cruise control
12-10-2006, 13:32
cruise control
I sent any earlier message, John Bleakley motors in Macon, Ga. sells and works
on a lot of BB. ask for russell in parts 1-877-456-3700. I have not tested mine yet, i will let you know. I re brake 1983 FC-35 sb > > From: "davidkerryedwards" > Date: 2006/12/09 Sat PM 10:34:43 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: CRUISE CONTROL > > Where were you able to find a replacement? How much was it? I thought they were no longer > available. > > Kerry > 82 Fc 35 > Denver- > > -- In WanderlodgeForum@yahoogroups.com, > > > > My vacuum pump was located behnd the driver side bumper. it had been installed in some > kind of air valve. > > > > > > > > > |
12-10-2006, 14:27
cruise control
Hi Bob,
I just tried that on mine tonight, it does not work like yours... Sea Ya Larry NYC 84 35FCSB one_dusty_hoot am not familiar with your year model. In the 87 you can turn the cruise control ON then press and release the RESUME rocker to the desired rpm. You might try this standing still, and you could try holding the SET control for 2 seconds. Keep your foot off the brake. bob janes, '87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > No way to test it without driving it to my knowledge. I know the slide arm of which you > speak but I don't know what it is attached to. My coach is in storage. Which vacuum control > did you replace? > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > I am working on the cruise control, i have installed a new vacuum > > control. When looking at the cruise control i have a round disc > > attached to a chain which is connected to the cruise control which i > > believe attaches to the throttle lever..their is also a metal slide > > which is connected to a rod which also connects to the throttle lever. > > Does anyone know what it does? it has been disconnected. Is their any > > way to test the cruise control setting still? > > > > re brake 1983 FC-35 SB "sagecoach" > > > --------------------------------- Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] |
12-10-2006, 14:29
cruise control
In theroy, if we are talking about the same thing, the longer it is, the faster
the torque converter will go into lockup and the later you will get a downshift. The shorter you make it, the reverse should be true. I have mine shortened up somewhat to hold gears a little longer due to our mountianous terrain (read: lots of big hills that makes Pokey go real slow). Let me know how it works out. Doug n' Pokey putneyflash@... wrote: I think you are right, I haveit all attached now and I can see if theres any change in the shift. re brake 1983 fc-35 sb > > From: Doug Engel > Date: 2006/12/09 Sat PM 04:54:32 EST > To: WanderlodgeForum@yahoogroups.com > Subject: RE: [WanderlodgeForum] Re: CRUISE CONTROL > > On our '81 FC, the ball chain is attatched to throttle linkage right above the throttle cable. If we are talking about the same part, the slide arm is part of the transmission kick down/shift point system. If it has never been attatched, I can't see how your tranny could have been shifting correctly, so maye this is something else. > > Dan Darst > > dandarst86fc35rbhuntleyil. > > >From: "davidkerryedwards" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: CRUISE CONTROL > >Date: Sat, 09 Dec 2006 20:14:41 -0000 > > > >No way to test it without driving it to my knowledge. I know the slide arm > >of which you > >speak but I don't know what it is attached to. My coach is in storage. > >Which vacuum control > >did you replace? > > > >Kerry > >82 Fc 35 > >Denver > > > >--- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > I am working on the cruise control, i have installed a new vacuum > > > control. When looking at the cruise control i have a round disc > > > attached to a chain which is connected to the cruise control which i > > > believe attaches to the throttle lever..their is also a metal slide > > > which is connected to a rod which also connects to the throttle lever. > > > Does anyone know what it does? it has been disconnected. Is their any > > > way to test the cruise control setting still? > > > > > > re brake 1983 FC-35 SB "sagecoach" > > > > > > > > > __________________________________________________________ > Talk now to your Hotmail contacts with Windows Live Messenger. > http://clk.atdmt.com/MSN/go/msnnkwme0020...t.liv\ e.com/messenger/overview > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Have a burning question? Go to Yahoo! Answers and get answers from real people who know. > > [Non-text portions of this message have been removed] > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] |
12-10-2006, 16:26
cruise control
Hi Ernie,
Maybe I did not do it correctly... I reved the engine up to about 1k rpms and hit the cruise set rocker, no good... I then reved up to 1k and hit the set twice, no luck... I also hit resume with the same sequence, no luck... Maybe some one can come up with the proper sequence it may work... Sea Ya Larry NYC 84 35FCSB erniecarpet@... wrote: My 84 35Fc would work on high idle if I hit the cruise, twice, if my old memory serves me right. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-10-2006, 17:35
cruise control
Larry:
If you get it figured out, let me know as well , mine does not work either. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Larry To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 10, 2006 8:26:21 PM Subject: Re: [WanderlodgeForum] Re: CRUISE CONTROL Hi Ernie, Maybe I did not do it correctly... I reved the engine up to about 1k rpms and hit the cruise set rocker, no good... I then reved up to 1k and hit the set twice, no luck... I also hit resume with the same sequence, no luck... Maybe some one can come up with the proper sequence it may work... Sea Ya Larry NYC 84 35FCSB erniecarpet@ aol.com wrote: My 84 35Fc would work on high idle if I hit the cruise, twice, if my old memory serves me right. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] ____________ _________ _________ _________ _________ __ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail. yahoo.com [Non-text portions of this message have been removed] <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-11-2006, 02:41
cruise control
You need air pressure on the air/Bendix cruise ('84 up on FC).
You don't need to rev it, parking brake on, turn on cruise, then hit resume, hit it again for higher idle, set for lower idle, touch brake to cancel (I might have resume and set backwards, but am pretty sure). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi Ernie, > Maybe I did not do it correctly... I reved the engine up to about 1k rpms and hit the cruise set rocker, no good... I then reved up to 1k and hit the set twice, no luck... I also hit resume with the same sequence, no luck... Maybe some one can come up with the proper sequence it may work... > Sea Ya > Larry > NYC > 84 35FCSB > > erniecarpet@... wrote: My 84 35Fc would work on high idle if I hit the cruise, twice, if my old > memory serves me right. > > Ernie Ekberg > 83PT40 > Weatherford, tx > > [Non-text portions of this message have been removed] > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
12-11-2006, 02:42
cruise control
Although the downsift Bowden cable will affect the shift points, I
don't believe it will change the torque-converter lockup point. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > In theroy, if we are talking about the same thing, the longer it is, the faster the torque converter will go into lockup and the later you will get a downshift. The shorter you make it, the reverse should be true. I have mine shortened up somewhat to hold gears a little longer due to our mountianous terrain (read: lots of big hills that makes Pokey go real slow). Let me know how it works out. Doug n' Pokey > > putneyflash@... wrote: I think you are right, I haveit all attached now and I can see if theres any change in the shift. > > re brake 1983 fc-35 sb > > > > From: Doug Engel > > Date: 2006/12/09 Sat PM 04:54:32 EST > > To: WanderlodgeForum@yahoogroups.com > > Subject: RE: [WanderlodgeForum] Re: CRUISE CONTROL > > > > On our '81 FC, the ball chain is attatched to throttle linkage right above the throttle cable. If we are talking about the same part, the slide arm is part of the transmission kick down/shift point system. If it has never been attatched, I can't see how your tranny could have been shifting correctly, so maye this is something else. > > > > Dan Darst > > > > dandarst86fc35rbhuntleyil. > > > > >From: "davidkerryedwards" > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >To: WanderlodgeForum@yahoogroups.com > > >Subject: [WanderlodgeForum] Re: CRUISE CONTROL > > >Date: Sat, 09 Dec 2006 20:14:41 -0000 > > > > > >No way to test it without driving it to my knowledge. I know the slide arm > > >of which you > > >speak but I don't know what it is attached to. My coach is in storage. > > >Which vacuum control > > >did you replace? > > > > > >Kerry > > >82 Fc 35 > > >Denver > > > > > >--- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > > > I am working on the cruise control, i have installed a new vacuum > > > > control. When looking at the cruise control i have a round disc > > > > attached to a chain which is connected to the cruise control which i > > > > believe attaches to the throttle lever..their is also a metal slide > > > > which is connected to a rod which also connects to the throttle lever. > > > > Does anyone know what it does? it has been disconnected. Is their any > > > > way to test the cruise control setting still? > > > > > > > > re brake 1983 FC-35 SB "sagecoach" > > > > > > > > > > > > > > __________________________________________________________ > > Talk now to your Hotmail contacts with Windows Live Messenger. > > http://clk.atdmt.com/MSN/go/msnnkwme0020...irect/01/? href=http://get.live.com/messenger/overview > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > --------------------------------- > > Have a burning question? Go to Yahoo! Answers and get answers from real people who know. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. > > [Non-text portions of this message have been removed] > |
12-11-2006, 03:05
cruise control
Hi Jeff,
Thanks I will try that next time am up at the coach... Sea Ya Larry NYC 84 35FCSB Jeff Miller need air pressure on the air/Bendix cruise ('84 up on FC). You don't need to rev it, parking brake on, turn on cruise, then hit resume, hit it again for higher idle, set for lower idle, touch brake to cancel (I might have resume and set backwards, but am pretty sure). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi Ernie, > Maybe I did not do it correctly... I reved the engine up to about 1k rpms and hit the cruise set rocker, no good... I then reved up to 1k and hit the set twice, no luck... I also hit resume with the same sequence, no luck... Maybe some one can come up with the proper sequence it may work... > Sea Ya > Larry > NYC > 84 35FCSB > > erniecarpet@... wrote: My 84 35Fc would work on high idle if I hit the cruise, twice, if my old > memory serves me right. > > Ernie Ekberg > 83PT40 > Weatherford, tx > > [Non-text portions of this message have been removed] > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
12-11-2006, 03:15
cruise control
Doesn't seem like it should, but it did on Pokey. When it was too long, it
virtually skipped straight into 3&4 lockup, really lugged him down. Doug n' Pokey Jeff Miller cable will affect the shift points, I don't believe it will change the torque-converter lockup point. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > In theroy, if we are talking about the same thing, the longer it is, the faster the torque converter will go into lockup and the later you will get a downshift. The shorter you make it, the reverse should be true. I have mine shortened up somewhat to hold gears a little longer due to our mountianous terrain (read: lots of big hills that makes Pokey go real slow). Let me know how it works out. Doug n' Pokey > > putneyflash@... wrote: I think you are right, I haveit all attached now and I can see if theres any change in the shift. > > re brake 1983 fc-35 sb > > > > From: Doug Engel > > Date: 2006/12/09 Sat PM 04:54:32 EST > > To: WanderlodgeForum@yahoogroups.com > > Subject: RE: [WanderlodgeForum] Re: CRUISE CONTROL > > > > On our '81 FC, the ball chain is attatched to throttle linkage right above the throttle cable. If we are talking about the same part, the slide arm is part of the transmission kick down/shift point system. If it has never been attatched, I can't see how your tranny could have been shifting correctly, so maye this is something else. > > > > Dan Darst > > > > dandarst86fc35rbhuntleyil. > > > > >From: "davidkerryedwards" > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >To: WanderlodgeForum@yahoogroups.com > > >Subject: [WanderlodgeForum] Re: CRUISE CONTROL > > >Date: Sat, 09 Dec 2006 20:14:41 -0000 > > > > > >No way to test it without driving it to my knowledge. I know the slide arm > > >of which you > > >speak but I don't know what it is attached to. My coach is in storage. > > >Which vacuum control > > >did you replace? > > > > > >Kerry > > >82 Fc 35 > > >Denver > > > > > >--- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > > > I am working on the cruise control, i have installed a new vacuum > > > > control. When looking at the cruise control i have a round disc > > > > attached to a chain which is connected to the cruise control which i > > > > believe attaches to the throttle lever..their is also a metal slide > > > > which is connected to a rod which also connects to the throttle lever. > > > > Does anyone know what it does? it has been disconnected. Is their any > > > > way to test the cruise control setting still? > > > > > > > > re brake 1983 FC-35 SB "sagecoach" > > > > > > > > > > > > > > __________________________________________________________ > > Talk now to your Hotmail contacts with Windows Live Messenger. > > http://clk.atdmt.com/MSN/go/msnnkwme0020...irect/01/? href=http://get.live.com/messenger/overview > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > --------------------------------- > > Have a burning question? Go to Yahoo! Answers and get answers from real people who know. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. > > [Non-text portions of this message have been removed] > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Want to start your own business? Learn how on Yahoo! Small Business. [Non-text portions of this message have been removed] |
12-11-2006, 13:35
cruise control
Does the transmission go intoTt/C lock up in each gear?
re brake 1983 FC_35 sb > > From: Doug Engel > Date: 2006/12/11 Mon AM 10:15:55 EST > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: CRUISE CONTROL > > Doesn't seem like it should, but it did on Pokey. When it was too long, it virtually skipped straight into 3&4 lockup, really lugged him down. Doug n' Pokey > > Jeff Miller cable will affect the shift points, I > don't believe it will change the torque-converter lockup point. > > - Jeff Miller > in Holland, MI > > --- In WanderlodgeForum@yahoogroups.com, Doug Engel > wrote: > > > > In theroy, if we are talking about the same thing, the longer it > is, the faster the torque converter will go into lockup and the > later you will get a downshift. The shorter you make it, the reverse > should be true. I have mine shortened up somewhat to hold gears a > little longer due to our mountianous terrain (read: lots of big > hills that makes Pokey go real slow). Let me know how it works out. > Doug n' Pokey > > > > putneyflash@... wrote: I think you are right, I haveit > all attached now and I can see if theres any change in the shift. > > > > re brake 1983 fc-35 sb > > > > > > From: Doug Engel > > > Date: 2006/12/09 Sat PM 04:54:32 EST > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: RE: [WanderlodgeForum] Re: CRUISE CONTROL > > > > > > On our '81 FC, the ball chain is attatched to throttle linkage > right above the throttle cable. If we are talking about the same > part, the slide arm is part of the transmission kick down/shift > point system. If it has never been attatched, I can't see how your > tranny could have been shifting correctly, so maye this is something > else. > > > > > > Dan Darst > > > > > > dandarst86fc35rbhuntleyil. > > > > > > >From: "davidkerryedwards" > > > >Reply-To: WanderlodgeForum@yahoogroups.com > > > >To: WanderlodgeForum@yahoogroups.com > > > >Subject: [WanderlodgeForum] Re: CRUISE CONTROL > > > >Date: Sat, 09 Dec 2006 20:14:41 -0000 > > > > > > > >No way to test it without driving it to my knowledge. I know > the slide arm > > > >of which you > > > >speak but I don't know what it is attached to. My coach is in > storage. > > > >Which vacuum control > > > >did you replace? > > > > > > > >Kerry > > > >82 Fc 35 > > > >Denver > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > > > > > > I am working on the cruise control, i have installed a new > vacuum > > > > > control. When looking at the cruise control i have a round > disc > > > > > attached to a chain which is connected to the cruise control > which i > > > > > believe attaches to the throttle lever..their is also a > metal slide > > > > > which is connected to a rod which also connects to the > throttle lever. > > > > > Does anyone know what it does? it has been disconnected. Is > their any > > > > > way to test the cruise control setting still? > > > > > > > > > > re brake 1983 FC-35 SB "sagecoach" > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > Talk now to your Hotmail contacts with Windows Live Messenger. > > > http://clk.atdmt.com/MSN/go/msnnkwme0020...irect/01/? > href=http://get.live.com/messenger/overview > > > > > > > > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > > > --------------------------------- > > > Have a burning question? Go to Yahoo! Answers and get answers > from real people who know. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > --------------------------------- > > Check out the all-new Yahoo! Mail beta - Fire up a more powerful > email and get things done faster. > > > > [Non-text portions of this message have been removed] > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Want to start your own business? Learn how on Yahoo! Small Business. > > [Non-text portions of this message have been removed] > > > |
