1989 WB Bluebird
07-27-2005, 05:40
1989 WB Bluebird
On the turbo piping, I meant the right front piping not the left.
Ralph
At 12:33 PM 7/27/2005 -0500, you wrote:
>Hello Doug:
>I am in Oklahoma http://home.swbell.net/rlf47/index.htm and perform service
>work on Birds.
>When you go see the Coach, don't be in a rush, take your time and don't be
>overwhelmed. It is easy to do, I know, we have all been there.
>After a walk through, ask Bleakly to have a service tech come out with a
>manometer and do an LP leak down test. This can be done in the refrigerator
>out side access compartment. This is important.
>Next, open the engine hatch, do a visual check where the hatch gas shocks
>mount to the lid. Then check the manifolds for cracks or broken ears by the
>hold down bolts. If the turbo piping is covered with heat shielding, as
>your facing the engine, on your left in front you will see the turbo
>piping, under that shielding you will find a flange covered by a clamp.
>Just above the clamp, do a visual check for any cracks.
>Next check the battery wiring, it should be 2/0 min cable size. Check the
>condition of the cable ends.
>As you do your walk through of the Coach, turn on all the lighting systems.
>Bring the AC's on line one at a time until all are running and take a look
>at the gauges to see if they are balanced and steady. Turn on the Coach
>head lights and driving lights, check to be sure they are working. If
>memory serves, unless it has been modified ( you will probably make that
>modification later) the bright lights have to be on for the driving lights
>to work. Check the step in and out function. Check the entry door to be
>sure it is not bowed or need an adjustment. Check all the gaskets around
>all windows to be sure there is not rust beginning. Go up on top and check
>all vents where the base contacts the roof metal, for cracking or if that
>d(*&@ silicone has been used to stop leaks. Check all screws holding down
>the walk plates to see if they are loose. Look over the side and check the
>seams where the awnings meet the coach. If the rain guttering has open
>cracks in the sealant, it is not a major concern but you will have to
>address that as a prevent maint later on.
>Standing at the front of the Coach peer down the sides for anything unusual
>like deeper than what should be normal indentations in the skin. Open the
>compartments and check the gas shocks and rubber seals. Look under the
>compartment edges, especially the front where tire blow outs could have
>crumpled the compartments. Check all wheel wells for missing insulation,
>this tells you if there has been a blow out, and if any damage from that.
>Check the water system to be sure it pressures up and the pump shuts off
>properly.
>So many things, but this you can do with an informed walk around. Check the
>undercarriage for major rust and the bottom of the LP ASME tank is a good
>tell tell there.
>That is just a few things to look at to start with. Hope this helps a
>little. The '89 is a good Coach. Good luck.
>Ralph Fullenwider
>out of Oklahoma
>At 08:32 PM 7/26/2005 -0500, you wrote:
> >Tom,
> >I am new to this forum and I don't know Ralph Fullenwider. How do you
> >contact and where does he live? I would probably hire someone after I see
> >the coach and decide to buy it. John Bleakley offered a free oil analysis
> >to be taken before they change the oil and they also said they would print
> >off what the computer history says (I am not familiar with what
> >information you can get from the computer).
> >Thanks for your response and help!!
> >Doug Tidwell
> > ----- Original Message -----
> > From: Tom Warner
> > To: WanderlodgeForum@yahoogroups.com
> > Sent: Tuesday, July 26, 2005 8:21 PM
> > Subject: Re: [WanderlodgeForum] 1989 WB Bluebird
> > Doug dont waste your money on an oil analysis. An oil analysis is only
> > good
> > if you have others to compare it with and the sample is taken at or near
> > oil change time so you get used oil to sample. If anyone has changed the
> > oil lately and you can bet it has been the only thing an oil analysis
> will
> > do now is to lighten your pocket.
> > I believe John Bleakley is a reputable organization from what I have
> > personally observed. I went there when another forum member Dave Campbell
> > bought I believe a 1988 PT40 WB from them at a RITV that I sponsered
> > him at
> > about 3 years ago. He was very satisfied with their service and the
> > upgrade
> > work he had done on the coach. I would suggest you get a good inspection
> > done by them and annotate it on your sales receipt. Or hire Ralph
> > Fullenwider to do a PDI on it for you and use that to get the necessary
> > repairs done and up to snuff.
> > Good luck
> > Tom
> > 1982 FC35
> > Vernon Center,NY
>Yahoo! Groups Links
Safe travels,
Ralph's RV Solutions,, Oklahoma
07-27-2005, 06:52
1989 WB Bluebird
Hello Ralph,
Your information is very much appreciated!! I have not seen this coach and I
only have the salesman word on the condition (he seems to very honest and is not
pressuring me in any way). I think I will fly down there tomorrow and look it
over and use your information as a guide. Assuming everything checks out good,
do you think it would be advisable for me to pay you to check it over before I
sign on the dotted line? I know so many things can be wrong and I really don't
want to get into a coach with numerous follow-up expenses. I was originally
focusing on coaches in the 91-95 model years which could probably afford but
certainly would like to pay less if I found the right older coach. What is your
opinion on the best value and is there any good comparisons between the 89
verses the early 90's? I guess you have worked on all of them and maybe have
established some fact based opinions. Any comments would be greatly
appreciated.
Also, should I look at suspension air-bags. I have noticed some people on the
forum have had to replace them in older coaches.
Do you have a phone number where I could call you?
Thanks!
Doug Tidwell
Sent: Wednesday, July 27, 2005 12:33 PM
Hello Doug:
work on Birds.
properly.
tell tell there.
Ralph Fullenwider
out of Oklahoma
>Tom,
>Doug Tidwell
> From: Tom Warner
> good
> oil lately and you can bet it has been the only thing an oil analysis will
> him at
> upgrade
> Good luck
> Tom
> 1982 FC35
> Vernon Center,NY
YAHOO! GROUPS LINKS
07-27-2005, 06:57
1989 WB Bluebird
Doug:
Sent you the phone back channel.
The folks at Bleakly are pretty reliable really. They know Birds and since
they are only a few miles from Bird's Nest, they do represent their Coaches
pretty openly. They have a nice facility there as well.
Safe travels,
At 01:52 PM 7/27/2005 -0500, you wrote:
>Hello Ralph,
>and I only have the salesman word on the condition (he seems to very
>honest and is not pressuring me in any way). I think I will fly down
>there tomorrow and look it over and use your information as a
>guide. Assuming everything checks out good, do you think it would be
>advisable for me to pay you to check it over before I sign on the dotted
>line? I know so many things can be wrong and I really don't want to get
>into a coach with numerous follow-up expenses. I was originally focusing
>is your opinion on the best value and is there any good comparisons
>between the 89 verses the early 90's? I guess you have worked on all of
>them and maybe have established some fact based opinions. Any comments
>would be greatly appreciated.
>the forum have had to replace them in older coaches.
>Thanks!
>Doug Tidwell
> From: Ralph L. Fullenwider
> Hello Doug:
> service
> work on Birds.
> refrigerator
> the
> systems.
> unusual
> properly.
> the
> tell tell there.
> Ralph Fullenwider
> out of Oklahoma
07-27-2005, 07:10
1989 WB Bluebird
Doug,
checkout this 90 pt40, Bill 91pt40
http://www.rvonline.com/single-ad.asp?Recnumber=24140
Sent: Wednesday, July 27, 2005 11:57 AM
Doug:
Safe travels,
>Hello Ralph,
>Thanks!
>Doug Tidwell
> Hello Doug:
> service
> work on Birds.
> refrigerator
> the
> systems.
> unusual
> properly.
> the
> tell tell there.
> Ralph Fullenwider
> out of Oklahoma
YAHOO! GROUPS LINKS
07-27-2005, 13:08
1989 WB Bluebird
Bill,
Thanks for the reference to rv-online. I sure like that coach but I
really wanted to stay away from wood cabinets (dark interior). I
did talk to the owners and may still consider it later on if it does
not sell.
I will fly to Georgia tomorrow and check out the 1989 John Bleakley
has. It will have to really good for me to purchase.
Do you have a 1991? If so how do you like it?
Thanks!
Doug Tidwell
--- In WanderlodgeForum@yahoogroups.com, "Village Drug Frontiernet"
> Doug,
> Doug:
and since
their Coaches
> Safe travels,
> >Hello Ralph,
this coach
very
fly down
would be
the dotted
want to get
originally focusing
but
coach. What
comparisons
on all of
comments
some people on
> >Thanks!
> >Doug Tidwell
> > Hello Doug:
perform
> > service
> > work on Birds.
time and don't be
there.
come out with a
> > refrigerator
hatch gas shocks
broken ears by
> > the
shielding, as
the turbo
by a clamp.
size. Check the
lighting
> > systems.
and take a look
on the Coach
working. If
probably make that
driving lights
door to be
gaskets around
top and check
cracking or if that
holding down
and check the
guttering has open
will have to
anything
> > unusual
skin. Open the
under the
could have
insulation,
damage from that.
pump shuts off
> > properly.
around. Check
> > the
tank is a good
> > tell tell there.
this helps a
> > Ralph Fullenwider
> > out of Oklahoma
> YAHOO! GROUPS LINKS
of Service.
07-27-2005, 13:22
1989 WB Bluebird
Ralph,
The transmission on this coach is a 4-speed. Do you think a 4-speed
is a great negative compared to one with more speeds? Just
wondering what you thought.
Thanks!!
Doug Tidwell
> Doug:
and since
their Coaches
> Safe travels,
> >Hello Ralph,
coach
very
down
would be
dotted
to get
focusing
but
coach. What
comparisons
all of
comments
people on
> >Thanks!
> >Doug Tidwell
> > Hello Doug:
perform
> > service
> > work on Birds.
and don't be
out with a
> > refrigerator
gas shocks
broken ears by
> > the
shielding, as
turbo
a clamp.
size. Check the
lighting
> > systems.
take a look
the Coach
working. If
make that
driving lights
door to be
gaskets around
top and check
or if that
holding down
and check the
has open
have to
anything
> > unusual
skin. Open the
under the
could have
insulation,
from that.
shuts off
> > properly.
around. Check
> > the
tank is a good
> > tell tell there.
helps a
> > Ralph Fullenwider
> > out of Oklahoma
07-27-2005, 13:38
1989 WB Bluebird
Doug:
Interesting question and a valid one. my thought is "not really" and I say
that because the Coach was set up with that transmission and the running
gears designed around the factors on concept. The rear end is probable a
3:56 or even a 3:34 gear ratio. then taking into consideration, the 8V92
over the 6V I really don't think that would be a consideration. Of course
more gears the different ratios. Many on here know the specs on ratios
better than I. It being a 4 speed would not stop me in considering the
coach, it is a good set up. The '89 PT 40 has staying power and with the
short drive shaft, little loss in torque. I don't remember exactly which
Allison was put in that Coach, even still my first thought is still "not
really."
Mike H or Mike M may be able to better to answer that one for you.
Give me a call at home if you like. We will talk Birds.
Safe travels,
Ralph's RV Solutions,, Oklahoma 580-252-7694
At 01:22 AM 7/28/2005 +0000, you wrote:
>Ralph,
>Thanks!!
>Doug Tidwell
07-27-2005, 15:01
1989 WB Bluebird
Doug, What are you looking for? I have a 90 SP for sale. Im about 40
mins. north of John Bleakley in Alpharetta GA. Tom 90 SP36
--- In WanderlodgeForum@yahoogroups.com, "dougtidwellhome"
> Bill,
I
does
> not sell.
Bleakley
> Thanks!
> Doug Tidwell
Frontiernet"
> > Doug,
> > Doug:
Birds
> and since
> their Coaches
> > Safe travels,
> > >Hello Ralph,
> this coach
to
> very
> fly down
> would be
> the dotted
> want to get
> originally focusing
afford
> but
> coach. What
> comparisons
worked
> on all of
Any
> comments
> some people on
> > >Thanks!
> > >Doug Tidwell
> > > Hello Doug:
> perform
> > > service
> > > work on Birds.
> time and don't be
> there.
> come out with a
> the
> > > refrigerator
> hatch gas shocks
> broken ears by
> > > the
> shielding, as
> the turbo
covered
> by a clamp.
> size. Check the
> lighting
> > > systems.
> and take a look
> on the Coach
> working. If
> probably make that
> driving lights
entry
> door to be
> gaskets around
on
> top and check
> cracking or if that
screws
> holding down
side
> and check the
> guttering has open
> will have to
> anything
> > > unusual
> skin. Open the
Look
> under the
outs
> could have
missing
> insulation,
> damage from that.
> pump shuts off
> > > properly.
> around. Check
> > > the
> tank is a good
> > > tell tell there.
> this helps a
> > > Ralph Fullenwider
> > > out of Oklahoma
> > YAHOO! GROUPS LINKS
Terms
> of Service.
07-27-2005, 15:08
1989 WB Bluebird
Doug,
You should look into the BMC line. You can get a 5 - 6 year
newer bird for same money with a Cummins Engine / 6 Speed Allison
MT3060 Transmission. You can find with white wash interiors as well
as dark wood. Ours has white wash interiors, wanderlodge dash, roof
latter / rails. As far as hp, the 37' has 350 and 40' have 400 I
believe. I am sure if I am wrong someone will correct me.
Al & Kathy Johnson
'96 BMC 37
Mandeville, Louisiana
Currently in Gillette, WY on way to Cody tomorrow then final to
Yellowstone
> Ralph,
speed
> Thanks!!
> Doug Tidwell
> > Doug:
> and since
> their Coaches
> > Safe travels,
> > >Hello Ralph,
this
> coach
> very
fly
> down
> would be
> dotted
want
> to get
originally
> focusing
> but
> coach. What
> comparisons
on
> all of
> comments
some
> people on
> > >Thanks!
> > >Doug Tidwell
> > > Hello Doug:
> perform
> > > service
> > > work on Birds.
time
> and don't be
there.
come
> out with a
> > > refrigerator
hatch
> gas shocks
> broken ears by
> > > the
> shielding, as
> turbo
by
> a clamp.
> size. Check the
> lighting
> > > systems.
> take a look
on
> the Coach
> working. If
probably
> make that
> driving lights
> door to be
> gaskets around
> top and check
cracking
> or if that
> holding down
> and check the
guttering
> has open
will
> have to
> anything
> > > unusual
> skin. Open the
> under the
> could have
> insulation,
damage
> from that.
pump
> shuts off
> > > properly.
> around. Check
> > > the
> tank is a good
> > > tell tell there.
this
> helps a
> > > Ralph Fullenwider
> > > out of Oklahoma
07-27-2005, 15:38
1989 WB Bluebird
The BMC line is a nice coach and is a good value but it is not a
Wanderlodge. It uses a Spartan mountain master chassis just like the Tiffin
motorhomes use, with a body put on it on the Bluebird Assembly line.
Bluebird marketed the BMC for a very few years in an effort to break into
the lower priced field.
tom
1982 FC35
Vernon Center,NY
At 03:08 AM 7/28/2005 +0000, you wrote:
>Doug,
>Al & Kathy Johnson
>'96 BMC 37
>Yellowstone
> > Ralph,
>speed
> > Thanks!!
> > Doug Tidwell
> > wrote:
> > > Doug:
> > and since
> > their Coaches
> > > Safe travels,
> > > >Hello Ralph,
>this
> > coach
> > very
>fly
> > down
> > would be
>the
> > dotted
>want
> > to get
>originally
> > focusing
> > but
> > coach. What
> > comparisons
>on
> > all of
> > comments
>some
> > people on
> > > >Thanks!
> > > >Doug Tidwell
> > > > Hello Doug:
> > > > I am in Oklahoma
> <http://home.swbell.net/rlf47/index.htm>http://home.swbell.net/rlf47/index.htm
> and
> > perform
> > > > service
> > > > work on Birds.
>time
> > and don't be
>there.
>come
> > out with a
>the
> > > > refrigerator
>hatch
> > gas shocks
> > broken ears by
> > > > the
> > shielding, as
>the
> > turbo
>by
> > a clamp.
> > size. Check the
> > lighting
> > > > systems.
>and
> > take a look
>on
> > the Coach
> > working. If
>probably
> > make that
> > driving lights
> > door to be
> > gaskets around
> > top and check
>cracking
> > or if that
> > holding down
> > and check the
>guttering
> > has open
>will
> > have to
> > anything
> > > > unusual
> > skin. Open the
> > under the
> > could have
> > insulation,
>damage
> > from that.
>pump
> > shuts off
> > > > properly.
> > around. Check
> > > > the
> > tank is a good
> > > > tell tell there.
>this
> > helps a
> > > > Ralph Fullenwider
> > > > out of Oklahoma
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
Loading...
