Front Air
04-18-2005, 03:14
Front Air
Bill,
Don't feel like you are the only one that has done that, I have found that the location of the switches, is very prone to being turned off by the arm rest on my drivers seat, when it is slid sideways and now that is the first thing that I check when one of the three roof airs on my 'Bird does not work. JOHN FINN '82 35 FCRB HOPKINS, SOUTH CAROLINA "ON THE ROAD IN " To Visit the Finn's Inn Express Remodeling Adventure go to; http://www.pbase.com/iamflagman/image/24977457 ///////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" wrote: > > Thanks Lawrence & all that responded, > I had come to the conclution that my caoch was differnent from all > the rest. The switches everyone was talking about were just not there. > Well, this morning I sat back down in the seat and relaxed and just > let my eyes roam over the dash. I noticed that the drapes, which I > keep closed when not in use, touched the the very top of the lower > left (on the wall beside the driver) panel of switches. I reached over > and moved the drape and guess what I found. Boy do I feel dumb. > Problem solved, that is after I put the coach back together. > You guys don't know how much I appreciate this group. Thanks Ernie. > Bill AR 90sp36 > > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > > > Bill > > On my 90 SP the "2 switches above the driver" Jeff refers to are > actually on > > the top left of the lower dash. The top switch operates the front > AC while > > the one under it operates the rear one. They also operate the > electric heat > > front and rear > > Lawrence Thornell in Eclectic, AL |
04-18-2005, 08:45
Front Air
Bill- don't ya love it when a "problem" is solved. Ernie- 83PT40 in Texas-
gonna get to drive my coach home to Weatherford in am--- hip hip horray!!-It's been so dirty here I had to cover the air intake and cleaned out the filter-yuk [Non-text portions of this message have been removed] |
04-18-2005, 16:30
Front Air
John
My switches are actually on the dash' not on the wall. My XV had the switches on the wall by my arm and as you described I would knock them off. I bought drawer handles wide enough to reach over the switches(top to bottom). Mounted them on the switch plate so they covered the switch protecting them from being unintentionally turned off. You can find handles that will match the color of the switch and they look quite well. LT 90 SP Eclectic, AL ----- Original Message ----- From: "John" To: Sent: Monday, April 18, 2005 10:14 AM Subject: [WanderlodgeForum] Re: Front Air > > > Bill, > > Don't feel like you are the only one that has done that, I have found > that the location of the switches, is very prone to being turned off > by the arm rest on my drivers seat, when it is slid sideways and now > that is the first thing that I check when one of the three roof airs > on my 'Bird does not work. > > > JOHN FINN > '82 35 FCRB > HOPKINS, SOUTH CAROLINA > "ON THE ROAD IN " > To Visit the Finn's Inn Express Remodeling Adventure go to; > http://www.pbase.com/iamflagman/image/24977457 > > ///////////////////////// > > --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" > wrote: >> >> Thanks Lawrence & all that responded, >> I had come to the conclution that my caoch was differnent from all >> the rest. The switches everyone was talking about were just not > there. >> Well, this morning I sat back down in the seat and relaxed and just >> let my eyes roam over the dash. I noticed that the drapes, which I >> keep closed when not in use, touched the the very top of the lower >> left (on the wall beside the driver) panel of switches. I reached > over >> and moved the drape and guess what I found. Boy do I feel dumb. >> Problem solved, that is after I put the coach back together. >> You guys don't know how much I appreciate this group. Thanks Ernie. >> Bill AR 90sp36 >> >> --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" >> >> > Bill >> > On my 90 SP the "2 switches above the driver" Jeff refers to are >> actually on >> > the top left of the lower dash. The top switch operates the front >> AC while >> > the one under it operates the rear one. They also operate the >> electric heat >> > front and rear >> > Lawrence Thornell in Eclectic, AL > > > > > > > > Yahoo! Groups Links > > > > > > > |
04-19-2005, 01:26
Front Air
"I bought drawer handles wide enough to reach over the switches(top
to > bottom). Mounted them on the switch plate so they covered the switch" ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Lawrence, Thanks ffor the tip, that is agreat idea, I will see what I can find and install them. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////////// > protecting them from being unintentionally turned off. --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > John > My switches are actually on the dash' not on the wall. My XV had the > switches on the wall by my arm and as you described I would knock them off. > I bought drawer handles wide enough to reach over the switches(top to > bottom). Mounted them on the switch plate so they covered the switch > protecting them from being unintentionally turned off. You can find > handles that will match the color of the switch and they look quite well. > > LT 90 SP Eclectic, AL > ----- Original Message ----- > From: "John" > To: > Sent: Monday, April 18, 2005 10:14 AM > Subject: [WanderlodgeForum] Re: Front Air > > > > > > > > Bill, > > > > Don't feel like you are the only one that has done that, I have found > > that the location of the switches, is very prone to being turned off > > by the arm rest on my drivers seat, when it is slid sideways and now > > that is the first thing that I check when one of the three roof airs > > on my 'Bird does not work. > > > > > > JOHN FINN > > '82 35 FCRB > > HOPKINS, SOUTH CAROLINA > > "ON THE ROAD IN " > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > http://www.pbase.com/iamflagman/image/24977457 > > > > ///////////////////////// > > > > --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" > > wrote: > >> > >> Thanks Lawrence & all that responded, > >> I had come to the conclution that my caoch was differnent from all > >> the rest. The switches everyone was talking about were just not > > there. > >> Well, this morning I sat back down in the seat and relaxed and just > >> let my eyes roam over the dash. I noticed that the drapes, which I > >> keep closed when not in use, touched the the very top of the lower > >> left (on the wall beside the driver) panel of switches. I reached > > over > >> and moved the drape and guess what I found. Boy do I feel dumb. > >> Problem solved, that is after I put the coach back together. > >> You guys don't know how much I appreciate this group. Thanks Ernie. > >> Bill AR 90sp36 > >> > >> --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > >> > >> > Bill > >> > On my 90 SP the "2 switches above the driver" Jeff refers to are > >> actually on > >> > the top left of the lower dash. The top switch operates the front > >> AC while > >> > the one under it operates the rear one. They also operate the > >> electric heat > >> > front and rear > >> > Lawrence Thornell in Eclectic, AL > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > |
04-28-2005, 04:24
Front Air
On the 89SP the relays are alongside the breaker panel. Find the
screws in the grey fabric covered surround by feeling for depressions. If relays are not there then pull the wood panel around the drawers in the aisle side of that cabinet. --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > As mentioned, you do have the two switches on above the driver's head > (front and rear A/C)? > > These switches control two relays in a metal enclosure, with the rig > quiet you should be able to have someone switch them on/off and find > the relays, usually near the breaker panel but not sure in the SP. > > - Jeff Miller > http://www.wanderlodge.net > > > --- In WanderlodgeForum@yahoogroups.com, "Bill Rowe" > wrote: > > > > Jeff & All, I dropped the cover, no power, checked behind the > braker good power, found box where two hots and commons connect and > go out as one each + ground to unit on roof, no power coming in. must > be another breaker somewhere. between main braker box and junction > box. I don't think the wall thermostat is in the involved with air > conditioning. > > I am writing on PDA so please excuse errors . > > Bill 90sp36 |
