Television
03-16-2006, 15:14
Television
how do you know if the antenna is rotating when you turn the wheel?
-------------- Original message from putneyflash@...: -------------- Thanks Tom: am i to understand you repaired the silver box.? when you installed the TV on the dog house do you use the TV connector on the floor by the co-pilot. where is your back up monitor??i was thinking of installing it in place of the orginal TVscreen. Thanks again for responding. -------------- Original message from Tom Warner -------------- "The silver box" is part of the electronics for the Cathode Ray tube mounted over the front of the driver. PMMI took apart a TV set and put part of it in the "Silver Box" and part in the overhead in front of the driver. There is really not enough room to replace the TV screen with a TV so I made a cherry cabinet mounted on too of the dog house for mine. I repaired mine and it works fine now. tom warner 1982 FC35 Vernon Center,NY The "Silver boxAt 10:13 PM 3/12/2006, you wrote: >I have several questions about the TV in my 1983 FC-35. >the TV screen comes on no rear picture, but the previous owner >installed a 5" tv on the dash and the back up camera works fine on >this TV. >Is the silver box located above the drivers seat the actual TV? when i >move some on the knobs i see movement on the TV sreen ( the orginal TV >screen)verical, contrast etc. >has anyone had one of these units repaired? >can i installed another TV in place of the orginal and get rid of the >silver box.? >is there an indicator that shows the TV antenna is rotating? >does the CB radio run through the silver box? >how is the silver box mounted, mine is setting loose on the shelf. >That for all the help I know I will get, this is a great site and you >folks have a lot of knowledge >re brake 1983 FC-35 > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
03-16-2006, 23:22
Television
I installed a new one and i know it rotates with the hand held control because
like you say the picture gets better or worse, when i turn the wheel so far i haven't seen any change. i didn't have the hand control hooked up when i moved the wheel, it will work like it is i am one of those guys who likes things to work like it was disigned to even if its old tecnology. Thanks for responding re brake -------------- Original message from krminyl@...: -------------- Not a real scientific answer, but I believe mine is turning because the signal (picture) gets better (or worse) as you hold down the "rotate" rocker switch. I would guess that if your TV picture never changes (try different channels), the element inside the dome isn't rotating like it is supposed to. I guess you could take the darn thing apart, and look inside the dome while someone works the switch. Have fun...I hear that the antennas are still available. Check the archives. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
03-22-2006, 02:57
Television
Yes I have the diagrams and information for the "silver box" and have
repaired it. The monitor is overhead of the driver in its original location. Now that I have the 85 PT40 I intend to put a new system in it consisting of two LCD screens (one for the driver and one for the passenger) with the appropriate electronics for a GPS system as well as a back up monitor. tom warner 1982 FC35 1985 PT40 At 09:02 PM 3/13/2006, you wrote: >Thanks Tom: am i to understand you repaired the silver box.? when >you installed the TV on the dog house do you use the TV connector on >the floor by the co-pilot. where is your back up monitor??i was >thinking of installing it in place of the orginal TVscreen. Thanks >again for responding. >-------------- Original message from Tom Warner >-------------- > >"The silver box" is part of the electronics for the Cathode Ray tube >mounted over the front of the driver. PMMI took apart a TV set and >put part of it in the "Silver Box" and part in the overhead in front >of the driver. There is really not enough room to replace the TV >screen with a TV so I made a cherry cabinet mounted on too of the dog >house for mine. I repaired mine and it works fine now. > >tom warner >1982 FC35 >Vernon Center,NY > > > > >The "Silver boxAt 10:13 PM 3/12/2006, you wrote: > >I have several questions about the TV in my 1983 FC-35. > >the TV screen comes on no rear picture, but the previous owner > >installed a 5" tv on the dash and the back up camera works fine on > >this TV. > >Is the silver box located above the drivers seat the actual TV? when i > >move some on the knobs i see movement on the TV sreen ( the orginal TV > >screen)verical, contrast etc. > >has anyone had one of these units repaired? > >can i installed another TV in place of the orginal and get rid of the > >silver box.? > >is there an indicator that shows the TV antenna is rotating? > >does the CB radio run through the silver box? > >how is the silver box mounted, mine is setting loose on the shelf. > >That for all the help I know I will get, this is a great site and you > >folks have a lot of knowledge > >re brake 1983 FC-35 > > > > > > > > > > > > > >SPONSORED LINKS > ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recr > eational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic\ le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=D\ AUkCKkU7Dzhn_ObWmSYTw>http://groups.yahoo.com/gads?t=ms&k=Recr...cles&\ w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa\ l+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163\ &.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational > > >vehicles > ><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+v > ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&\ w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3Q\ LPj9U0JvqYQ>http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Rec > reational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi\ cle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=\ IF4u_5wI8Pmy34cC1O9CxA>http://groups.yahoo.com/gads?t=ms&k=Auto...enanc\ e&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreatio\ nal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=1\ 63&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive > > >maintenance > ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w > 1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational\ +vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&\ .sig=z6_XahaeYHfELr6o72IW1A>http://groups.yahoo.com/gads?t=ms&k=Recreational+veh\ icle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4\ =Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiato\ rs&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreational > > >vehicle dealer > ><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1 > =Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+\ vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.\ sig=UGEY5km4L-kXbDI4ZSadEw>http://groups.yahoo.com/gads?t=ms&k=Used+recreational\ +vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=R\ ecreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators\ &c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used > > >recreational vehicles > ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recre > ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=eP\ NVMmISsCWgTnMq_4GlXA>http://groups.yahoo.com/gads?t=ms&k=Auto...rs&w1\ =Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+\ vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.\ sig=ePNVMmISsCWgTnMq_4GlXA>Automotive > > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > odgeForum-unsubscribe@yahoogroups.com > > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > >SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance >Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > >YAHOO! GROUPS LINKS > >Visit your group "WanderlodgeForum" on the web. > >To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > >Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
03-22-2006, 03:00
Television
I actually built a nice Cherry mounting pod to anchor the TV in that
takes the place of the old "thing" (dont know what to call it) that was mounted on the doghouse originally. It works very well and the TV works as it was intended for the last 2 years. tom warner 1982 FC35 1985 PT40 At 09:23 PM 3/13/2006, you wrote: >Years ago, when we had our 84 35fC, we set a color tv on the doghouse. >Something happened to the color in that set.Is there any electrical >field that may >have interfered with the color on that tv- or was it the tv's time to go >south? Ernie-83pt40 in louisiana > > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
03-22-2006, 05:28
Television
I pulled the 'silver box' and the picture tube out of my coach. If
anyone would like it, ask and its yours. I mounted a 5.6" color LCD in place of the interior rear view mirror and connected that to the rear-view camera full time. In place of the TV tuner control panel, I mounted the remote panel for my Xantrex inverter/charger. The original stereo equipment that was next to the TV is no more, a fellow listee has it. My current head-end unit is in the center dash next to the CB Radio, the system amplifier(s) are mounted where the old system once was and tie into the existing speaker wiring at that point. I'll try to post some photos soon. Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Yes I have the diagrams and information for the "silver box" and have > repaired it. The monitor is overhead of the driver in its original > location. Now that I have the 85 PT40 I intend to put a new system > in it consisting of two LCD screens (one for the driver and one for > the passenger) with the appropriate electronics for a GPS system as > well as a back up monitor. > > tom warner > 1982 FC35 > 1985 PT40 > |
03-22-2006, 07:26
Television
If the picture tube still works, I could use it. Mine died shortly
after I bought the coach last year. I'm guessing it is probably the same size/model as in my 83. I'll gladly pay the shipping charge. Phil Olson 83FC35SB Appleton, WI --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > I pulled the 'silver box' and the picture tube out of my coach. If > anyone would like it, ask and its yours. > > I mounted a 5.6" color LCD in place of the interior rear view mirror > and connected that to the rear-view camera full time. > > In place of the TV tuner control panel, I mounted the remote panel > for my Xantrex inverter/charger. > > The original stereo equipment that was next to the TV is no more, a > fellow listee has it. My current head-end unit is in the center dash > next to the CB Radio, the system amplifier(s) are mounted where the > old system once was and tie into the existing speaker wiring at that > point. > > I'll try to post some photos soon. > > Tim Hannink > Winter Park, FL > 1981 FC-33SB > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > Yes I have the diagrams and information for the "silver box" and > have > > repaired it. The monitor is overhead of the driver in its original > > location. Now that I have the 85 PT40 I intend to put a new > system > > in it consisting of two LCD screens (one for the driver and one > for > > the passenger) with the appropriate electronics for a GPS system > as > > well as a back up monitor. > > > > tom warner > > 1982 FC35 > > 1985 PT40 > > > |
03-22-2006, 07:44
Television
Tom,
Let me know how that works out, I'm thinking of doing the same thing on mine. I hear 'sparking' Noises coming from the "silver Box" when I plug the fuse in (no wonder the fuse was missing)-So I was thinking of doing the same thing as you-Upgrade to LCD- and get a color backup camera for the rear. I 'wandered' also, could I use the same camera cable that exists? Or would I have to run another :-~ Stephen 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Wednesday, March 22, 2006 9:58 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Television Yes I have the diagrams and information for the "silver box" and have repaired it. The monitor is overhead of the driver in its original location. Now that I have the 85 PT40 I intend to put a new system in it consisting of two LCD screens (one for the driver and one for the passenger) with the appropriate electronics for a GPS system as well as a back up monitor. tom warner 1982 FC35 1985 PT40 At 09:02 PM 3/13/2006, you wrote: >Thanks Tom: am i to understand you repaired the silver box.? when >you installed the TV on the dog house do you use the TV connector on >the floor by the co-pilot. where is your back up monitor??i was >thinking of installing it in place of the orginal TVscreen. Thanks >again for responding. >-------------- Original message from Tom Warner >-------------- > >"The silver box" is part of the electronics for the Cathode Ray tube >mounted over the front of the driver. PMMI took apart a TV set and >put part of it in the "Silver Box" and part in the overhead in front >of the driver. There is really not enough room to replace the TV >screen with a TV so I made a cherry cabinet mounted on too of the dog >house for mine. I repaired mine and it works fine now. > >tom warner >1982 FC35 >Vernon Center,NY > > > > >The "Silver boxAt 10:13 PM 3/12/2006, you wrote: > >I have several questions about the TV in my 1983 FC-35. > >the TV screen comes on no rear picture, but the previous owner > >installed a 5" tv on the dash and the back up camera works fine on > >this TV. > >Is the silver box located above the drivers seat the actual TV? when i > >move some on the knobs i see movement on the TV sreen ( the orginal TV > >screen)verical, contrast etc. > >has anyone had one of these units repaired? > >can i installed another TV in place of the orginal and get rid of the > >silver box.? > >is there an indicator that shows the TV antenna is rotating? > >does the CB radio run through the silver box? > >how is the silver box mounted, mine is setting loose on the shelf. > >That for all the help I know I will get, this is a great site and you > >folks have a lot of knowledge > >re brake 1983 FC-35 > > > > > > > > > > > > > >SPONSORED LINKS > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recr> &k=Recreational+vehicles&w1=Recr > eational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+v ehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=16 3&.sig=DAUkCKkU7Dzhn_ObWmSYTw>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational > > >vehicles > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+v> &k=Wanderlodge&w1=Recreational+v > ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8 HJdysB3QLPj9U0JvqYQ>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Rec> &k=Automotive+maintenance&w1=Rec > reational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+ vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=1 63&.sig=IF4u_5wI8Pmy34cC1O9CxA>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive > > >maintenance > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w> &k=Recreational+vehicle+dealer&w > 1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreati onal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c= 6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati onal > > >vehicle dealer > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1> &k=Used+recreational+vehicles&w1 > =Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreatio nal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6 &s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used > > >recreational vehicles > ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recre> &k=Automotive+radiators&w1=Recre > ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+ve hicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163 &.sig=ePNVMmISsCWgTnMq_4GlXA>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive > > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > derlodgeForum-unsubscribe@yahoogroups.com > > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > >SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance >Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > >YAHOO! GROUPS LINKS > >Visit your group "WanderlodgeForum" on the web. > >To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > >Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati onal >vehicle dealer ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
03-22-2006, 07:52
Television
I might be interested in them.. I live In Plant City-not too far.. I could
use them until I can get my new LCD system up and running! Let me know. Would love to see pics when they are avail.. (or better yet, If I get the monitor- I can see the coach in person!) Stephen --Twin coach to yours- 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tim Hannink Sent: Wednesday, March 22, 2006 12:28 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Television I pulled the 'silver box' and the picture tube out of my coach. If anyone would like it, ask and its yours. I mounted a 5.6" color LCD in place of the interior rear view mirror and connected that to the rear-view camera full time. In place of the TV tuner control panel, I mounted the remote panel for my Xantrex inverter/charger. The original stereo equipment that was next to the TV is no more, a fellow listee has it. My current head-end unit is in the center dash next to the CB Radio, the system amplifier(s) are mounted where the old system once was and tie into the existing speaker wiring at that point. I'll try to post some photos soon. Tim Hannink Winter Park, FL 1981 FC-33SB SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
03-22-2006, 07:55
Television
I'm sorry. Didn't see this post. Well, If he does not take the 'silver
box' Then I will I guess. _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of olson_phil Sent: Wednesday, March 22, 2006 2:26 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Television If the picture tube still works, I could use it. Mine died shortly after I bought the coach last year. I'm guessing it is probably the same size/model as in my 83. I'll gladly pay the shipping charge. Phil Olson 83FC35SB Appleton, WI --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > I pulled the 'silver box' and the picture tube out of my coach. If > anyone would like it, ask and its yours. > > I mounted a 5.6" color LCD in place of the interior rear view mirror > and connected that to the rear-view camera full time. > > In place of the TV tuner control panel, I mounted the remote panel > for my Xantrex inverter/charger. > > The original stereo equipment that was next to the TV is no more, a > fellow listee has it. My current head-end unit is in the center dash > next to the CB Radio, the system amplifier(s) are mounted where the > old system once was and tie into the existing speaker wiring at that > point. > > I'll try to post some photos soon. > > Tim Hannink > Winter Park, FL > 1981 FC-33SB > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > Yes I have the diagrams and information for the "silver box" and > have > > repaired it. The monitor is overhead of the driver in its original > > location. Now that I have the 85 PT40 I intend to put a new > system > > in it consisting of two LCD screens (one for the driver and one > for > > the passenger) with the appropriate electronics for a GPS system > as > > well as a back up monitor. > > > > tom warner > > 1982 FC35 > > 1985 PT40 > > > _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
03-22-2006, 09:38
Television
Stephen, if you are local why don't you take the monitor. I'm
leaning towards replacing the whole works with a LCD monitor and new camera anyway. I have been looking at rvcams.com, anyone use them before or have a suggestion on where to get a system? Phil Olson 83FC35SB Appleton, WI --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote: > > I'm sorry. Didn't see this post. Well, If he does not take the 'silver > box' Then I will I guess. > > > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of olson_phil > Sent: Wednesday, March 22, 2006 2:26 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Television > > > > If the picture tube still works, I could use it. Mine died shortly > after I bought the coach last year. I'm guessing it is probably the > same size/model as in my 83. I'll gladly pay the shipping charge. > > Phil Olson > 83FC35SB > Appleton, WI > > > --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > > > > I pulled the 'silver box' and the picture tube out of my coach. If > > anyone would like it, ask and its yours. > > > > I mounted a 5.6" color LCD in place of the interior rear view > mirror > > and connected that to the rear-view camera full time. > > > > In place of the TV tuner control panel, I mounted the remote panel > > for my Xantrex inverter/charger. > > > > The original stereo equipment that was next to the TV is no more, a > > fellow listee has it. My current head-end unit is in the center > dash > > next to the CB Radio, the system amplifier(s) are mounted where the > > old system once was and tie into the existing speaker wiring at > that > > point. > > > > I'll try to post some photos soon. > > > > Tim Hannink > > Winter Park, FL > > 1981 FC-33SB > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > wrote: > > > > > > Yes I have the diagrams and information for the "silver box" and > > have > > > repaired it. The monitor is overhead of the driver in its > original > > > location. Now that I have the 85 PT40 I intend to put a new > > system > > > in it consisting of two LCD screens (one for the driver and one > > for > > > the passenger) with the appropriate electronics for a GPS system > > as > > > well as a back up monitor. > > > > > > tom warner > > > 1982 FC35 > > > 1985 PT40 > > > > > > > > > > > > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > _____ > > > > [Non-text portions of this message have been removed] > |
