, MI
you installed the TV on the dog house do you use the TV connector on
the floor by the co-pilot. where is your back up monitor??i was
thinking of installing it in place of the orginal TVscreen. Thanks
> -------------- Original message from Tom Warner : ----
tube
front
dog
> tom warner
> 1982 FC35
> Vernon Center,NY
> >this TV.
when i
orginal TV
> >silver box.?
you
> >re brake 1983 FC-35
> >SPONSORED LINKS
t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w
3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O
> >vehicles
t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti
ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh
8HJdysB3QLPj9U0JvqYQ>Wanderlodge
t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34
cC1O9CxA>Automotive
> >maintenance
t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl
recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY
> >vehicle dealer
t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo
ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-
kXbDI4ZSadEw>Used
t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3
=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat
ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq
_4GlXA>Automotive
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
on the web.
> > subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com
maintenance
radiators
> YAHOO! GROUPS LINKS
Service.
03-14-2006, 13:49
Television
Must've been its time.
- Jeff Miller
in Holland, MI
doghouse.
field that may
go
03-14-2006, 14:33
Television
Keep it between the fires Ernie.
- Jeff Miller
in Holland, MI
03-14-2006, 19:02
Television
thanks, jeff, will do. Ernie-83pt40 leaving louisiana
03-16-2006, 10:52
Television
Not a real scientific answer, but I believe mine is turning because the
signal (picture) gets better (or worse) as you hold down the "rotate" rocker
switch.
I would guess that if your TV picture never changes (try different
channels), the element inside the dome isn't rotating like it is supposed to.
I guess
you could take the darn thing apart, and look inside the dome while someone
works the switch.
Have fun...I hear that the antennas are still available. Check the archives.
Kevin McKeown
Yorba Linda, CA
1986 38' PT
