Education thread
03-22-2006, 07:43
Education thread
Jay, I still need diagrams for the Jake brake and high idle, too. Ernie-
83pt40 in Lamesa, tx [Non-text portions of this message have been removed] |
03-22-2006, 09:18
Education thread
Has anyone ever replaced/repaired the fuel shutoff cylinder? Mine
leaks air so badly that the steps pop out five minutes after I shut down the engine? Thanks, Larry Watson 87 PT40 --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Thanks Randy & Ralph! > > Randy, I have updated tthe return springs using 2 springs with, what > seems to me, have an awful lot of return pressure. > > I thought the old dual springs were contributing to my somewhat > sluggish throttle response, so removed one. Learned real quick when > I then engaged the high idle and it headed straight for Wide Open > Throttle, that you need the 2 return springs. > > Seems this places quit a strain on things having some much spring > pressure..? > > Ralph, I still don't find the transducer. Only thing I see is a > throttle cable coming from the cruise control board of crap. > > Pictures anyone? Sure would like to slow down the high idle a bit. > > Randy, I will add a 3rd return spring to see if it slows the high > idle as I know how and where to do that. > > Thanks to both of you again! > > Jay Darst > 85PT40 > Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > adjustment for the high idle.the best i remember (its been years) > you > > need a 9/16 wrench to adjust it. looking into your engine > > compartment,above the fuel filter on top of the engine you will > > see..jay,i have an 86 pt40 here for sme repairs,let me look at > that > > part tomorrow so i can give you a better discription,i need a > > refresher on it! BUT,before you go adjusting anything replace the > > throttle return springs where the throttle cable connects on top > of > > the engine at the rear,you need 3 springs,anything less will > result > > in high fast idle speeds,no kidding.. > > randy dupree 93wb > > 84fc for sale > > > > > > If anyone has information to contribute regarding the air > > throtttle, > > > its components and how they function, I would appreciate hearing > > > about it. > > > > > > My high idle is set at 1,350 rpm. I ant to slow it to 1,000 rpm > > but > > > don't know what or where to adjust it. > > > > > > A typed description is nice, but a picture of the component > would > > > help tremendously! > > > > > > This thread was started by Ralph, it wasn't finished(IMO) when > it > > > faded away. Least I can't find the info I need. > > > > > > Heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeellllllp! > > > > > > Thanks > > > Jay Darst > > > 85PT40 > > > Springfield, IL where we are still cleaning up from the 2 > > tornadoes > > > and this evening we have a winter storm warning, 7 inches of > > blowing > > > drifting accumulation by tomorrow, Spring started today at > 6:33am > > > CT... ;-} > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Good morning everyone: > > > > > > > > Well the grass is cut, edges all trimmed and weed eater put > away > > > on this > > > > beautiful Sunday morning. > > > > > > > > What say we start and education thread? > > > > > > > > Here is a topic seldom touched upon and can benefit all of us > in > > > one way or > > > > another. > > > > > > > > Anyone had much to do with the air throttle system, high idle > > > system and > > > > electronic shifter found on the PT's and some FC's? Come on PT > > > owner's jump > > > > on this one and lets find out how they work, where the > > components > > > are > > > > located and how to adjust them. > > > > > > > > Many of the air throttles seem to have a little greater lag > than > > > others. > > > > What is sticking, and wehre is it? > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > http://home.swbell.net/rlf47/index.htm > > > > > > > > > > |
03-22-2006, 09:26
Education thread
Randy,
No Jake. Tranny Retarder though.... Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > have here,its not a jake brake model and the high idle adjustment is > different from what i was thinking.does yours have a engine jake > brake? > randy > > > > Thanks Randy & Ralph! > > > > Randy, I have updated tthe return springs using 2 springs with, > what > > seems to me, have an awful lot of return pressure. > > > > I thought the old dual springs were contributing to my somewhat > > sluggish throttle response, so removed one. Learned real quick > when > > I then engaged the high idle and it headed straight for Wide Open > > Throttle, that you need the 2 return springs. > > > > Seems this places quit a strain on things having some much spring > > pressure..? > > > > Ralph, I still don't find the transducer. Only thing I see is a > > throttle cable coming from the cruise control board of crap. > > > > Pictures anyone? Sure would like to slow down the high idle a bit. > > > > Randy, I will add a 3rd return spring to see if it slows the high > > idle as I know how and where to do that. > > > > Thanks to both of you again! > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > > adjustment for the high idle.the best i remember (its been years) > > you > > > need a 9/16 wrench to adjust it. looking into your engine > > > compartment,above the fuel filter on top of the engine you will > > > see..jay,i have an 86 pt40 here for sme repairs,let me look at > > that > > > part tomorrow so i can give you a better discription,i need a > > > refresher on it! BUT,before you go adjusting anything replace > the > > > throttle return springs where the throttle cable connects on top > > of > > > the engine at the rear,you need 3 springs,anything less will > > result > > > in high fast idle speeds,no kidding.. > > > randy dupree 93wb > > > 84fc for sale > > > > > > > > If anyone has information to contribute regarding the air > > > throtttle, > > > > its components and how they function, I would appreciate > hearing > > > > about it. > > > > > > > > My high idle is set at 1,350 rpm. I ant to slow it to 1,000 > rpm > > > but > > > > don't know what or where to adjust it. > > > > > > > > A typed description is nice, but a picture of the component > > would > > > > help tremendously! > > > > > > > > This thread was started by Ralph, it wasn't finished(IMO) when > > it > > > > faded away. Least I can't find the info I need. > > > > > > > > Heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeellllllp! > > > > > > > > Thanks > > > > Jay Darst > > > > 85PT40 > > > > Springfield, IL where we are still cleaning up from the 2 > > > tornadoes > > > > and this evening we have a winter storm warning, 7 inches of > > > blowing > > > > drifting accumulation by tomorrow, Spring started today at > > 6:33am > > > > CT... ;-} > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. > Fullenwider" > > > > > > > > > > > > > > Good morning everyone: > > > > > > > > > > Well the grass is cut, edges all trimmed and weed eater put > > away > > > > on this > > > > > beautiful Sunday morning. > > > > > > > > > > What say we start and education thread? > > > > > > > > > > Here is a topic seldom touched upon and can benefit all of > us > > in > > > > one way or > > > > > another. > > > > > > > > > > Anyone had much to do with the air throttle system, high > idle > > > > system and > > > > > electronic shifter found on the PT's and some FC's? Come on > PT > > > > owner's jump > > > > > on this one and lets find out how they work, where the > > > components > > > > are > > > > > located and how to adjust them. > > > > > > > > > > Many of the air throttles seem to have a little greater lag > > than > > > > others. > > > > > What is sticking, and wehre is it? > > > > > > > > > > Safe travels, > > > > > > > > > > Ralph and Charolette Fullenwider > > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > http://home.swbell.net/rlf47/index.htm > > > > > > > > > > > > > > > |
User(s) browsing this thread: 8 Guest(s)
