Slide Out Installation
06-06-2007, 08:33
Is there any company that would install a living room slide out in a 43-
LXI. Any information would be appreciated. Thanks |
06-06-2007, 09:44
I'd be betting that it would not be cost effective.
On Wed, 06 Jun 2007 20:33:50 -0000, you wrote: >Is there any company that would install a living room slide out in a 43- >LXI. Any information would be appreciated. Thanks -- Regards, Peter T. Arnold 2007 HHR, 2.4L/Auto, LT2, Fun to drive so far 1987 300SDL 280KMI Inherited by Grandson 1995 F-250 PowerChoke 196Kmi 1954 Metropolitan Convertible, Hanger Queen Wife has a Cruizer, 80 Kmi, as reliable as an Ice Box, the car that is! |
06-06-2007, 10:23
I looked into that possibility a couple of years ago. Having hydronic heat,
steel ribs on the side of the coach, and many other issues I backed out. There is a company in the Kansas City area, Premier Coach Services, http://www.premiercoachservices.com that provides the service. There is another one in the Phoenix area and I cannot remember the name. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: d.mckendree To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 06, 2007 3:33 PM Subject: [WanderlodgeForum] Slide Out Installation Is there any company that would install a living room slide out in a 43- LXI. Any information would be appreciated. Thanks [Non-text portions of this message have been removed] |
06-07-2007, 13:53
Don't know of a place to have it done, but do know that the
slide equipped LXi's were reinforced under the basement. Check yours to see if it has a two 2 x 6 box section steel beams running under the basement cross members and stretching from the front of the bus to the back. The box sections have additional diagonal bracing tying them together. If your LXi has these components then it's slide ready; otherwise, you have a big project ahead of you. David Brady '02 LXi, Smokey NC d.mckendree wrote: > > Is there any company that would install a living room slide out in a 43- > LXI. Any information would be appreciated. Thanks > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.472 / Virus Database: 269.8.9/834 - Release Date: 6/5/2007 2:38 PM > [Non-text portions of this message have been removed] |
