Can I run B20?
04-22-2007, 15:47
Can I run B20?
I saw a couple of posts of folks using Bio. I see there are a lot of
B20 sellers on my route home, most notably this "BioWillie" stuff. Can
I just pull my bus in to one of these and fill up without problems? I
understand there is a chance of clogging fuel filters sooner at first,
but otherwise, what's your take? I'd love to save money while
supporting American corn farmers.
-Ryan
'86 PT-40 8V92 (Tuesday!)
04-22-2007, 16:54
Can I run B20?
It's a nice thought but the filters and fuel lines might not like the sudden
introduction of the cleaning effect of the B20. Picture a sudden loss of power
and time on the side of the road waiting for the road angle to change fuel
filters. Just pay big oil until you get home, then do some research on the good
and bad of "bio".
MH
Sent: Sunday, April 22, 2007 9:47 PM
Subject: [WanderlodgeForum] Can I run B20?
-Ryan
04-22-2007, 20:23
Can I run B20?
Brad, Al Johnson in Mandeville, La has been using his own biodiesel in his
BMC. Hopefully he will chime in on your question.
83PT40
Livingston, Mt
04-22-2007, 22:34
Can I run B20?
Mike,
I think you'll actually be helping Texas Soybean farmers. The corn's used
to make Ethanol..which is even worse for your car than biodiesel is for your
bus. I'd like to see a consortium of BB owners get together and make their
own biodiesel. I think it's better for engines in the long run, but it has
such a cleaning effect it can clog your filters w/ petroleum residue the
first few times.
Has anyone out there tried "Diesel Secret" where you simply filter used
cooking oil and add a catalyst, usually Lye? Or as has anyone made their
own BioDiesel?
If this subject has already been handled, just point me to the thread and
ignore me.
Brad Barton 00LXiDFW
bbartonwx@...
>From: "Mike Hohnstein" <MHOHNSTEIN@...>
>To:
>Subject: Re: [WanderlodgeForum] Can I run B20?
>Date: Sun, 22 Apr 2007 22:54:18 -0600
>sudden introduction of the cleaning effect of the B20. Picture a sudden
>loss of power and time on the side of the road waiting for the road angle
>to change fuel filters. Just pay big oil until you get home, then do some
>research on the good and bad of "bio".
>MH
> From: Ryan Wright
> -Ryan
Download Messenger. Join the i’m Initiative. Help make a difference today.
http://im.live.com/messenger/im/home/?so...AGHM_APR07
04-23-2007, 00:56
Can I run B20?
I have researched the viability of bio, straight grease etc. Problem I
can't get over is after 7 or 8 hundred miles from the home base, gotta fill
again. My stash of low buck fuel don't help me then.
I suppose if one has great memories of playing with a chemistry set as a
youngster, add the notion of getting over on "big oil", the tenacity to deal
with a major mess, and just a small amount of grease is a mess, it could
work. However, I'll go to the truck stop for now, not the Flying J mind
you.
MH
To:
Sent: Monday, April 23, 2007 4:34 AM
> Mike,
> your
> their
> has
> first few times.
> own BioDiesel?
> ignore me.
> bbartonwx@...
>>To:
>>MH
>> From: Ryan Wright
>> -Ryan
> Download Messenger. Join the i'm Initiative. Help make a difference today.
> Yahoo! Groups Links
04-23-2007, 01:57
Can I run B20?
Ryan,
Since this is a new to you bus, I would strongly recommend you not
use the biodiesel on your voyage back home. Because biodiesel has a
cleaning effort on the petro carbons left in your system, they will end
up in your filters. Do the conversion when you safely made it back to
your home so you will have access to all the tools and what not you
need. Chances are you will not have a problem but I would not take a
chance. Plus you need to know how the bus performs before you
complicate matters.
As for buying biodiesel from commercial pumps, usually you will
find the cost will probably be more than petro diesel. If you make it
yourself, your cost should be about $0.66 a gallon. No time /
equipment included in the calculation.
Al Johnson
Mandeville, Louisiana
'96 BMC B100
'04 VW Passat B100
'03 Dodge 2500 B100
> -Ryan
04-23-2007, 01:59
Can I run B20?
I totally agree with you on wait till you get home to convert.
Al Johnson
Mandeville, Lousiana
'96 BMC B100
'04 VW Passat B100
'03 Dodge 2500 B100
the sudden introduction of the cleaning effect of the B20. Picture a
sudden loss of power and time on the side of the road waiting for the
road angle to change fuel filters. Just pay big oil until you get
home, then do some research on the good and bad of "bio".
> MH
> From: Ryan Wright
of
stuff. Can
problems? I
first,
> -Ryan
04-23-2007, 02:07
Can I run B20?
Brad,
I have read a ton of feedback on "Diesel Secret". STAY AWAY from
it. The making of biodiesel is a chemical reaction that strips away
the fatty molecules thus thining the oil to consistency of petro
diesel. The biodiesel is going to be better on engines and better on
the environment. You get less friction because of all the
lubrication. You also get no carbon monoxide but instead you get
carbon dioxide which plants use to make oxygen for us. I have never
had to change a filter on the bus due to it being clogged. I do
service and change out all filters every 5k miles. I make my own
fuel and have since Nov. '05. Only had one filter clog on my '93
Dodge truck. Changed out the fuel filter, reprimed the engine and
off she went. So moral of the story, keep extra filters / wrenches
just in case.
Al Johnson
'96 BMC B100
'04 VW Passat B100
'03 Dodge 2500 B100
'93 Dodge 2500 B100
--- In WanderlodgeForum@yahoogroups.com, "brad barton"
<bbartonwx@...> wrote:
> Mike,
corn's used
for your
make their
but it has
residue the
> first few times.
used
their
> own BioDiesel?
thread and
> ignore me.
> bbartonwx@...
> >To:
sudden
road angle
do some
> >MH
> > From: Ryan Wright
lot of
stuff. Can
problems? I
first,
> > -Ryan
today.
04-23-2007, 03:17
Can I run B20?
Ernie,
Thanks. I'm sure I'm not the only coach owner dreading my next fillup.
bbartonwx@...
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/defau...TERAVERAGE
04-23-2007, 03:24
Can I run B20?
Al,
Thanks for the feedback. Not being a chemist, nor retired, I'm pretty
reluctant to get into it right now, but it's intriguing.
bbartonwx@...
Don’t quit your job – Take Classes Online and Earn your Degree in 1 year.
Start Today!
http://www.classesusa.com/clickcount.cfm...asses\
usa.com%2Ffeaturedschools%2Fonlinedegreesmp%2Fform-dyn1.html%3Fsplovr%3D866144
