musical horn
07-15-2006, 07:42
musical horn
We have decided to reprogram the musical horn. Today, on our 86FC35RB I
took the compartment above the co pilot apart and there was no black box. Hmmm Then I took the right front over head panel down..no box. Alot of a/c hoses but no box. Then the Left front overhead panel and still can not find it. Any ideas?? I have come to a point where I have the front open and can not find the box. Has anyone found the box some where else???? Thanks in advance ScottB 86FC35 SC |
07-15-2006, 08:29
musical horn
Scott,
Open the passenger side outside panel above the headlights, the windshield wiper is attached to this panel. This is where I found the black box on my coach. Darn tight fit. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Scott To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 15, 2006 3:42 PM Subject: [WanderlodgeForum] Musical Horn We have decided to reprogram the musical horn. Today, on our 86FC35RB I took the compartment above the co pilot apart and there was no black box. Hmmm Then I took the right front over head panel down..no box. Alot of a/c hoses but no box. Then the Left front overhead panel and still can not find it. Any ideas?? I have come to a point where I have the front open and can not find the box. Has anyone found the box some where else???? Thanks in advance ScottB 86FC35 SC ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006 [Non-text portions of this message have been removed] |
07-15-2006, 08:40
musical horn
Mr musical horn "brain" is above the co-pilot seat. Open the forward-
most curb side overhead compartment, then remove the front sidewall of the storage bin (simple screws). Behind that, I found the "brain" (actually a silver box, not black), and also an aplifier that sent the signal to the roof speakers. The silver box was about six inches square by one inch high and had no markings of any kind on it, but you will see the thick, gray wire ribbon that plugs in to it. I was going to have mine reprogrammed, too, but when it got to PMMI, they discovered that mine is so old it cannot be reprogrammed. You may want to verify with them that your model can be reprogrammed before you spend the shipping to send it in. Good luck Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Scott" > > We have decided to reprogram the musical horn. Today, on our 86FC35RB I > took the compartment above the co pilot apart and there was no black > box. Hmmm > Then I took the right front over head panel down..no box. Alot of a/c > hoses but no box. Then the Left front overhead panel and still can not > find it. Any ideas?? I have come to a point where I have the front open > and can not find the box. Has anyone found the box some where else???? > > Thanks in advance > > ScottB > 86FC35 > SC > |
07-15-2006, 08:57
musical horn
Scott, thanks for the quick reply. I have that area taken apart and
can not find the box. ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Mr musical horn "brain" is above the co-pilot seat. Open the forward- > most curb side overhead compartment, then remove the front sidewall of > the storage bin (simple screws). Behind that, I found the "brain" > (actually a silver box, not black), and also an aplifier that sent the > signal to the roof speakers. The silver box was about six inches square > by one inch high and had no markings of any kind on it, but you will > see the thick, gray wire ribbon that plugs in to it. > > I was going to have mine reprogrammed, too, but when it got to PMMI, > they discovered that mine is so old it cannot be reprogrammed. You may > want to verify with them that your model can be reprogrammed before you > spend the shipping to send it in. > > Good luck > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > > > > We have decided to reprogram the musical horn. Today, on our 86FC35RB > I > > took the compartment above the co pilot apart and there was no black > > box. Hmmm > > Then I took the right front over head panel down..no box. Alot of a/c > > hoses but no box. Then the Left front overhead panel and still can > not > > find it. Any ideas?? I have come to a point where I have the front > open > > and can not find the box. Has anyone found the box some where else???? > > > > Thanks in advance > > > > ScottB > > 86FC35 > > SC > > > |
07-15-2006, 10:04
musical horn
Guess they moved it by '86....
Scott --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > Scott, thanks for the quick reply. I have that area taken apart and > can not find the box. > > ScottB > 86FC35 > SC > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Mr musical horn "brain" is above the co-pilot seat. Open the > forward- > > most curb side overhead compartment, then remove the front sidewall > of > > the storage bin (simple screws). Behind that, I found the "brain" > > (actually a silver box, not black), and also an aplifier that sent > the > > signal to the roof speakers. The silver box was about six inches > square > > by one inch high and had no markings of any kind on it, but you > will > > see the thick, gray wire ribbon that plugs in to it. > > > > I was going to have mine reprogrammed, too, but when it got to > PMMI, > > they discovered that mine is so old it cannot be reprogrammed. You > may > > want to verify with them that your model can be reprogrammed before > you > > spend the shipping to send it in. > > > > Good luck > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > > > > > We have decided to reprogram the musical horn. Today, on our > 86FC35RB > > I > > > took the compartment above the co pilot apart and there was no > black > > > box. Hmmm > > > Then I took the right front over head panel down..no box. Alot of > a/c > > > hoses but no box. Then the Left front overhead panel and still > can > > not > > > find it. Any ideas?? I have come to a point where I have the > front > > open > > > and can not find the box. Has anyone found the box some where > else???? > > > > > > Thanks in advance > > > > > > ScottB > > > 86FC35 > > > SC > > > > > > |
07-16-2006, 08:21
musical horn
To all that replied, THANKS, I got into the front today and well after
figuring out that I could not reach everything I took the panel off the in front of the passenger seat. I guess everyone was right take the front panel off or open the front of the bus. Small tight space was an understatement. No way was I going to get the box out so I took the whole wooden tray out. I will send off to PMMI in the am. Thanks for all the help ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Scott" > > We have decided to reprogram the musical horn. Today, on our 86FC35RB I > took the compartment above the co pilot apart and there was no black > box. Hmmm > Then I took the right front over head panel down..no box. Alot of a/c > hoses but no box. Then the Left front overhead panel and still can not > find it. Any ideas?? I have come to a point where I have the front open > and can not find the box. Has anyone found the box some where else???? > > Thanks in advance > > ScottB > 86FC35 > SC > |
07-16-2006, 10:30
musical horn
Scott,
If your musical horn is not working it could be your speakers on top of the bus. That was my problem. I took a speaker from the house and wired it to the box and mine played fine. Just a thought. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Scott To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 16, 2006 4:21 PM Subject: [WanderlodgeForum] Re: Musical Horn To all that replied, THANKS, I got into the front today and well after figuring out that I could not reach everything I took the panel off the in front of the passenger seat. I guess everyone was right take the front panel off or open the front of the bus. Small tight space was an understatement. No way was I going to get the box out so I took the whole wooden tray out. I will send off to PMMI in the am. Thanks for all the help ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Scott" > > We have decided to reprogram the musical horn. Today, on our 86FC35RB I > took the compartment above the co pilot apart and there was no black > box. Hmmm > Then I took the right front over head panel down..no box. Alot of a/c > hoses but no box. Then the Left front overhead panel and still can not > find it. Any ideas?? I have come to a point where I have the front open > and can not find the box. Has anyone found the box some where else???? > > Thanks in advance > > ScottB > 86FC35 > SC > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006 [Non-text portions of this message have been removed] |
07-16-2006, 14:20
musical horn
Howard, thanks but my horn plays great! We just want some new tunes.
ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Scott, > If your musical horn is not working it could be your speakers on top of the bus. That was my problem. I took a speaker from the house and wired it to the box and mine played fine. Just a thought. > Howard Truitt > Camilla, Ga. > 86 PT40 > > ----- Original Message ----- > From: Scott > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, July 16, 2006 4:21 PM > Subject: [WanderlodgeForum] Re: Musical Horn > > > To all that replied, THANKS, I got into the front today and well after > figuring out that I could not reach everything I took the panel off the > in front of the passenger seat. I guess everyone was right take the > front panel off or open the front of the bus. Small tight space was an > understatement. No way was I going to get the box out so I took the > whole wooden tray out. I will send off to PMMI in the am. Thanks for > all the help > > ScottB > 86FC35 > SC > > --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > > > We have decided to reprogram the musical horn. Today, on our 86FC35RB > I > > took the compartment above the co pilot apart and there was no black > > box. Hmmm > > Then I took the right front over head panel down..no box. Alot of a/c > > hoses but no box. Then the Left front overhead panel and still can > not > > find it. Any ideas?? I have come to a point where I have the front > open > > and can not find the box. Has anyone found the box some where else???? > > > > Thanks in advance > > > > ScottB > > 86FC35 > > SC > > > > > > > > > -------------------------------------------------------------------- ---------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006 > > > [Non-text portions of this message have been removed] > |
07-16-2006, 15:08
musical horn
Going for some Rapp music Scott? hehe!
Bob Janes 87FC35 Greenville --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > Howard, thanks but my horn plays great! We just want some new tunes. > > ScottB > 86FC35 > SC > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Scott, > > If your musical horn is not working it could be your speakers on > top of the bus. That was my problem. I took a speaker from the house > and wired it to the box and mine played fine. Just a thought. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > ----- Original Message ----- > > From: Scott > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, July 16, 2006 4:21 PM > > Subject: [WanderlodgeForum] Re: Musical Horn > > > > > > To all that replied, THANKS, I got into the front today and well > after > > figuring out that I could not reach everything I took the panel > off the > > in front of the passenger seat. I guess everyone was right take > the > > front panel off or open the front of the bus. Small tight space > was an > > understatement. No way was I going to get the box out so I took > the > > whole wooden tray out. I will send off to PMMI in the am. Thanks > for > > all the help > > > > ScottB > > 86FC35 > > SC > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > wrote: > > > > > > We have decided to reprogram the musical horn. Today, on our > 86FC35RB > > I > > > took the compartment above the co pilot apart and there was no > black > > > box. Hmmm > > > Then I took the right front over head panel down..no box. Alot > of a/c > > > hoses but no box. Then the Left front overhead panel and still > can > > not > > > find it. Any ideas?? I have come to a point where I have the > front > > open > > > and can not find the box. Has anyone found the box some where > else???? > > > > > > Thanks in advance > > > > > > ScottB > > > 86FC35 > > > SC > > > > > > > > > > > > > > > > > ------------------------------------------------------------------ -- > ---------- > > > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: > 7/14/2006 > > > > > > [Non-text portions of this message have been removed] > > > |
06-06-2007, 12:23
musical horn
I had my musical horn reprogrammed at PMMI with new songs. I received
the unit back today, installed it, and it won't work. Has anyone ever tried to troubleshoot one of these? I tested the speakers, it isn't that. Scott Forman 86 PT38 |
