24 Volt
04-17-2006, 15:13
24 Volt
The calc for amps at 110 volts to amps at 12 volts-
say 15 amps at 110V = 15 x 110 = 1,650 watts 1,650 watts divied by 12volts = 137.5 amps(at 12V) because inverters are, at best, about 92% efficient, ya need to divide the 137.5amps by 92% efficiency, you'll get 149.5 amps (at 12V) to run a 15 amp/110V load. Fortunately, the roof tops only draw about 12.5 amps at 110V, so- 12.5 x 110 = 1,375watts divided by 12V = 114.6amps divied by 92% efficiency = 124.5 amps at 12V Throw in a bit of curve now. My alternator is actually 14 volts, so the equation looks like this: 12.5 x 110 = 1,375watts divided by 14V = 98.2amps divided by 92% efficientcy = 106.75 amps at 14V to run my front A/C. Pretty easy for the 14volt/320amp alternator. Plus the inverter likes to have plenty of voltage/amperage to convert to 110V, makes it work not so hard ;~} Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Just remember that to provide 15amps at 24 volts will require your generator > to provide about 83 amps at 24 volts or about 170 amps at 12 volts in > addition to the load it is currently carrying. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of putneyflash@... > Sent: Sunday, April 16, 2006 7:52 PM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] 24 Volt > > > Blair: could you run the fron ta/c off the inverter by tapping into the > correct leg? seems that would work better than having the dash a/c repaired > and converted from 12 to 134 > > re brake FC-35SB albany, ga. "sagecoach" > > -------------- Original message from Blair > -------------- > > > Lee, the Outback's are the best in the business and I sell all types. > Blair in Oregon > > > > At 05:57 PM 4/15/2006, you wrote: > >Hi electricians, My iota charger had an unfortunate encounter with a > >welding outlet and I am in the market for a new one. One thing leads > >to another and I am now looking at running the front A/C off an > >inverter for those minor cooling days without the generator. Then I > >looked at the currents and now am considering going to and LN 24v > >alternator(maybe 130A at 24V) and an outback VFX3524M inverter. It > >looks to me like I could hook the inverter to one of the 30 amp legs > >and put the inverter loads there and that way the existing selector > >switch would still work as isolation for the 50 amp and gen use? > > > >I have read through the writeup by > ><http://ourodyssey.blogspot.com/>http://ourodyssey.blogspot.com/ but > >I don't want THAT much automation. I think the 24v bus would be an > >asset for a future solar addition also. > > > >Any thoughts on 24V? > > > >Lee Benson, 85FC35, Carthage, IN > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+v > ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi cle+dea > ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&. sig=DAU > kCKkU7Dzhn_ObWmSYTw> > &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=A utomoti > ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+ve hicles& > w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreat ional > >vehicles > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer &w5=Use > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLP > j9U0JvqYQ> > &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+ mainten > ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6= Automot > ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+ > vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+veh icle+de > aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163& .sig=IF > 4u_5wI8Pmy34cC1O9CxA> > &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3= Automot > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v ehicles > &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automo tive > >maintenance > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreati > onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa l+vehic > le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s =163&.s > ig=z6_XahaeYHfELr6o72IW1A> > &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodg e&w3=Au > tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreatio nal+veh > icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>R ecreati > onal > >vehicle dealer > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreatio > nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational +vehicl > e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s= 163&.si > g=UGEY5km4L-kXbDI4ZSadEw> > &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge &w3=Aut > omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreation al+vehi > cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L- kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads?t=ms > <http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+ve > hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+deal > er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=ePNV > MmISsCWgTnMq_4GlXA> > &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotiv > e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w > 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automoti ve > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the > web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > > > [Non-text portions of this message have been removed] > > > > > YAHOO! GROUPS LINKS > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > [Non-text portions of this message have been removed] > > > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service > <http://docs.yahoo.com/info/terms/> . > > > _____ > > > > > [Non-text portions of this message have been removed] > |
04-18-2006, 01:57
24 Volt
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
wrote: > > My brother Dan has a 1986 FC35RB with the 3208 and a 320amp Leece > NeVille Alternator. The 160 and 320 use exactly the same mounting > hardware with no modifications at all- NONE. > I looked at one just superficially at the repair shop the other day. It sure looked bigger. I am on my way over there today. It sure doesn't look like there is much room around the Motorola that is there now. > You will need to change the cable that runs to the alternator as the > factory stuff is 1 gage, we replaced ours with 1/0 cable. This can > be a big PITA on the FC's, pretty easy on the PT. > As I think and read it seems that this is the real issue. I already have the 1/0 and 2/0 cable so that expense is not an issue. Those sizes are a real bear to work with, let alone threading it around a greasy frame. That was why I was looking at 24v to start with. I guess it boils down to the work to change cable v.s. the expense of a vanner DC-DC converter and all the other stuff to add a 24V bus. > The 320 amp unit is $1,500 new. Buy a take off(from ambulance or > fire truck) on E-Bay. > The shop has a new one on the shelf, $1,000. I am not sure I need to go all the way to 320 A. > > Too many variables. This is too much thinking for an old retired guy. At least it is not cold anymore so I have some time before I have to worry about getting a Proheat although that is in the back of my mind when looking at pumps, etc (12 vs 24). Lee Benson, 85FC35, Carthage, IN |
