Generator related questions
05-17-2006, 11:19
Thanks. I flipped the breakers a couple of times. I'll look for the
other switches.
Kerry
--- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote:
> Hi Kerry,
> It may sound elementary, but the breakers are deceiving...flip the
breakers
> to "off", then to "on" again. When tripped, it's kind of hard to tell
> visually if they are tripped. Also, are your overhead toggle
switches turned to
> the "on" position (on my PT they are overhead and on the left side
of the
> driver's head...one toggle switch for each roof air/floor level 110V
heater).
> These switches control the 110V AC heaters located down near the
floor, and the
> 110V AC roof air conditioners. Make sure only the roof air or
floor heaters
> are turned on, not both at the same time. If the roof airs still
don't work
> (toggle switch "on", selector switch on the roof air set to "cool",
> shore/gen switch sen to GEN), see if the 110V heaters turn on...if
they do, than will
> narrow down your troubleshooting to the roof airs. Like with most
system
> issues with BB, it's usually something simple.
> Good luck,
> Kevin McKeown
> Yorba Linda, CA
> 86 38PT
05-17-2006, 13:42
Kerry,
On my '82 FC35RB 'Bird the airconditioner wall switches are located
next to the driver s seat, you can see them in this photo;
http://www.pbase.com/iamflagman/image/34374169
Here is what I have listed that I used on my Perkins, for belts,
hoses and filters and other items, that you may be interested in
making a note of them. My Perkins has a water cooled exhaust
manifold, so keep this in mind, to see if yours has the same
configuration;
These are the part numbers that you need to replace all the hoses on
your Kohler/Perkins 12.5 KW . All are available from Auto Zone.
2ea. M-248 (1) thermostat housing to exhaust manifold cooler inlet
(1) exhaust manifold cooler outlet to inflow tube to
radiator
1ea M-049 top radiator inlet hose from inflow tube
1ea L-326 bottom radiator outlet hose to outflow tube inlet (this
tube is reduced down in size directly after the hose connection)
1ea L-978 radiator outflow tube outlet to engine block (SEE NOTE)
This is a Cut and Fit project. The Molded hose (L-978) has two
different end diameters, make sure that you use the smaller diameter
end trimmed down to the block side and cut the larger diameter end
off, just before the bend.
PERKINS FILTERS
OIL NAPA GOLD 1806
FUEL NAPA 3166
LOCATE YOUR ENGINE NUMBER NEAR THE IDLER PULLEY FOR THE WATER
PUMP/CRANKSHAFT BELT
High Water Temperature Shut Down Sending unit (Perkins Generator
Engine)
BLUEBIRD #4176483 $88.00
NIXON POWER #241308 (KOHLER PART) $45.72
Low Oil Pressure Shut Down sending unit (Perkins Generator Engine)
BLUEBIRD #4176491 $41.49
NIXON POWER #271662 (OLD) REPLACED BY #328309 (NEW STYLE KOHLER
PART**) $21.36
**FOR INSTALLATION TIP GO TO;
http://www.pbase.com/iamflagman/image/50053227
***Nixon Power Services 800-766-4966***
Thermostat
NAPA #382-190
Gasket
1038-ST
The thermostat is made by VW-AUDI and has these numbers inscribed on
it;
BTT
050 121 113C
1.180
87 degrees Celsius (that converts to 188.6 Fahrenheit)
Perkins "V" Belt 40 inches long
AutoZone and Advance Auto part DAYCO #15400 (11A1015)
NAPA PREMIUM XL 25-10153 (not positive on this number, be sure to
measure)
RADIATOR CAP 7# CARQUEST #33029
OIL PRESSURE SENDING UNIT FOR GAUGE NAPA #OP6622
I hope that this helps.
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
HOPKINS, SOUTH CAROLINA
> other switches.
> Kerry
> --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote:
> > Hi Kerry,
> breakers
tell
> switches turned to
side
> of the
110V
> heater).
> floor, and the
> floor heaters
> don't work
to "cool",
on...if
> they do, than will
most
> system
> > Good luck,
> > Kevin McKeown
> > Yorba Linda, CA
> > 86 38PT
05-17-2006, 13:58
John:
Thank you very much. Just what I needed. I had figured out the oil
and fuel filters today at NAPA but the rest of the those numbers are
just what I was looking for. For some reason, the numbers in the
manual for the Kohler in my bluebox are not the correct ones for my
generator. Those switches look familiar also. I'll check when I go to
the storage lot tomorrow to change the oil in the generator.
I noticed there was some weeping on either the low oil pressure shut
off sender or the gauge sender so those numbers will be of immediate
use.
Kerry
82 FC 35
Denver
--- In WanderlodgeForum@yahoogroups.com, "John" wrote:
> Kerry,
> configuration;
> radiator
> PERKINS FILTERS
> OIL NAPA GOLD 1806
> FUEL NAPA 3166
> Engine)
> PART**) $21.36
> Thermostat
> NAPA #382-190
> Gasket
> 1038-ST
> it;
> BTT
> 050 121 113C
> 1.180
> measure)
> John Finn
> '82 35FCRB
> GO TO;
05-22-2006, 14:23
I run Baldwin filters on my Perkins. Next time I am up at the storage place
I can get the part numbers if you wish.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards
Sent: Wednesday, May 17, 2006 11:49 AM
Subject: [WanderlodgeForum] Re: Generator related questions
It's an 82 FC. I'll check with NAPA. However, when I purchased the
oil and fuel filters from NAPA based on the part numbers in the
Bluebox, they were incorrect, so I was hoping to find a Kohler/Perkins
expert.
Kerry
--- In WanderlodgeForum@yahoogroups.com, "John B. Montgomery, AIA"
> David, i get the messages to my email account and your message
caught my attention. Check with your auto parts supplier/Store for
the hoses. I replaced mine in the last year or so and it is a 1982
Perkins. What model is your coach?
> John
> John B. Montgomery
> johnb@...
> From: davidkerryedwards
> Sent: Wednesday, May 17, 2006 11:41 AM
> Subject: [WanderlodgeForum] Generator related questions
> The generator slide tray is malfunctioning on my coach. If the
> locking mechanism is disengaged and the coach aired up, it pushes out
> the generator. Neither the key switch on the slide door or the switch
> by the steps makes any difference. I assume there is an air/electric
> switch somewhere that is stuck. Can someone tell me where it is
> and/or how to troubleshoot it?
> Also, while the tray was out I fired up the generator. I had power to
> the outlets but none of the AC's would work. Breakers were all on.
> Anyone have any idea what is happening? They all worked ok when I
> tested them when purchasing the coach a few months ago.
> Finally, what is a good source for all the radiator hoses on the
> Perkins 12.5? Mine are all original and could stand replacing.
> Thanks.
> Kerry
> 82 FC 35
> Denver
> YAHOO! GROUPS LINKS
> a.. Visit your group "WanderlodgeForum" on the web.
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
SPONSORED LINKS
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=
Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v
ehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> vehicles Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recre
ational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+r
epair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recre
ational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> vehicle
financing Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreati
onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa
ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati
onal+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> vehicle repair
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreati
onal+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> vehicle rental
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreati
onal+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> vehicle camper
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreation
al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair
&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreation
al+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> vehicle rate
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
_____
05-22-2006, 14:50
There's a list of filters for the Perkins in the Files at
http://autos.groups.yahoo.com/group/Wand...20Filters/
1991 WB40 "Texas Minivan"
San Antonio, TX (currently in Salt Lake City)
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
storage place
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
> expert.
> Kerry
> > John
> > John B. Montgomery
> > johnb@
pushes out
switch
power to
> > Thanks.
> > Kerry
> > 82 FC 35
> > Denver
> > YAHOO! GROUPS LINKS
> Service.
> SPONSORED LINKS
> Recreational
Recreational
> Recreational
> Recreational
> Recreational
> _____
> YAHOO! GROUPS LINKS
> _____
