Sporlan Water Valve- Changeout
03-15-2006, 10:15
Has anyone ever replced one of these? Now that all my water lines are
repaired- and I have pressure, the valve that is used to fill the fresh tank is obvously not working. EWhen I hook up city water, it starts to fill the tank- without regard to the valve switch on or off. I can hear the valve clicking and trying to work, but it does not. The water pump also is affected by this- because it does not seal the loop, and lets water bypass around in a circle. I have even thought about seeing if there was a type of manual valve with a push/pull type cable to open and close the connection. Help??! Stephen 81 FC-33SB Plant City, FL |
03-15-2006, 11:38
--- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...>
wrote: > Stephen, I have not replaced the full valve, but was able to get a repair kit and replace the innards. Easy to do. Works great. I followed the instructions provided by Ralph F, which at the moment, I cannot seem to find. Basically, you likely need to clean or replace the inner seal "disk". Links are hard to paste in Yahoo so search for Sporlan.com and you will get the company, and there are downloads for parts. I'll stick the service/part sheet in the files here and at Wanderlodge FC in a few moments. Good luck. Frank 85FC33 > Has anyone ever replced one of these? Now that all my water lines are > repaired- and I have pressure, the valve that is used to fill the > fresh tank is obvously not working. EWhen I hook up city water, it > starts to fill the tank- without regard to the valve switch on or off. > I can hear the valve clicking and trying to work, but it does not. The > water pump also is affected by this- because it does not seal the > loop, and lets water bypass around in a circle. > > I have even thought about seeing if there was a type of manual valve > with a push/pull type cable to open and close the connection. > Help??! > Stephen > 81 FC-33SB > Plant City, FL > |
03-16-2006, 05:10
wrote: > Steven, I have the same problem you described.(89sp). I have my valve out right now, and ordered a rebuild kit from bb yesterday, $30.00.. The valve(I could only get the top off with 4 bolts)and it was filled with a white scum from water contamanites.I understand from other owners that it sticks in this condition and causes what you described. good luck Ed Gardels 89sp Arlington, Texas > Has anyone ever replced one of these? Now that all my water lines are > repaired- and I have pressure, the valve that is used to fill the > fresh tank is obvously not working. EWhen I hook up city water, it > starts to fill the tank- without regard to the valve switch on or off. > I can hear the valve clicking and trying to work, but it does not. The > water pump also is affected by this- because it does not seal the > loop, and lets water bypass around in a circle. > > I have even thought about seeing if there was a type of manual valve > with a push/pull type cable to open and close the connection. > Help??! > Stephen > 81 FC-33SB > Plant City, FL > |
03-16-2006, 05:20
Is the diaphragm in good condition? A while back I took mine apart,
removed the white stuff, lightly cleaned the diaphragm, and reassembled it. Works great so far. .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ED GARDELS wrote: > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> > wrote: > > > Steven, I have the same problem you described.(89sp). I have my > valve out right now, and ordered a rebuild kit from bb yesterday, > $30.00.. The valve(I could only get the top off with 4 bolts)and it > was filled with a white scum from water contamanites.I understand > from other owners that it sticks in this condition and causes what > you described. > good luck > Ed Gardels 89sp > Arlington, Texas > |
03-16-2006, 05:28
> Yes curt, the diaphram was dirty but now looks clean and new. It was soooo hard to get at(behind bedroom dresser which i had to dismantal) that i thought I would put in new parts.Was yours hard to get to? edgardels 89sp Arlington Texas > Is the diaphragm in good condition? A while back I took mine apart, > removed the white stuff, lightly cleaned the diaphragm, and reassembled > it. Works great so far. > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > ED GARDELS wrote: > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > wrote: > > > > > Steven, I have the same problem you described.(89sp). I have my > > valve out right now, and ordered a rebuild kit from bb yesterday, > > $30.00.. The valve(I could only get the top off with 4 bolts)and it > > was filled with a white scum from water contamanites.I understand > > from other owners that it sticks in this condition and causes what > > you described. > > good luck > > Ed Gardels 89sp > > Arlington, Texas > > > |
03-16-2006, 06:28
Ed,
No too bad. Mine was between walls that support the bed and keep the water tank in place. A space about 12 inches by 24 inches, filled with plumbing. Lifted the mattress and supported it, removed the mattress platform, and stuck my head in under the mattress and cussed the whole time. About a half hour job. It would take all day if I had to R&R the valve body. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ED GARDELS wrote: > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > Yes curt, the diaphram was dirty but now looks clean and new. It was > soooo hard to get at(behind bedroom dresser which i had to > dismantal) that i thought I would put in new parts.Was yours hard to > get to? > edgardels 89sp > Arlington Texas > > Is the diaphragm in good condition? A while back I took mine > apart, > > removed the white stuff, lightly cleaned the diaphragm, and > reassembled > > it. Works great so far. > > > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > ED GARDELS wrote: > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > > wrote: > > > > > > > Steven, I have the same problem you described.(89sp). I have my > > > valve out right now, and ordered a rebuild kit from bb yesterday, > > > $30.00.. The valve(I could only get the top off with 4 bolts)and > it > > > was filled with a white scum from water contamanites.I understand > > > from other owners that it sticks in this condition and causes > what > > > you described. > > > good luck > > > Ed Gardels 89sp > > > Arlington, Texas > > > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
03-16-2006, 07:24
My valve was not clogged, or full of anything. I took it apart before I knew
I had problems, because it was leaking(the big o-ring) I went to the local hardware store, and got a new o-ring.. Well it does not leak, but it does not stop water from flowing either. The rubber disc was clean, and soft.. but I guess it has sit up dry for a long time, and the top rubber does not seal the hole anymore??.. I guess I need a rebuild kit. When I go outside and move the "tank Fill" switch on/off, I hear a clicking sound inside.. I assume the solenoid is trying to open/close. and it is getting power. What cha think? Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger Sent: Thursday, March 16, 2006 1:28 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout Ed, No too bad. Mine was between walls that support the bed and keep the water tank in place. A space about 12 inches by 24 inches, filled with plumbing. Lifted the mattress and supported it, removed the mattress platform, and stuck my head in under the mattress and cussed the whole time. About a half hour job. It would take all day if I had to R&R the valve body. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ED GARDELS wrote: > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > Yes curt, the diaphram was dirty but now looks clean and new. It was > soooo hard to get at(behind bedroom dresser which i had to > dismantal) that i thought I would put in new parts.Was yours hard to > get to? > edgardels 89sp > Arlington Texas > > Is the diaphragm in good condition? A while back I took mine > apart, > > removed the white stuff, lightly cleaned the diaphragm, and > reassembled > > it. Works great so far. > > > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > ED GARDELS wrote: > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > > wrote: > > > > > > > Steven, I have the same problem you described.(89sp). I have my > > > valve out right now, and ordered a rebuild kit from bb yesterday, > > > $30.00.. The valve(I could only get the top off with 4 bolts)and > it > > > was filled with a white scum from water contamanites.I understand > > > from other owners that it sticks in this condition and causes > what > > > you described. > > > good luck > > > Ed Gardels 89sp > > > Arlington, Texas > > > > > > _____ [Non-text portions of this message have been removed] |
03-16-2006, 07:29
Stephen I believe you can get re-build kits from Stephen Birtles. Give him a
shout. Quoting Stephen <share@...>: > > > > > My valve was not clogged, or full of anything. I took it apart before I knew > > I had problems, because it was leaking(the big o-ring) I went to the local > > hardware store, and got a new o-ring.. Well it does not leak, but it does > > not stop water from flowing either. The rubber disc was clean, and soft.. > > but I guess it has sit up dry for a long time, and the top rubber does not > > seal the hole anymore??.. I guess I need a rebuild kit. When I go outside > > and move the "tank Fill" switch on/off, I hear a clicking sound inside.. I > > assume the solenoid is trying to open/close. and it is getting power. What > > cha think? > > > > > > > > Stephen > > > > 81 FC-33SB > > > > Plant City, Fl > > > > > > > > > > > > > > > > Â _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger > > Sent: Thursday, March 16, 2006 1:28 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout > > > > > > > > Ed, > > No too bad. Mine was between walls that support the bed and keep the > > water tank in place. A space about 12 inches by 24 inches, filled with > > plumbing. Lifted the mattress and supported it, removed the mattress > > platform, and stuck my head in under the mattress and cussed the whole > > time. About a half hour job. It would take all day if I had to R&R the > > valve body. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > ED GARDELS wrote: > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > > > Yes curt, the diaphram was dirty but now looks clean and new. It was > > > soooo hard to get at(behind bedroom dresser which i had to > > > dismantal) that i thought I would put in new parts.Was yours hard to > > > get to? > > > Â edgardels 89sp > > > Â Arlington Texas > > > > Is the diaphragm in good condition? A while back I took mine > > > apart, > > > > removed the white stuff, lightly cleaned the diaphragm, and > > > reassembled > > > > it. Works great so far. > > > > > > > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > ED GARDELS wrote: > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > > > > wrote: > > > > > > > > > > > Steven, I have the same problem you described.(89sp). I have my > > > > > valve out right now, and ordered a rebuild kit from bb yesterday, > > > > > $30.00.. The valve(I could only get the top off with 4 bolts)and > > > it > > > > > was filled with a white scum from water contamanites.I understand > > > > > from other owners that it sticks in this condition and causes > > > what > > > > > you described. > > > > > Â Â good luck > > > > > Â Ed Gardels 89sp > > > > > Â Arlington, Texas > > > > > > > > > > > > > > > > Â _____ > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > > |
03-16-2006, 09:10
Ed- so thats where your sporlan valve was located. Ernie-83pt40 in Texas
-----Original Message----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Thu, 16 Mar 2006 10:28:25 -0800 Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout Ed, No too bad. Mine was between walls that support the bed and keep the water tank in place. A space about 12 inches by 24 inches, filled with plumbing. Lifted the mattress and supported it, removed the mattress platform, and stuck my head in under the mattress and cussed the whole time. About a half hour job. It would take all day if I had to R&R the valve body. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ED GARDELS wrote: > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > Yes curt, the diaphram was dirty but now looks clean and new. It was > soooo hard to get at(behind bedroom dresser which i had to > dismantal) that i thought I would put in new parts.Was yours hard to > get to? > edgardels 89sp > Arlington Texas > > Is the diaphragm in good condition? A while back I took mine > apart, > > removed the white stuff, lightly cleaned the diaphragm, and > reassembled > > it. Works great so far. > > > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > ED GARDELS wrote: > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > > wrote: > > > > > > > Steven, I have the same problem you described.(89sp). I have my > > > valve out right now, and ordered a rebuild kit from bb yesterday, > > > $30.00.. The valve(I could only get the top off with 4 bolts)and > it > > > was filled with a white scum from water contamanites.I understand > > > from other owners that it sticks in this condition and causes > what > > > you described. > > > good luck > > > Ed Gardels 89sp > > > Arlington, Texas > > > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Yahoo! Groups Links [Non-text portions of this message have been removed] |
03-16-2006, 12:04
> yes ernie, the valve is on the floor behind the built in dresser. I had to dismantle the dresser cabinet and jack it up enough to get my upper torso in to get the top off the valve. I can barely see it. Any way it was coated with white mineral stuff which I cleaned off. since its so hard to get to I thougt it best to put in new parts. By the way I fixed my gen set(wouldnt fire). Changed fuel filter and tightned alt belt. edgardels 89sp arlington texas > Ed- so thats where your sporlan valve was located. Ernie-83pt40 in Texas > > -----Original Message----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Thu, 16 Mar 2006 10:28:25 -0800 > Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout > > > Ed, > No too bad. Mine was between walls that support the bed and keep the > water tank in place. A space about 12 inches by 24 inches, filled with > plumbing. Lifted the mattress and supported it, removed the mattress > platform, and stuck my head in under the mattress and cussed the whole > time. About a half hour job. It would take all day if I had to R&R the > valve body. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > ED GARDELS wrote: > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > Yes curt, the diaphram was dirty but now looks clean and new. It was > > soooo hard to get at(behind bedroom dresser which i had to > > dismantal) that i thought I would put in new parts.Was yours hard to > > get to? > > edgardels 89sp > > Arlington Texas > > > Is the diaphragm in good condition? A while back I took mine > > apart, > > > removed the white stuff, lightly cleaned the diaphragm, and > > reassembled > > > it. Works great so far. > > > > > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > ED GARDELS wrote: > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > > > wrote: > > > > > > > > > Steven, I have the same problem you described.(89sp). I have my > > > > valve out right now, and ordered a rebuild kit from bb yesterday, > > > > $30.00.. The valve(I could only get the top off with 4 bolts)and > > it > > > > was filled with a white scum from water contamanites.I understand > > > > from other owners that it sticks in this condition and causes > > what > > > > you described. > > > > good luck > > > > Ed Gardels 89sp > > > > Arlington, Texas > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > > > Wanderlodge > > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > > > Automotive maintenance > > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > > > > Recreational vehicle dealer > > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > > > Used recreational vehicles > > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > > > Automotive radiators > > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > > > > > > ------------------------------------------------------------------------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > |
